Author Topic: UJ Maintenance  (Read 3413 times)
UJ Maintenance
« on: December 01, 2018, 09:01:16 PM »
Just wondering, how often do you strip the UJ's on your bikes.
Mine is a smallblock Breva, which only has the one.
Offline Rolf Halvorsen
Re: UJ Maintenance
« Reply #1 on: December 02, 2018, 04:00:21 AM »
Never.
Change with a new one when the old has too much slack.
Rolf
Re: UJ Maintenance
« Reply #2 on: December 02, 2018, 05:01:54 AM »
Never.
Rolf
There's no slack in it Rolf.  Have just fitted another second hand gearbox in, and as I was putting the swing-arm back on I just wondered if they should have a bit of grease in them seeing they do have circlips in them.
It's all buttoned up now but if they should be serviced I thought I could do it at the next tire change.
Re: UJ Maintenance
« Reply #3 on: December 02, 2018, 06:15:38 AM »
More fresh grease is fine - but the job of doing it is terrible. Better to buy new when needed.
That is my opinion.
Rolf
Re: UJ Maintenance
« Reply #4 on: December 02, 2018, 12:55:51 PM »
That is my opinion.
Rolf
Thanks Rolf. Done them on cars before. You're right, about as much fun as having teeth pulled.
Re: UJ Maintenance
« Reply #5 on: December 02, 2018, 02:28:50 PM »
I agree with Rolf, I grease the driveline at tire changes and make sure the boot is ok but that's about it.
Re: UJ Maintenance
« Reply #6 on: December 02, 2018, 10:37:12 PM »
That's my usual as well.
Offline pressureangle
Re: UJ Maintenance
« Reply #7 on: December 03, 2018, 06:51:55 AM »
My '85 LM1000 has ~80k on the joint with no detectable wear. While the bike was apart, I warmed the cardan up in the sun (too hot to touch barehanded) and let it cool in a bath of gear oil. The idea was to draw some lube in by vacuum as it cooled. Dunno if it did but I feel better about it.
