Author Topic: Solder or Crimp, that is the question  (Read 2124 times)
Offline pyoungbl
« on: September 17, 2018, 08:48:29 PM »
I have seen lots of opinions about wire connections, personally I crimp.  Here's a video that seems to make sense and may be useful:
https://www.youtube.com/watch?v=faLn-SjVfwY
'13 V7 Special (red/white)
Re: Solder or Crimp, that is the question
« Reply #1 on: September 17, 2018, 08:54:54 PM »
Yep, crimp only just like the motorcycle and automobile manufacturers did at the factory. I use the original type connections and use a proper crimp tool.
Offline lucian
« Reply #2 on: September 17, 2018, 09:06:13 PM »
Good info , interesting he prefers the un insulated connectors and them shrink wraps them. makes sense. thank's for sharing that video. :thumb:
Offline Warren Rhen
« Reply #3 on: September 18, 2018, 01:28:44 AM »
Posi-lock or posi tap google it or check ebay. Not cheap but worth the money
Cheers,
Warren
16 Piaggio BV 350
86 Citroen 2CV6 Dolly
18 Dodge Charger R/T
Offline roadscum
« Reply #4 on: September 18, 2018, 04:51:51 AM »
Yes sir, nut'n better.... like a cold draft beer.  :boozing:
Paul
"The only true wisdom is in knowing you know nothing " - Socrates
Paul M. in SW Florida: 318 miles, 11 curves and not a Guzzi dealer in sight!
Offline lucian
« Reply #5 on: September 18, 2018, 06:37:53 AM »
posi locks look interesting but look like they are large in size for a lot of tight spots with multiple connectors on bikes.  I've always used the insulated marine grade crimp connectors that have the adhesive shrink covers.  The kit I have now is by Total Boat and is a great assortment for under 50 bucks. Any decent marine store should have these. Here  a place called Hamilton Marine,  Portland Maine
« Reply #6 on: September 18, 2018, 08:17:54 AM »
I always carry a few PosiLocks and some wire on the bike for roadside repairs. But I would not trust them as a permanent connection. They press the wires against the metal post with a plastic nut. Over time and heat cycles that plastic will get loose and the connection will get bad.
Offline Sheepdog
« Reply #7 on: September 18, 2018, 08:39:20 AM »
IF (capitalized because it’s a big “if”) I cut into my bike’s harness, I treat it like a point-to-point wired amplifier: soldered and encapsulated in shrink-tube.
Online John A
« Reply #8 on: September 18, 2018, 10:53:53 AM »
This is good general info
http://www.sullivanuv.com/wp-content/uploads/2014/06/Aircraft-Wiring-Best-Practices.pdf
He believes in solder. I use crimp as well, it's interesting to note that you can't use crimpers without the automatic tensioner on certificated aircraft.
« Last Edit: September 18, 2018, 11:45:57 AM by John A »
