Author Topic: Timing Cover Seal Installation  (Read 12588 times)
Online blackcat
« on: September 22, 2018, 07:12:02 AM »
The seal is leaking a little (enough to cause a minor drip) on the CX and looking through the manual it says that I should use tool # 14927200. My first question is, can I remove the existing seal without removing the timing case cover and can I use a socket the size of the seal to install the new seal? Thanks.
Re: Timing Cover Seal Installation
« Reply #1 on: September 22, 2018, 07:25:52 AM »
I would think you could, but it will be a pretty deep socket. disclaimer.. I've never done it.
Online blackcat
« Reply #2 on: September 22, 2018, 07:41:05 AM »
I had assumed that I would need to remove the cover and now that I look at the factory tool, it looks like that cover has to come off.
« Reply #3 on: September 22, 2018, 08:13:22 AM »
No need to remove the timing cover, just remove the alternator stator and rotor, then use a seal puller to pop the old seal out.
Be sure not to gouge the the timing cover with the pointed tip of the puller. A deep-well socket works fine for installing the new seal.
Online blackcat
« Reply #4 on: September 22, 2018, 08:29:47 AM »
Charlie, thanks. I purchased a gasket in case the cover needed to come off but I'd rather not have to remove it.  Stupid me, when I rebuilt the engine this replacement was on my list and it just slipped my mind.
Offline dxhall
« Reply #5 on: September 22, 2018, 08:59:41 AM »
Does not the seal install from the inside?  I think the cover must come off.
Offline TOMB
« Reply #6 on: September 22, 2018, 09:25:56 AM »
If you were doing tbis on  V700,Ambo,Eldo the yes the cover has to come off as those seals are installed from the inside.
The Toni framed ,T 850 T3 type install from the outside.
The hardest part is removing the rotor.
TOMB
« Last Edit: September 22, 2018, 10:38:00 AM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #7 on: September 22, 2018, 09:46:42 AM »
Put your hardened pin in there, tighten the bolt good and tight, smack the end of the bolt head with your copper hammer.. and be ready to catch the rotor to keep it from falling on the floor.  :smiley:
At least that has been my experience.
« Reply #8 on: September 22, 2018, 10:54:36 AM »
Yep, it's an easy seal replacement, and good instructions on the posts here :thumb:
Online blackcat
« Reply #9 on: September 22, 2018, 05:29:33 PM »
Yes, have the pin,seal puller and the seal.  I'm hoping this is the last of my oil weep/leaks on this bike. A few weeks ago I (with the help of GuzziOwner) laid the bike over, removed two old failed helicoils that I installed 12 or so years ago and found another stripped pan bolt and timeserted all three of them which ended a major leak.
I hate oil leaks.
Thanks all.
« Reply #10 on: September 23, 2018, 09:41:56 AM »
Not all V700s had a lip on the timing cover. So on those, it is possible to replace the seal without removing the timing cover.
« Last Edit: September 23, 2018, 06:57:11 PM by Antietam Classic Cycle »
Online blackcat
« Reply #11 on: September 23, 2018, 01:43:57 PM »
Start to finish this took about 10-15 minutes. The old seal could have come out with a paper clip it was leaking that bad.
« Reply #12 on: September 23, 2018, 01:52:48 PM »
« Reply #13 on: September 23, 2018, 04:09:32 PM »
 :grin: Sometimes the worrying is worse than the doing..
Not to say worrying is bad, it makes you have a plan to execute.
Online blackcat
« Reply #14 on: September 23, 2018, 04:14:45 PM »
I kept putting this off because I thought that the timing cover had to come off. Not that that was that difficult, but it definitely would have taken much longer.
Offline Lesman
« Reply #15 on: September 25, 2018, 12:14:35 PM »
I had a leak on my timing cover of my Quota. The gasket was clearly fubared. I replaced the gasket and the timing cover seal. Still had a leak. Turned out there is an o ring on the crank. Replaced the oil ring . Fixed the leak. Does the CX have this o ring?
« Reply #16 on: September 25, 2018, 12:24:18 PM »
Do tell what you used to install the new seal.
I found a 3/4 drive socket will slip over the long crank shaft to undo the sprocket nut.
Turn it with a pipe wrench or grind a couple of flats for a 12" Cresent Wrench.
« Reply #17 on: September 25, 2018, 04:09:47 PM »
No, only the later engines with a non-tapered "nose" on the crank have that o-ring.
Offline stevoreno
« Reply #18 on: October 21, 2023, 09:18:07 AM »
can you explain how to get the pulley off and how you got it back on without changing the timing
Online blackcat
« Reply #19 on: October 21, 2023, 03:00:06 PM »
What bike are you talking about?
« Reply #20 on: October 21, 2023, 04:34:21 PM »
On Loopframes (V700, Ambo, Eldo) the pulley can be incorrectly installed very easily (120 or 240 degrees off). Before you remove the pulley, rotate the engine until the left-side piston is at TDC. The TDC mark on the pulley should now align with the arrow on the timing cover. If you don't rotate the crank then you just align the marks again during assembly. If you do rotate the crank, simply repeat the above - find TDC on the left cylinder and align the TDC mark on the pulley with the arrow on the timing cover.
I use an M6 x 50 bolt with the head cut off as an alignment stud. Thread it into one of the holes, then slide the pulley back half, shims and pulley front half on, thread in two bolts, remove stud, thread in third bolt.
Offline stevoreno
« Reply #21 on: October 22, 2023, 11:26:11 PM »
Thanks for the info    :grin:
Offline stevoreno
« Reply #22 on: November 13, 2023, 12:22:47 PM »
how do you get the big nut off without the special 12905300 tool.
« Reply #23 on: November 13, 2023, 02:49:28 PM »
Air or electric impact. If you have an Eldorado, insert a small pry bar in through the timing inspection hole on the right side of the transmission and engage the start ring gear to lock the engine from turning. May be able to put the bike in gear, hold the rear brake on and then loosen that nut.
Offline stevoreno
« Reply #24 on: November 13, 2023, 06:38:29 PM »
I made a tool and it bent :( is it right or left hand thread. I only had a pice of aluminum but I can double it up
« Reply #25 on: November 13, 2023, 07:20:02 PM »
Right-hand thread. It's on there tight, makes my air impact really "grunt" to remove it. On occasion I need to heat the nut to help convince it to move.
Offline stevoreno
« Reply #26 on: November 13, 2023, 09:13:28 PM »
Thanks :) ill try again
Offline Scout63
« Reply #27 on: November 14, 2023, 06:53:14 AM »
I would have crabbed the frame, pulled the gearbox, clutch and flywheel and pulled the crank from the rear.  Then the front oil seal would have been a breeze…
Ben Zehnder - Orleans, MA USA
Offline Perazzimx14
« Reply #28 on: November 14, 2023, 02:51:03 PM »
Hardened pin or a section of the right size allen wrench cut to size  :thumb:
2017 Road Glide Special
2020 Kawasaki KLX300SM
« Reply #29 on: November 14, 2023, 08:30:28 PM »
Don’t use something that will distort for it will get stuck and be a major bad thing to fix. Note everyone says “hardened pin”
