Everyone, a 2014 California is LED.
I would swap indicators with one that you know works to confirm or deny that the indicator is the problem.
Is that system canbus, or is it all separate wiring?
Thanks rocker59 I guess thats what I get for assuming people would know a 2014 would be LED. BK
As others say it will be an earth problem, current finding it’s way to ground thru the indicator light rather than the earth wire. If you can see a point on the socket connecting to the bulb body run a wire to ground to see if that fixes it, then start tracing the earth wire back to ground and fix it
