Author Topic: Stupid Lario brake light switch  (Read 5397 times)
« on: June 19, 2017, 01:53:01 PM »
P/N 28741100
I put a new one on the Lario a couple of years ago and it's already failed. I wouldn't mind so much, but Harpers gets $55.87 plus shipping for a switch that is going to fail again. This is two switches in 4 years.
Has anyone figured out a work around with a reliable switch?
TIA
Edit to add picture..
2017-06-19_02-29-28 by Charles Stottlemyer, on Flickr
« Last Edit: June 19, 2017, 02:02:22 PM by Chuck in Indiana »
Offline Markcarovilli
Re: Stupid Lario brake light switch
« Reply #1 on: June 19, 2017, 02:09:42 PM »
Hand signals.... :evil:
Mark
« Reply #2 on: June 19, 2017, 02:15:09 PM »
Chuck, I'm not familiar with how that mounts and how much room is around it, but a search for things like "plunger switch" and similar combinations of words turn up similar switches.
« Last Edit: June 19, 2017, 02:16:06 PM by Triple Jim »
« Reply #3 on: June 19, 2017, 03:14:43 PM »
I buy industrial instruments for a crust.
I look at the size of those and the oil pressure switch and knowing what's inside them "that's not going to work for long"
Perhaps a trip to your local auto wrecker to find a decent switch or convert to a mechanical type.
« Reply #4 on: June 19, 2017, 03:45:29 PM »
I thought the one in the photo is a mechanical type.
« Reply #5 on: June 19, 2017, 04:32:44 PM »
Yeah, it's mechanical. I'm thinking of maybe coming up with a pressure switch.. but first.. I'll put this one in the lathe and cut the crimp off of it and see why it fails. *Maybe* repair it. If that doesn't work, I'll look in some machinery catalogs.
Just thought maybe someone had already been down this path and had an easy fix.
Offline not-fishing
« Reply #6 on: June 19, 2017, 04:35:11 PM »
What about converting to a banjo type?
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_146&products_id=586
I wonder if you could use a "plug type" like on my V50 III?  $21.17
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_146&products_id=957
Or
Brake light switch, banjo bolt M10 x 1.00  $19.76
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_146&products_id=1583
Or double banjo bolt.
One of the interesting things I found out about my Griso 1100 oil pressure sensor is that it's also used on BMW's (at a much lower cost).  It did take me two switches to get the right one because there's a course thread sensor sold by a will not be named Dealer as the correct sensor -(wrong)- and a fine thread sensor.
Guzzi uses "off the shelf" gear, the only problem is which BMW/FIAT/MATRA/OTHER EUROPEAN CAR MFG also uses them.
http://www.ebay.co.uk/itm/Moto-Guzzi-29741150-Frt-Stop-Switch-MG1452-/390907350109   From an overseas source  US $12.99
« Last Edit: June 19, 2017, 04:47:06 PM by not-fishing »
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
« Reply #7 on: June 19, 2017, 04:42:25 PM »
Thanks for that.. I'd already looked at what Cheese and Gordon had available. I'll look for a mechanical solution first before going completely non stock. I'd hate to throw away that custom $20 brake line that Earl's of Indy made for me.. (snapping suspenders)  :smiley:
Offline bad Chad
« Reply #8 on: June 19, 2017, 04:50:47 PM »
I don't know what kind of brake light switch the  v65 has, but I know it's been working non stop since 1984!   I have heard that the multi valve small blocks are known for gernading their brake light switches! ha ha
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #9 on: June 19, 2017, 05:22:54 PM »
You know, I don't ever shy away from defending our prices for original parts. Your post reads like you bought that one from me, but the one you bought from me back in September of 2016, you also returned 5 days later. I don't remember why you returned it, I am guessing because it was too much money. But maybe if you had used the OEM part it may have lasted 30 some years like the first one did.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
« Reply #10 on: June 19, 2017, 05:44:46 PM »
Curtis.. I don't mean to offend you at all. The reason I sent that one back was it was back ordered at the time, so I went elsewhere. I didn't *tell* you to order it, it just appeared in my mailbox with a bill. Probably a snafu of some sort. At any rate, the one I have is an OEM switch as far as I know.
I'm also *not* complaining about your pricing. I didn't mean it to sound like that at all. I know full well how expensive it is to stock all this stuff.
Again.. the reason I sent it back is I didn't order it, and already had one when it showed up. <shrug>
Offline kevdog3019
« Reply #11 on: June 19, 2017, 09:32:52 PM »
Never had one go tits up.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
« Reply #12 on: June 19, 2017, 09:41:53 PM »
You're right, I should have looked closer.
On my old Eldorado I have been using reed switches, 2 Amp ones are very common and ideal for LED type lamps, All you have to do is figure out how to move a magnet in the proximity and you have a sealed switch good for billions of operations.
Here's my indicator & Hi/Lo switch Mk2 built into the base of the old pillbox, Mk3 will have a few improvements.
Sketch of Mk1
« Last Edit: June 19, 2017, 09:55:35 PM by Kiwi_Roy »
Offline LeRoy
« Reply #13 on: June 19, 2017, 11:24:28 PM »
Sidestepping a discussion of Harper's price and availability, I'll refer instead to this thread:
http://wildguzzi.com/forum/index.php?topic=84415.0
Same switch, same problem. Charlie's pointer to MZ and Aermacchi is probably the most useful and helpful although it doesn't lead directly to an alternative source.
However, Googling "Magura master cylinder brake light switch" comes up with many hits. These look similar. albeit with a plastic body. But if it says "Magura" on the switch, as many of these seem to, that's good enough for me. Something between $12.31 and $20 sounds good, if the switches below are compatible. I just added one to my Amazon shopping cart to keep a spare on hand. That should assure that the one on my bike (fromHarper's0 lasts the three decades I've come to expect.
https://www.amazon.com/Magura-225-2-Hydraulic-Brake-Assembly/dp/B000WO1Y90
http://www.100moto.com.au/magura-master-cylinder-front-brake-light-switch-fits-model-73-163-225-0128496/
Last, and perhaps least, if anyone would like a dead version of the original switch for an autopsy, I probably have one or two. A PM will get them on the way to you.
« Last Edit: June 19, 2017, 11:30:50 PM by LeRoy »
LeRoy (Bob Sharp)
Rochester, MI  U.S.A.
'83 1000SP (as of Oct. 15)
« Reply #14 on: June 20, 2017, 05:08:03 AM »
Chuck? How is the brake line going to be an issue if you go to the banjo type, (Which I've found to be far more reliable than any of the microswitches.)? If the line has a banjo on the end then surely the hydraulic switch will work. Or have you got a hose with a straight fitting on the end?
Rough Edge racing
« Reply #15 on: June 20, 2017, 05:33:32 AM »
 I converted the troublesome brake light mechanical switches on my 96 Ducati to stud style pressure switches to fit the stock brake line banjo...Also a good time to change brake fluid  :grin:....And one pressure switch failed quickly so I got the chance the brake fluid twice...
« Reply #16 on: June 20, 2017, 06:04:59 AM »
Well, duh! For some reason, I "remembered" it screwing directly into the master cylinder. It's a banjo.. :rolleyes:
Thanks for jogging my memory. <old person shuffling off>
Offline Old Jock
« Reply #17 on: June 20, 2017, 06:33:04 AM »
I've got a pressure switch on the 1000 and one is also on the 1100, that's yet to run
So far on the 1000 its been reliable and not given me any trouble, I changed as I felt the mechanical type setup was fragile and designed by "Michael Mouse Engineering".
The only downside that I've noticed is that unlike the mechanical type which triggered just before the brakes started to operate, the pressure switch operates the brake light a split second later as (obviously) pressure has to be present for the switch to work.
« Reply #18 on: June 20, 2017, 06:53:28 AM »
Oh, and thanks, LeRoy. For $12 and change delivered, that switch looks to be plug and play. I'll drop one in my cart and experiment with it.  :thumb:
Edit: before punching the buy it now button, I looked at the thread and it appears the OEM is M6, not M10. Whew! Almost wasted $12.. :) :)
2017-06-20_07-48-17 by Charles Stottlemyer, on Flickr
« Last Edit: June 20, 2017, 06:59:56 AM by Chuck in Indiana »
« Reply #19 on: June 20, 2017, 08:01:35 AM »
Ok, here's the issue.
2017-06-20_08-53-48 by Charles Stottlemyer, on Flickr
The bottom tab doesn't quite touch the plunger. All I have to do is bend it down a few thousandths until it does. Reliably. :smiley: Then, figure out how to recrimp the switch back together. Maybe some sand blast and metal set epoxy..
King.. this case is closed. Mystery solved. :wink:
« Reply #20 on: June 20, 2017, 08:47:26 AM »
The description for the Magura switch LeRoy linked to is not for the switch, but the entire master cylinder.
13mm-dia. piston
Alloy body master cylinder
Nylon fluid reservoir
Threaded for brake light switch
Outlet thread M10 x 1.0
The "outlet thread" is where the banjo bolt goes, not the switch thread diameter. I'm betting the threaded hole for the switch is M6-1.00 which seems to be some sort of an industry standard.
« Reply #21 on: June 20, 2017, 08:55:41 AM »
I've had at least one pressure switch fail as well.  For what it's worth, the pressure type add a small amount of sponginess to the system too, since it takes a small amount of fluid flow into the switch to actuate it.  Sometimes it's noticeable and sometimes not.
« Reply #22 on: June 20, 2017, 09:10:51 AM »
I have the old one repaired (soldered back together) and working. Maybe it'll last 30 years  :smiley: but if it doesn't I'll try one of the other solutions posted.
Gotta love WG! Thanks all.. :thumb:
Offline normzone
« Reply #23 on: June 20, 2017, 11:53:33 AM »
It's so sexy when you talk like that ....   :evil:
