Author Topic: Stainless brake line kit moto guzzi ev?  (Read 3963 times)
Offline flower_king001
« on: October 02, 2018, 10:48:44 AM »
Hi,
Anyone know a source here in the US for?
Stainless brake line kit moto guzzi ev 1998?
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Re: Stainless brake line kit moto guzzi ev?
« Reply #1 on: October 02, 2018, 12:00:32 PM »
FrenTubo makes a made-up kit, don't know who supplies them anymore.
their site has    https://sportbikes4hireshop.com/     as a USA dealer  , MG Cycle used to carry them and may get them if you call.
« Last Edit: October 02, 2018, 12:12:16 PM by guzzisteve »
« Reply #2 on: October 02, 2018, 12:16:52 PM »
I've been able to have stainless steel brake lines fab'd at local shops.  Otherwise, you might consider making the lines yourself from one of those universal kits.
What I have seen done is to take the old lines off and use them as a pattern.  Then cut the right length of tubing and the proper banjo joints with proper angle radius can be matched up.
You might just go to local bike or service shop and ask them about it.
« Reply #3 on: October 02, 2018, 12:23:43 PM »
Home made brake lines can be dangerous.  Even factory made ones can be imperfect.  I recently had to change a Russell (factory) line out on the trike because it was leaking at the swedge.  get DOT-approved lines made to length with the ends you need.  they are not cheap, but stopping is the most important thing you do with a bike.
Offline JBBenson
« Reply #4 on: October 02, 2018, 12:53:57 PM »
I think Spiegler probably has something for your bike:
https://spieglerusa.com
« Reply #5 on: October 02, 2018, 01:21:12 PM »
Earls on gasoline alley in Indy will make up custom lines for about 20 bucks each. (!) Good stuff. They've done several for me.
Send them your stuff if you're not in the area, they'll make up new stuff.
The usual disclaimers..
https://www.holley.com/brands/earls/
Offline Diploman
« Reply #6 on: October 03, 2018, 10:51:46 AM »
I beg to differ - DIY brake lines are no more dangerous than prefabricated lines, provided the home assembler knows how to follow directions included in the package.  Putting together lines and fittings is not exactly an exercise which requires an intellectual giant.  I have used with success both Magnum lines (MG Cycle) and Goodridge Sniper II microbore lines.  Of the two, the Goodridge lines are better adaptable to motorcycle dimensions and spaces, while the Magnums are more automotive-sized.  I prefer the Goodridges.  I have never had any sort of failure with either brand.  DIY offers the ability to customize and route lines any way desired: also, considerably less expensive (Guzzi content) than prefabricated.  Perfectly safe if assembled correctly.
2015 KTM 390 Duke
« Reply #7 on: October 03, 2018, 09:02:27 PM »
Differ away.  And show me your DOT approved, DIY assembly.  That's the differ I'll listen to.  They don't approve those for a reason.
If a brake circuit was redone end-to-end with -3AN fittings and swivel ended hose it would be solid.  But it's not like the diy you're wanting.  You get the DOT braided hose done up to length (many standard lengths out in quality mass production that will fit) with swivel female ends already fitted.  Then you add the end bits (banjo, flare, whatever) you need.  They just couple up like any flare.  This is commonly used in streetable custom automotive work and the components may be available at your local custom shop.  Be wary of internet (ebay) offerings.  Many are fake or poor quality.  Get the good stuff.
« Last Edit: October 03, 2018, 11:32:35 PM by rodekyll »
« Reply #8 on: October 03, 2018, 09:19:14 PM »
I had a Russell brake line rupture when I was doing a track day.   NOT  FUN!!  (Neither was riding the bike home with only a rear brake.)
The guys at Racing Innovations fab'd a replacement.  (They build drag bikes and chopper frames for TV father & son soap opera)
Offline toolittletime
    • mysportgear.com
« Reply #9 on: October 04, 2018, 02:16:53 PM »
I have used the Magnum products from MG Cycle:
All length hose and lots of fittings available......sear ch "Magnum" on the MG Cycle site.
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_114&products_id=2664
Worked good for me.
Tim
« Last Edit: October 04, 2018, 02:18:58 PM by toolittletime »
X-MSF Instructor
MGNOC 22710
12 Norge
2002 Cali EV
74 Eldorado
« Reply #10 on: October 04, 2018, 09:05:14 PM »
From MG Cycle's website:
Magnum BYO brake banjo fitting 60 degree angle. No more guessing pre-cut hose lengths, simply assemble these brake hoses and fittings on the bike for a perfect fit every time. Meets all DOT FMVSS-106 standards for safe and reliable on-road use.
Magnum Build Your Own DOT approved braided stainless brake hose only, 6 foot section.Use only with Magnum brand fittings, which are not included.
No more guessing pre-cut hose lengths, simply assemble these brake hoses on the bike for a perfect fit every time. Meets all DOT FMVSS-106 standards for safe and reliable on-road use.
« Reply #11 on: October 05, 2018, 10:52:15 AM »
I like the part where the prospect can't measure point A to point B for a ready-made length, yet he's assumed competent to measure that same distance to roll his own.  I'll argue that if he can't do a proper measurement, he can't do a proper assembly.
The parts may meet DOT.  The assembly does not.  As you said earlier, it's the skill of the assembler that counts.  I've built dozens of these.   Some work.  Some fail over time.  Most leak.  For my liability and health, the approach I wrote up above makes better sense.
We've discussed how even the factory built ones can have problems, and the factory builds them all day.  So why do a hold-my-beer fabrication for such a critical area when the good stuff is readily available, made up and waiting for the banjos of choice?
That's all I've got.
