We don't know your history. Tell us what "...adjusted properly..." means regarding the clutch. Can you see the actuator arm on the transmission? If you pull on the hand lever with just one finger, does that actuator arm move? Can you see if the actuator arm is butting up against any part of the frame or other components?Patrick HayesFremont CA
I've seen a clutch get burned out in a couple minutes when a guy was revving the snot out of the bike while feathering the clutch trying to get the bike up a steep mountain gravel driveway. So, sure, a clutch can be spent at 14,000 miles. It really isn't related to miles as it is to full engagement and how often you start out and shift gears and your shifting technique.Strange that it only happens in 5th gear though. I would think the lower gears put more stress on the clutch plates due to gear ratios if you are doing full throttle accelerations.
I don't know the later bikes at allUsually with me when a clutch starts to slip it manifests itself in top gear (I don't even know how many gears the V7 has)If the set up is similar to the older bikes it's essential that the clutch arm doesn't excert force onto the pushrod when the clutch is engaged (when you are not opertating it). If it does it can lead to premature wear so IF they are similar to the older machines then cable and linkage play is the first point I'd start withJohn
clutch is rooted, might as well put new plates in
Wow. Thanks for all the input and advice guys. I had a chance to look it over today. It did appear a bit gritty around the clutch arm, and I took SmithSwede’s advice and loosened the clutch lever to be sure that there really was not tension in the clutch arm, then I gave the bike a good wash, making sure to clean our all of the grit and funk around the area of the arm. Once dry I sprayed the arm and as much of the cable as I could get to with dry graphite lube while pulling the clutch lever in and out to get to all of the moving bits. Then I took it for a ride and tried to replicate the scenario where it was slipping. It did not slip. Tried it several times, and no slippage. I don’t know it I’m in the clear, but hopeful at this point. I’ll keep an eye on it and see if it comes back. Thanks for all of the education and advice. This forum is great. I generally just lurk to learn a thing or two when I have time. Hopefully I’ll learn enough about these guzzis to be helpful to someone else one day. Oh, I also pulled the rubber plug from the bell housing and stuck my finger in it. There was definitely some wet sooty grime in there. It doesn’t seem oily so much as like wet soot. I wiped it on a white paper towel and it seemed to quickly dry into a dry black spot suggesting that it was wet with water rather than oil. Thoughts?
Im surprised, in my experience once they've slipped a few times they don't come back. Third gear on a hard pull like passing someone is where you can tell if the clutch slips. To do a mineral spirits clutch wash, make a plug out of a toungue depressor like a wedge to plug the rectangle drain hole in the bellhousing. Pull the starter and make a cover for the hole. fill the bellhousing thru the timing hole, I use a compressor& siphon gun stuck in a gallon of Mineral Spirits, about 12 bones at a local Try&save. You can leave the starter on but it may fill with spirits. Work the clutch, rotate the flywheel 180 degrees working clutch, drain, repeat three or so times. Then blow it all out and start it up, work the clutch with no load, build some heat, shut it down and let it dry. I put a clamp on the hand lever to open the plates. The reason I say mineral spirits is because it is a good oil solvent and will not hurt seals. good luck, some times it works well
That adjustment nub on the bottom back of the transmission is a bear to deal with. Using a bicycle spoke wrench is a good approach because it has many small variations in size. Conventional wrenches don't fit well.Joe
Well, should have known it was too good to be true. Felt the clutch slip again. Took a closer look through the timing/inspection hole with a little flashlight, cocking my head awkwardly while shining the light in to try and see what was going on in there, and sure enough when I had my head tilted just right so that I could glimpse the surface of the bell housing near the bottom, it was glistening with oil like Luigi's hair on a Saturday night. I also discovered oil at the seam where the bell housing meets the block. I guess I've got an oil leak in there somewhere.... Either the main seal or the gear box seal, I take it... Ugh.
If we knew roughly where you were located we could maybe give directed help
Well that's a fur piece from me. the good news is its fairly easy, theres a lot to it but if you are a mechanical wizard, its just disassemble and reassemble, paying attention to detail
