So Jim, what exactly is Tremclad, purpose etc. Never heard of it out here.
The reproduction knobs are too big, they foul on the seat, I need to find another source for these, same problem on my V7 Sport, I used acetone, clean rags, to wipe the seat, keep the rag wet and use a clean fresh rag with each wipe, it will make a 40 year seat look pretty good
Good assortment of different types at McMaster-Carr:http://www.mcmaster.com/#machine-component-knobs/=12mnxc7
Does anyone know if this is the stock switch and if so where I can find a new one? This switch was quite corroded and the spring loaded tang sticks a bit.
Something along these lines??http://www.ebay.com/itm/Emgo-Universal-Brake-Light-Switch-Rear-Stop-Spring-Pull-Motorcycle-New-K-S-/301366457630?hash=item462ad7351e:g:InoAAOSwfcVUE6bU&vxp=mtr Paul B
Great work Jim!Any idea where I can get one of those little clutch adjuster lock ring thingys on page 4?Frank750S
Yes, that's an original switch. Used to be available, but I haven't seen one for a while. Maybe Harper's? http://www.harpermoto.com/stop-switch-14741110.html
I had TrueDisc regrind the rotors, the powder coater did not mask the inner opening so the rotor will not fit over the carrier, a sanding wheel quickly removes the baked on powder
Did you also remove the powder coat where it mounts to the hub? If you didn't it's really back to have powder coat between the hub and rotor.
