Author Topic: TPS question or two  (Read 8128 times)
Offline flower_king001
TPS question or two
« on: October 21, 2018, 07:02:12 PM »
Have owned my 1998 EV for the past 10 years. I never changed out the TPS but been having drive-ability problems for the past few months. I seem to hit a spot around 78-80 MPH where the bikes misses. My questions is as I have gone through a slew of things that I'll list later. Question, bike has a Harley Davidson 27271-95 HD TPS in it. It was set on 2.1 and smooth all the way to and from WOT. So I took it out and sprayed some CRC and turn it back and forth with a flat head screwdriver and set it back to 2.1. Same drive-ability problem trying to maintain a steady 78-80 mph. So the TPS seems good by the readings, could it still be bad?
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline RinkRat II
  • Lake Powell AZ
Re: TPS question or two
« Reply #1 on: October 21, 2018, 07:56:42 PM »
     KoF,  The Harley TPS and The Guzzi TPS are similar but not quite the same ,as their performance curves are different electrically due to fueling,spark advance differences between a Harley and your Guzzi.  As to your question, they can get worn spots in them as they are just a potentiometer. One thing you could try is to leave the tps just loose enough to move it with finger pressure and go for a ride. When it stumbles move it ever so slightly and see if it clears. If so it'll be pretty obvious and you'll need to replace it.  Hope this helps.
        Paul B :boozing:
« Reply #2 on: October 21, 2018, 08:09:05 PM »
How old are your plug caps and wires? Can you replicate at same rpm in say 4th gear?
Offline pehayes
« Reply #3 on: October 21, 2018, 09:41:14 PM »
How did you get electronic cleaner INSIDE?  I drilled a 1/16" hole here where the white dot is located.  Plugged with silicone when finished.
Offline pehayes
« Reply #4 on: October 21, 2018, 09:43:39 PM »
What are you using to set the base TPS value?  I would recommend a voltmeter to obtain 150mV base install with linkages disconnected and throttle butterfly fully closed.  Once the linkage is reconnected you should have around 385mV.
« Reply #5 on: October 22, 2018, 10:12:37 AM »
I'm using Technoresearch Centurion
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #6 on: October 22, 2018, 10:14:57 AM »
If I had a worn spot I would think it would show up while viewing the Centurion software. The TPS doesn't stick at all and readings from 2.1 all the way to WOT and back are as smooth as can be with no jump in numbers. I did think about setti ngthe TPS from 2.1 to 2.3 and see if that makes a difference.
        Paul B :boozing:
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #7 on: October 22, 2018, 10:18:04 AM »
wires and caps about 2 months old. Purchased them through MGCycle..NGK 5K ohm caps, 7 mm wire
Replicate in 4th gear? Have not tried that yet. My only other thought is to pull the injectors and send them off to be cleaned.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline John Croucher
« Reply #8 on: October 22, 2018, 10:20:03 AM »
A TPS will come apart very easily.  There is not anything complicated inside.  A three pronged brass brush rubbing against a internal wire winding.  The brass brush section on one I replaced was bent, worn, and not touching the wire coil correctly.  Actually touching advanced and retarded.  I tossed it and installed a new one.  Bike ran much better.
Setting does not have to be complicated.  Set you idle speed and adjust the TPS to 500 mva.  Takes about 2 minutes. No need to turn, adjust, check, adjust, close throttle, open throttle, synchronize, turn, check.
 If you put a timing light on the bike and check the timing mark while adjusting the TPS, you will see the engine timing change.
Grab the sparkplug wires and caps while the engine is running and on hand on a good ground on the bike.  If you get shocked, replace wires, caps and or coils.
« Reply #9 on: October 22, 2018, 10:21:11 AM »
I didn't drill a hole...the TPS was not all that dirty on the outside/inside where I could see. Just sprayed CRC and turned with screwdriver. All felt very smooth
While viewing software/program on my laptop and turning throttle if all is smooth going going up and down the number scale, would you think I did to drill a hole and clean or? Could there still be a problem if I see nothing in the readings on the program?
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #10 on: October 22, 2018, 02:04:19 PM »
You could try adjusting the sensor to a different spot. The book has a + or - on the setting. I have noticed the motors I work on like +15mv better than the 150 number. I've had very good results doing this. It helps w/motors running open intake or exhaust.
I have also seen a post here giving location of the original TPS for a reasonable price. I have had no runability issues w/HD sensor.
Just had a thought, have you checked the fuel pressure, unless the pump is newer than 20yrs old.
« Last Edit: October 22, 2018, 05:37:15 PM by guzzisteve »
« Reply #11 on: October 22, 2018, 03:17:08 PM »
Back in the day, I had a bad TPS on the Jack-All, and the Centurion software didn't show it. You'll have better luck checking it with an ohm meter, preferably analog.
Offline malik
« Reply #12 on: October 22, 2018, 05:32:54 PM »
Found out how to test the TPS with Guzzidiag on the V7C - watched the Throttle V while slowly moving the revs up the range. At 3,400rpm the V would fluctuate wildly between 6 & 10.8, while at other revs the V was fairly steady. Replacing the TPS cured the missing at around 3,500-4,000rpm on constant throttle. Success at last.
« Reply #13 on: October 23, 2018, 12:30:20 PM »
Thanks for that Patrick..I did just that today and reset. I also had a new temp sensor so I installed that as well even-though it was checking good with Centurion. I will test bike on my way to work this afternoon.
 Prior to the above..the bike starts and idles just fine and after a few miles of warming engine up I don't have the hesitation problem. Thoughts?
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #14 on: October 23, 2018, 12:31:37 PM »
Did just as you stated yesterday and all was good.
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
« Reply #15 on: October 23, 2018, 12:32:32 PM »
No...but just added it to my lists of things to do...thanks!
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline ejs
« Reply #16 on: October 23, 2018, 02:40:44 PM »
[/qudote]
To much air when cold :grin:
California EV 1999
« Reply #17 on: November 01, 2018, 07:41:42 AM »
Update:
 Replaced TPS the other day and bike runs brilliant! Purchased the TPS here:
https://ca-cycleworks.com/pf3c
thanks to all here1
1971 BMW R90/5
2005 BMW 1200 RT
2007 BMW 1200 GS
Offline RinkRat II
  • Lake Powell AZ
« Reply #18 on: November 01, 2018, 09:25:27 AM »
  Flower_King, glad you got it sorted!
     Paul B :boozing:
Online Ncdan
« Reply #19 on: November 01, 2018, 09:27:34 AM »
That's a fare price unlike the TPS on the 1400, 400-450.00. Rip-off!
