Author Topic: New paint job completed on my Cal II  (Read 6500 times)
Offline gearman
Re: New paint job completed on my Cal II
« Reply #30 on: November 24, 2018, 05:17:06 PM »
Consummate craftsmanship. Beautiful.
Rich
Well put :wink:
Offline brider
« Reply #31 on: November 26, 2018, 09:14:30 AM »
Lucian, what I like to do as prep is take it down to the metal, using aircraft paint remover, and or an abrasive disc, especially where the fenders are chromed, to get good paint adhesion. I finish this with 320 grit sandpaper, so the primer sealer will get a good"bite". I then spray Nason epoxy primer sealer on everything, then block sand with 400 then 600 grit to get the surface smooth and flat.
  Now I spray the basecoat color, and if I have to tape for a second color, I will spray a light coat of clear to allow me as much time as I need for taping, etc. ( you have  a couple of hours "window"to spray the clear over the base, so it bonds to the base, and wont peel, but once you have some clear down ,you can always go back and scuff it with 600 grit, and continue adding layers of clear as needed)
  I like to wet sand the clear with 600 grit , adding coats of clear until you cant feel any of the paint lines, and then I finish it by buffing with a foam pad on the drill using a 3M swirl mark remover , which is a very fine compound. How many times you wet sand and re clear is the trick to getting a deep, glass like finish.
Rick.
Absolutely bee-utiful, nicely done! I was going to wonder AGAIN why my Cal II Auto looks so raggy in comparison, and was about to commit to painting MINE also, until I read your painting regimen. Guess I'll be content to ride a rat-bike, and just appreciate the nice examples by the pros, like yours.
Cal II Auto IS THE BEST HIGHWAY BIKE, long, roomy, smooth, effortless (as long as you keep that TC happy!).
Here's a maroon job sold by a guy I knew in RI, 24k on the clock, sold for $2400, wish I had the brains to buy it:
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Online bigbikerrick
« Reply #32 on: November 26, 2018, 11:07:38 AM »
Thanks for the kind words, brider. I am far from being a "professional painter" , I am just a hobbyist, I dont have a paint booth, or anything fancy. I paint outside, on a covered patio behind my garage.
  The part of a paint job that is most tedious is taping for color separation, and pinstripes done in paint, etc. The sanding and prepping is actually fun.
  Another thing to mention, the quality of rattle can paints has improved dramatically in the last few years. I have a couple of buddies that have done some pretty  impressive paint jobs on bikes ,using some of the newer rattle can paints made by krylon, and rust oleum, then finishing with a chemical resistant rattle can clear , made for automotive wheels,over the top, for wear resistance.  You can even buy catalyzing rattle can paints,although they are a bit pricey.  The local auto paint store I deal with will mix automotive paint, then load it into a rattle can, ready to spray, for customers. Thats a good way to do the clear as well, if a person doesnt have a compressor and paint gun. One of the guys I mention, lives in an apartment, and painted the tins of his street bob on his small balcony! :laugh:
Rick.
Offline Groover
    • Scooteropolis
« Reply #33 on: November 10, 2026, 02:20:46 PM »
Well done  :thumb:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline drdwb
    • backfeelsgreat.com
« Reply #34 on: November 11, 2026, 06:17:55 PM »
Very nice. The finished product is worth the effort.
Online bigbikerrick
« Reply #35 on: November 11, 2026, 08:53:06 PM »
Thanks for the kind words, Guys. I miss that bike. I replaced it with a "regular" 76 convert that I really like, but that cal II automatic had a very special charm, and was a highway star with its very long wheelbase. I ended up putting a texas sidecar on the Cal II and sold it.
Rick.
Online TN Mark
« Reply #36 on: November 12, 2026, 09:40:20 AM »
Beautiful job on the Call II Bigbikerrick, congratulations to you sir.
