Author Topic: floor board rubber removal  (Read 3488 times)
Offline xackley
« on: December 16, 2018, 02:47:02 PM »
I want to remove the rubber from the floor boards to clean up the rust. What is the safest way to pop them off without damage?
Thank you
Don
1958 R69 BMW, 1972 R75/5, 1980 yamaha XS650, 1982 GL1100, 2003 EV, 2007 Triumph America and 2017 V7!!!
All on the road, going nowhere in particular.
Re: floor board rubber removal
« Reply #1 on: December 16, 2018, 02:57:17 PM »
On the 2003 EV? Are they the type that are glued on or ride on rubber isolators?
« Reply #2 on: December 16, 2018, 03:28:03 PM »
2004 has the rubber insulators. You just carefully push them out from the bottom with a screwdriver. 2003 should have this style.
Offline xackley
« Reply #3 on: December 16, 2018, 04:30:29 PM »
Rubber insulators on mine. Ok, thats what I thought but decided to ask before I poked a hole through them.
I guess I'll soak them in hot soapy water before I try again.
« Reply #4 on: December 16, 2018, 04:48:28 PM »
Might help to warm them up a bit with a hair drier or heat gun.
Offline Ncdan
« Reply #5 on: December 16, 2018, 06:42:57 PM »
Take them out the same way one removes a tubeless valve from a wheel. Put a little  upward pressure on the board as you take a blunt screwdriver and starting at the edges push the nipples through the hole their in, one at a time. If they are very dry rotted they will probably break off at which time replacement is the only fix.
Offline giusto
  • Giusto il canne del Como
    • photobucket
« Reply #6 on: December 16, 2018, 07:51:30 PM »
and the best deal on replacement rubber is?
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
