Author Topic: 98 EV fuse and relay diagram  (Read 8479 times)
Offline flower_king001
« on: August 29, 2018, 01:18:25 AM »
Hi,
 Anyone point me in the direction to a fuse/relay diagram?
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline Madtownguzzi
Randy S.
98 V11 EV
05 HD Electra Glide Classic
Madison, WI
Re: 98 EV fuse and relay diagram
« Reply #2 on: August 29, 2018, 04:48:36 AM »
Heres mine
The fuse at the battery positive is something I added
I never did figure out where the Blue/Blk at fuse 3 went to
Note Patrick points out in the next post the first two relays are swapped around.
98 must have been a banner year for the EV, every man and his dog seem to have one.
« Last Edit: August 29, 2018, 02:43:27 PM by Kiwi_Roy »
« Reply #3 on: August 29, 2018, 06:04:04 AM »
Thank you both!
Brian
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline pehayes
« Reply #4 on: August 29, 2018, 11:24:55 AM »
Careful.  The published wiring plans for the 98EV are often in error.  Seems to depend on the date of your bikes assembly.  On both of our 98EVs, the frame wiring matches the published plans but the engine wiring matches the earlier 1100i.  When diagnosing, be prepared to view both diagrams.  Meanwhile, I carry the following in the battery tray on both bikes.
1998 V11EV WIRING CIRCUIT PLAN
VIEWED FROM THE RIGHT SIDE
REAR TOWARD FRONT
RELAY #1   Starter
RELAY #2   Horn
RELAY #3   Side Stand Safety
RELAY #4   Headlight
FUSE #1   Fuel Petcock
FUSE #2   Turn Signal Flasher – Parking Light – Instrument lights
FUSE #3   Brake Light (foot) – Horn – Starter Solenoid
FUSE #4   Brake Light (hand) – Headlights – Charging – Tachometer – Idiot Lights
RELAY #5   Fuel Injectors – Computer – Relay #6
FUSE #5   Fuel Pump Relay – Fuel Injectors - Computer
FUSE #6   Fuel Pump - Coils
RELAY #6   Fuel Pump – Coils
« Reply #5 on: August 31, 2018, 06:34:07 AM »
REAR TOWARD FRONT
RELAY #1   Starter
RELAY #2   Horn
RELAY #4   Headlight
FUSE #2   Turn Signal Flasher � Parking Light � Instrument lights
FUSE #3   Brake Light (foot) � Horn � Starter Solenoid
FUSE #4   Brake Light (hand) � Headlights � Charging � Tachometer � Idiot Lights
RELAY #5   Fuel Injectors � Computer � Relay #6
FUSE #5   Fuel Pump Relay � Fuel Injectors - Computer
RELAY #6   Fuel Pump � Coils
Thanks Patrick...just printed out and laminated an extra one to go in my bike
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline xackley
« Reply #6 on: August 31, 2018, 08:23:59 AM »
While we're at it, what is the part number for the relay that replace the oem.
I clean up the connector for the fuses, and added spares to my tool bag. For a couple bucks it would be good to have a spare relay.
Thank you
Don
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Offline JoeB
« Reply #7 on: August 31, 2018, 08:30:08 AM »
Some of us get our relay's here: http://dpguzzi.com/relay.htm
His info shows some crossovers.
"This GEI AR4-012-C11 relay replaces 4 or 5 terminal relays used in Moto Guzzi, Ducati, Big Dog and other bikes, Cub Cadet and CaseIH MX Magnum tractors, and many other applications. It is a direct replacement for:
Bitron B047E 46520411-232006 & 232008
Borg-Warner (BWD) R3223
BMW 61 36 1 393 412 & 61 36 1 393 415
Bosch 0-332-207-307
Ducati 541.4.003.1A & 541.4.010.1A
Ford F57B-14B192-AA
Hella 4RD 931 524-02
Hongfa HFV6 012ZS-TR & 012HS-TR
NAIS ACM13221 & ACM33221
NHG NVFMCZ20 & NVFMCZ25
Omron G8HN-1A2T & G8HN-1C2T
Siemens V23073 & V23074
Song Chuan 871-1C-S-R1-12VDC
Tyco A1001-A402 & A1001-A403
Zettler AZ988-1CT-12DC1R(201)"
« Reply #8 on: August 31, 2018, 10:38:02 AM »
Sure do...I just bought 6 from Dan last week.
Brian
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
