Author Topic: Lifter bore wear in a big block Guzzi?  (Read 9729 times)
Offline bigbikerrick
« on: October 10, 2018, 03:02:58 PM »
Hello Folks, the other day while assembling the top end on my eldorado, a question came to mind. The lifters on a big block run up and down in the aluminum block, and there is no replaceable sleeve of any sort where the lifters run.
 This seems like an area that would wear, since its steel running against aluminum. I have never read anything about checking clearances or fit between the  lifter and the hole in the block. A friend that was visiting me while I was assembling my engine asked me this, and I was stumped!
Do these blocks ever "wear out" or the lifters get loose in their bores?
They are not lubricated by an oil pressure film, just oil that drips down the pushrods, and works its way between the lifter and the block, right?
mine seemed to fit fairly tight, with 40K miles on the block, almost as if no wear has taken place.....What gives here?
Rick.
jwinwi
Re: Lifter bore wear in a big block Guzzi?
« Reply #1 on: October 10, 2018, 03:57:39 PM »
 :popcorn:
Offline RinkRat II
  • Lake Powell AZ
« Reply #2 on: October 10, 2018, 03:59:56 PM »
   Lifter bore....22.0mm-22.021mm
     Tappet dia......21.978mm-21.996mm
       Oversize tappets sold 0.05 and 0.10mm over
          Tappet to bore  clearance 0.004-0.043mm
         Paul B :boozing:
« Reply #3 on: October 10, 2018, 04:08:29 PM »
Even on the most worn out, poorly maintained old Guzzi engine, I've never found the lifter bore worn.
« Reply #4 on: October 10, 2018, 04:25:38 PM »
I have on very rare occasions replaced tappets with oversized ones but this has always been done as a very last resort to try and quieter down bikes with noisy top ends!
Older doundfins especially tended to get 'Clanky', especially on the left for some reason. Usually re-facing the rocker tips and installing new pins and bushes fixed it up but on some occasions it didn't and although the 'Clankiness' never seemed to cause any damage it did upset a couple of customers so much they kept on at me to chase it. Gradually, after replacing part after part, cam, lifters, retainer plate, pushrods etc. the only thing that hadn't been done was the lifter bores. So O/S tappets were bought and the block duly reamed and everything refitted and, wonder of wonders! The motors were whisper quiet! For about 5,000 miles. Then the 'Clank' gradually returned. :violent1:
Make of that what you will.... :grin:
Pete (Who is now so used to riding an early 'Roller' 8V that produces an 'Industrial Deafness Inducing' racket even when running perfectly that a 'Clanky' roundfin sounds like the gentle tweeting of birds on a spring morning!)
« Reply #5 on: October 10, 2018, 05:06:13 PM »
Excellent information, Guys! I had no idea lifters were available in oversize dimensions. I also never knew that lifter bore wear, although uncommon, could be a source of noise, to consider when evaluating weird engine noises. :wink:
thanks alot,
Rick.
Offline jacksonracingcomau
« Reply #6 on: October 10, 2018, 07:05:50 PM »
Imhe
Like gudgeon pins, rocker spindles etc etc, the opposite to what you think happens
The hard part wears out not the soft
I have changed lifters that had perfect face, no pitting at all
But sides worn out to cock in a sock fit in cases, appropriate noise fixed with std new
Have both oversizes in stock for 30+ years, still haven't needed them.
Simple test, finger in lifter, wiggle to feel play, if it rocks try new one
Measure sides with mic to confirm but visual gives em away too
Have actually broken lifters too, from same wear, again new std fixed, Pete's one well extreme but someone has to get them. Bet all osize are now very old, not a fast moving item, guess I will die with mine but if anyone needs.......
« Reply #7 on: December 05, 2023, 05:48:44 PM »
Revisiting this old post. Rebuilding a customer's 850 Le Mans engine and find that all the lifter bores are "egg-shaped" and one looks like a bit of material has flaked off the bottom (closest the cam). Three are a little out of spec., the damaged one a lot. Lifters are all in spec.
The question is: are oversized lifters/tappets really available, and if so, where?
Offline RinkRat II
  • Lake Powell AZ
« Reply #8 on: December 05, 2023, 06:48:26 PM »
  Cadre's fiche shows the part No.s but you'd have to call and check availability.
    GU10045801...  .005mm
     GU10045802... 0.10mm
  Haven't checked since 2018.
    Paul B.  :boozing:
« Reply #9 on: December 05, 2023, 09:38:19 PM »
    Paul B.  :boozing:
Thanks. Found a set of 1st over in Yurp.
« Reply #10 on: December 05, 2023, 09:55:44 PM »
Its always nice,when a plan comes together!   Just curious, Charlie, what is yurp?
Rick.
« Reply #11 on: December 05, 2023, 09:58:29 PM »
Rick.
Europe.  :azn:
« Reply #12 on: December 05, 2023, 11:53:03 PM »
Missed this one but Charlie found em anyway
As I posted earlier in this thread I have a set of first and a set of second oversize if anyone ever finds this thread again.
I’ve had them for 40 years and never needed them so it’s not a common thing
PM me if you need them, sell at current market price for std ones
Offline Frenchfrog
« Reply #13 on: December 06, 2023, 05:42:03 AM »
I came across a case where the bores were well worn many years ago in the UK ...but the bike was in an awful overall  state and with high mileage.
Offline Alfetta
« Reply #14 on: December 06, 2023, 07:29:15 AM »
steel on aluminum is actually a very good bearing surface. most modern car engines actually run the cams directly in the aluminum head without inserted bearings.
In the case of Guzzi lifters, the force is mostly linear and the bore doesn't have to do much more than guide the lifter. unlike a cam shaft bearings that are bucking the forces of the valve springs directly.
its a good solid design.
« Reply #15 on: December 06, 2023, 08:43:37 AM »
This particular Le Mans engine is a huge mess. All of the lifter bores are worn and one has damage at the bottom closest to the cam.
I'm not sure 1st over will clean it up, so 2nd over may be required.
« Reply #16 on: December 06, 2023, 02:52:45 PM »
Interesting to me. So, is it from not rotating?
« Reply #17 on: December 07, 2023, 03:35:23 AM »
Here if you need them but maybe cases are binfodder, run dry (or 30 year old oil) for long enough, the cam journals might be donald as well
« Reply #18 on: December 07, 2023, 08:51:39 AM »
I checked the cam and journals - both are near perfect. I sent you an email about the 2nd over followers.
« Reply #19 on: December 10, 2023, 02:40:02 AM »
Old email no longer used, I sent you pm with new one, hope that worked, if not try pm me
Offline MattP
« Reply #20 on: December 11, 2023, 02:49:30 PM »
if the lifters are fine i would sleeve them
Offline moto-uno
« Reply #21 on: December 14, 2023, 08:21:59 PM »
  It's been a while since I was last into my Le Mans 2 motor , but if my memory serves me (kinda questionable) I was sure the
cam lobes ran somewhat off center and would tend to cause the lifters to slowly rotate .  Peter
Offline Frenchfrog
« Reply #22 on: December 15, 2023, 05:53:26 AM »
And the lifters are very slightly domed too to help make that happen ...never had reground ones but I do wonder if they replicate that feature?
Offline Moparnut72
« Reply #23 on: December 15, 2023, 09:08:05 AM »
This is a video by Uncle Tony of Uncle Tony's Garage explaining lifter and camshaft design and the reasons why. Well worth a view, I am sure you will learn something if not a lot. Applies to what is being discussed here. Check it out.
kk
https://youtu.be/7M-yopGZO94?si=lhyuG-a0Sn0AxzOm
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline moto-uno
« Reply #24 on: December 17, 2023, 05:46:15 PM »
   ^  Well I'm truly shocked , in this video he seems to reference  "Mopar"  engines  :laugh:  !  Peter
Offline Moparnut72
« Reply #25 on: December 17, 2023, 08:48:03 PM »
Gee, go figure.   :grin:
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
