...Any opinions, and suggestions much appreciated
I cannot speak to your question as to the smaller tire on a Cal2, but I do have lots of experience with both the bikes you've mentioned, which leads me to ask... Are you running 40psi in the Cal2 front tire?
I currently run about 32-35 psi in the front tire on my cal II. Is it advisable to run 40 psi?
Yes; the Cal2 is interesting in that Guzzi gave it the same rim and tire size, front and rear. I'd recommend 40 psi in both. For sure, 32 psi in the front will feel heavy.
