Author Topic: Cal 2 rear drive seal replacement ??  (Read 2048 times)
Offline brider
« on: September 29, 2018, 07:38:10 AM »
Looking at my rear drive, I can't figure out how to coax the housing that the large seal is in from the main case. It appears like the housing was installed using some kind of sealant, as evidenced by the squeeze-out at about the 12 o'clock position in the image below:
list of wordsworth poems
I myself have never had this unit apart, and I bought the bike with under 6k miles on it. The Guzzi manual I have has NO re-build instructions for the drive unit; is it typical to seal this housing with sealant? I bought a seal kit for it from MG, and it has a gasket for this housing. I find it VERY hard to believe the PO took this apart with under 6k miles on it.
So, in the absence of sealant, what's the trick to get the housing out? A few soft blows circumferentially with a rubber hammer on the ribs? It LOOKS like the housing gasket surface sits BELOW the outer surrounding rib of the larger unit, so I can't wiggle a pry blade under it.
Tempted to just pry out the seal and replace it alone if the housing is bonded in.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Re: Cal 2 rear drive seal replacement ??
« Reply #1 on: September 29, 2018, 08:31:43 AM »
Here's how I do it:
Remove all of the cover/flange bolts, insert a suitably sized socket into the axle spacer, turn the legs of my smallest three-legged puller so that the "hooks" point outward and grab the edge of splines. The o-rings around the hook's pivot help to keep them in place.
Online John A
« Reply #2 on: September 29, 2018, 10:20:21 AM »
Put it back together with exactly the same thickness, it adjusts gears mesh. You may want to replace inner seal while your in there. If you haven't already disturbed the cover plate it may be better to just replace the big seal with the cover in place. They can be tough to get out, mostly destroying the seal in the process.
Offline brider
« Reply #3 on: September 30, 2018, 08:12:05 PM »
Here's how I do it:
You mean the female splined piece will pull out the seal housing? I'm having a hard time imagining how they're attached, and if they're not, is there some kind of thrust bearing interface??
The kit I bought has the inner seal, but honestly, I have no interest in pulling the housing if I can just replace the outer seal with the housing intact.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
« Reply #4 on: September 30, 2018, 08:44:43 PM »
I pull the flange w/bearing out along with the female splined hub and ring gear. If you're not intent on replacing the gasket(s), then pluck the seal out and replace it only.
Offline brider
« Reply #5 on: September 30, 2018, 08:51:14 PM »
Thanks, I'll just do the outer seal then.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
