Author Topic: getting mineral spirits inside transmission?  (Read 3628 times)
Offline amamet
« on: May 12, 2020, 02:27:43 PM »
mineral spirits works great to clean oily greasy engines and parts. my question is, if im going to clean an assembled transmission or engine, specifically a transmission though, is there a problem if mineral spirits gets inside?  ill assume not, but im not sure, hence checking with you all.  ill try not to get anything in but shit happens
thx again
allen
Online RinkRat II
  • Lake Powell AZ
Re: getting mineral spirits inside transmission?
« Reply #1 on: May 12, 2020, 03:07:05 PM »
    The only thing to be careful of is the seals, Mineral spirits can cause swelling of some material but if your careful, a little inside won't hurt just flush it out with oil.
      Paul B :boozing:
Online moto-uno
« Reply #2 on: May 12, 2020, 03:12:32 PM »
 ^  +1 , Peter
Offline Groover
    • Scooteropolis
« Reply #3 on: May 12, 2020, 04:37:12 PM »
Yup, I'd also be worried about the seals. Reason I also think so is that I used mineral spirits to put the grips on, and makes rubber feel slimey when wet then stick like crazy once dry, so it does something probably not healthy to seals.. maybe.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
jwinwi
« Reply #4 on: May 13, 2020, 12:29:20 PM »
Use Diesel; it's cheaper and won't harm seals.
« Reply #5 on: May 13, 2020, 12:37:35 PM »
I got a Gas Gas full of water one time and douched it out with diesel. No harmful after effects.
« Reply #6 on: May 13, 2020, 03:23:59 PM »
 I am a little curious about why a working transmission needs to be flushed out ?
« Reply #7 on: May 13, 2020, 03:33:36 PM »
Convert?
Online RinkRat II
  • Lake Powell AZ
« Reply #8 on: May 13, 2020, 03:39:03 PM »
       I gathered he was cleaning the outside and was concerned with some of the cleaner getting inside. :popcorn:
        Paul B :boozing:
« Reply #9 on: May 13, 2020, 03:43:17 PM »
I think the original poster was concerned about errant mineral spirits doing bad things, not that he was going to wash the trans internally.
Offline amamet
« Reply #10 on: May 13, 2020, 03:46:45 PM »
yup, John, that was the case,  was just going to give it a cleaning to get of heavy grime and was concerned about getting some inside
« Reply #11 on: May 13, 2020, 03:50:43 PM »
Convert?
 Good question  :thumb:
 If this is a 4 or 5 speed what heavy grime would there be to clean out ?
Offline delrod
« Reply #12 on: May 13, 2020, 08:40:33 PM »
Am I the only one who wants to know how the gasgas got full of water?
Doug in Pittsburg KS
2003EVT
« Reply #13 on: May 14, 2020, 12:34:15 AM »
No, I want to know what is a gasgas?
« Reply #14 on: May 14, 2020, 01:16:08 AM »
 It is after all Race Bacon
 Modern Spanish trials bike
« Reply #15 on: May 14, 2020, 02:22:14 PM »
2 liter jug at HomeDepot.
