Author Topic: Griso clutch master cylinder push rod  (Read 5468 times)
Offline Trogladyte
  • Location: South London - home of the world's best football team.
« on: February 08, 2020, 08:50:04 AM »
Is that what this thing is called? It's the adjustable pin in the clutch lever that actually operates the hydraulics. Mine was coming loose, and I was getting clutch drag and trouble getting neutral at a standstill. So I took it all apart, adjusted it and re-tightened the grub screw to lock it. It's all working - for now. But the threads on the pin are very worn. and the post in the lever that the pin screws into is aso very worn indeed. There's a worrying amount of play - it's flopping about like a sausage in the Mersey Tunnel. I've greased it up, which should slow the wear, but I would really like a new one.
Has anyone got a part number, or any other inspirational ideas to identify and locate this thing, which appears to be made from 100% unobtanium. Can't see it on the Fowlers microfiche. it must be a Brembo part, right? I suspect it's used on a whole range of European bikes. But what is it, and where can I get one? I'd rather not buuy a whole lever, as I have a couple of good spares. One has a push-rod, but someone has lost the grub screw, and used epoxy to keep it is place. Yawn.
Re: Griso clutch master cylinder push rod
« Reply #1 on: February 08, 2020, 09:07:34 AM »
They come with epoxy on the grub screw, new on bike. Others have done this, I did a Griso once BUT I had the parts, don't know where boss got them.
Try a search
« Last Edit: February 08, 2020, 09:08:59 AM by guzzisteve »
Online RinkRat II
  • Lake Powell AZ
« Reply #2 on: February 08, 2020, 09:28:24 AM »
  Looks like the lever assy is available... 981046 Silver 114.00 ...AP8118659  Gold...112.00  Cadre cycle shows the breakdown in their parts Fiche
     https://cadrecycle.com/
      Paul B :boozing:
Offline Trogladyte
« Reply #3 on: February 08, 2020, 11:35:17 AM »
      Paul B :boozing:
Thats the same diagram as Fowlers use. The pin isn't shown, so difficult to see if it is included with the lever assembly. Here's the part.
« Last Edit: February 08, 2020, 11:36:06 AM by Trogladyte »
Online RinkRat II
  • Lake Powell AZ
« Reply #4 on: February 08, 2020, 12:26:49 PM »
       As you say, it doesn't show it and you may have to search Brembo's site to find it. Know a good machinist? Plan B.
       Paul B :boozing:
Moto
« Reply #5 on: February 08, 2020, 12:38:27 PM »
Check eBay for item number 274166448077, clutch lever pressure pin griso.
I just bought one from the same seller.
EDIT: The item is supplied with the parts shown in the photo above, for $22 plus $6 shipping from Germany. It may have taken a couple of weeks to arrive. I wasn't in a hurry to get it, since I bought it to have as a spare.
Moto
« Last Edit: February 08, 2020, 03:53:34 PM by Moto »
Offline Trogladyte
« Reply #6 on: February 08, 2020, 05:09:38 PM »
Moto
Thanks. I just bought the last one they had in stock. It feels like a lot of £$£$ for a tiny little part, which is hardly precision engineering. But it is critical, and I'm glad to be getting a new one!
« Last Edit: February 08, 2020, 05:56:38 PM by Trogladyte »
Offline Charles
  • Guzzi goodness
« Reply #7 on: October 26, 2021, 10:12:31 AM »
I know this thread is a bit old but can anyone provide info for a supplier (website) of this pin/plunger assembly. Trying to find the same. No luck on ebay.
Thanks.
Offline gpranzo
« Reply #8 on: January 24, 2025, 03:49:13 PM »
Gotham Cycles has them for about $40. Expensive but well made.
Moto Guzzi Griso 1200 Norge Breva Brembo Clutch Lever Pushrod Push Rod Paddle. These  will work  for Griso and Stelvio.
« Reply #9 on: January 25, 2025, 04:04:05 PM »
Linky: https://www.gothamcycles.com/Clutch/ducati--aprilia--moto-guzzi-brembo-clutch-lever-pushrod-and-barrel-with-paddle.html
Offline Lee Bruns
« Reply #10 on: January 26, 2025, 11:17:08 AM »
Yep. I recently made one of those on the lathe for a local fellow.  Silly little pin.
Offline kidsmoke
« Reply #11 on: January 26, 2025, 11:35:37 AM »
Additional link. I took delivery just yesterday.
https://www.wemoto.com/parts/aa0557
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
