Author Topic: Petcock question  (Read 2396 times)
Petcock question
« on: May 14, 2020, 06:39:18 PM »
I'm going to change the electric petcock on my 2001 jackal to a manual.  I'm thinking it's a straight swap but starting to think I remember someone saying maybe the outlet of the manual is smaller and thus may not flow enough fuel.  I'm sure one of you folks can assist.  Thank you in advance.
Re: Petcock question
« Reply #1 on: May 14, 2020, 06:43:21 PM »
The pump has pretty good suction, it will even suck the electric valve open.
Why not do a flow test on your manual one.
FUEL CIRCUIT  From the Efiman document
The electric pump draws fuel from the tank and sends it through a filter to a manifold equipped with feed branches to the injectors. A pressure regulating valve maintains steady fuel pressure by bleeding excess fuel back into the tank.
Electric fuel pump
This is a roller positive displacement pump with the motor submerged in the fuel. The motor is a permanent magnet carbon brush type. When the impeller is turned by the motor, the fuel is moved from the intake orifice to the delivery port. The amount of fuel is determined by the rollers which adhere to the outer ring while the motor is turning. The pump has a check valve to prevent the fuel circuit emptying when the pump is not running. It is also equipped with an overpressure valve which short-circuits the delivery when the pressure is over 74 psi to prevent the pump motor from overheating.
Delivery: 26.5 gal/hour at 44 psi with 12V power supply. The pump draws about 4.5 amps.
Note: We recommend strict cleanliness whenever the hoses are installed or removed, or when work is done on the system.
You could also see how much current the pump draws Before/After it will go up if the pump is struggling, poke your ammeter into the relay socket, I would guess anything below 5 Amps is ok, it will draw nearly 9 Amps if the filter plugs off. Liquid cooled pump lol
Personally I like the electric petcock but thats just me.
« Last Edit: May 14, 2020, 06:56:37 PM by Kiwi_Roy »
« Reply #2 on: May 14, 2020, 06:50:07 PM »
I did that years ago. I forget which petcock and where I got it, but it was straight bolt on with no flow issues.
It was a model that uses a valve that screws shut from the bottom, not one of those 1/4 turn shut off valves.
« Last Edit: May 14, 2020, 07:40:55 PM by Kev m »
« Reply #3 on: May 14, 2020, 07:06:01 PM »
Thank you fellas.  Adam Zuckerman, who used to be at Hamlin's before he moved to CA a while ago also got back to me with the same info as kev.
You guys rock............... .......
Offline moto
  • Fear the deer!
« Reply #4 on: May 14, 2020, 07:06:24 PM »
I made some calculations some time ago when swapping in an electric petcock for the manual one on my T3. Along the way I measured the flow through the manual petcocks and calculated the flow needed to support certain assumed mpg values at particular speeds. I suppose some of that could be of help in comparing your measured flow with my results. So, here you are (click to enlarge):
Moto
850 T-3
Griso 1100 corretto
Offline BillinPA
« Reply #6 on: May 14, 2020, 07:10:17 PM »
The one Charlie listed from Mgcycle is what I have on my EV.  Works great,
« Reply #7 on: May 14, 2020, 07:42:34 PM »
Yup that looks like what I used too.
Only complaint is it isn't as fast and easy to shut off as a 1/4 turn valve type, but there isn't much of a reason to turn it off often.
« Reply #8 on: May 14, 2020, 09:11:10 PM »
THX again to all.
Offline s1120
« Reply #9 on: May 15, 2020, 06:43:33 AM »
I just swapped the MG cycle one onto my cali stone. Hose outlet was the same size. I did need to replace the hose though, becouse the angle of the barb on the petcock was different then the electric one. The old hose was too short. The valve on mine works a little hard.. But it is brand new. I would like a basic 1/4 turn one.. but im happy with this one.
Paul B
« Reply #10 on: May 15, 2020, 08:00:21 AM »
While the tank is off I'm going to replace all the fuel hoses anyway.  It's past time for this.
Online JJ
« Reply #11 on: May 15, 2020, 10:06:35 AM »
About a year ago, I bought a manual petcock from MG Cycle, (about $40), and installed it on my Centauro.  No issues.... :thumb:  The main reason is that if you are out on a road trip, and the solenoid FAILS on the electronic petcock...you are dead in the water! :shocked: :rolleyes:
 :thumb: :thumb: :thumb:
Offline Roebling3
« Reply #12 on: May 15, 2020, 11:21:12 AM »
www.herdan.com   610-562-3155   Port Clinton, PA.
Could be worth a look/call. Good folks for fuel tubing, petcocks, etc. R3~
« Reply #13 on: May 15, 2020, 11:23:40 AM »
Not necessarily - as noted above, a healthy fuel pump will draw fuel through it. Not a good situation, but it will.
« Reply #14 on: May 15, 2020, 01:04:14 PM »
I haven’t had many pets over the journey, but one of those sounds interesting... Do they come with much baggage ?  :popcorn:
« Last Edit: May 15, 2020, 01:06:49 PM by Huzo »
Offline s1120
« Reply #15 on: May 15, 2020, 04:48:08 PM »
I replaced a lot of the ones on mine. i wasnt going to do that one though. :)  It needed to be done, becouse the old one leaked.
Paul B
Online JJ
« Reply #16 on: May 16, 2020, 07:38:02 PM »
I just HATE things that LEAK...especially on a motorcycle!!  New MG Cycle Fuel Valve coming!! :thumb: :cool: :wink:
Offline s1120
« Reply #17 on: May 17, 2020, 07:01:43 AM »
I should be more clear. It leaked past the valve. Not on the ground. Normally it wasnt a big issue, but every time I pulled the tank, fuel was leaking out of it. That along with the chance of failure, made me bring it up toward the top of the to do list last winter.
Paul B
Offline charlieb / ma
« Reply #18 on: May 17, 2020, 01:15:45 PM »
in a pinch while on the road I used a bolt(13mm??). I split the electric petcock and just used the bolt with a sealer. Used it like that for a couple years before going to back to the electric version and eventually switch it out to a manual.
Charlie Brackett
Rockport, MA
Online JJ
« Reply #19 on: May 24, 2020, 11:13:47 AM »
Well, I installed my third MG Cycle manual fuel valve ("petcock") yesterday.  :thumb:
I Flogged the Centauro for a 50 mile shake down run...no leaks last night or this morning.   "Dry as a bone...Ahhhhhhhh!!!!:" :thumb: :thumb: :thumb: (As it should be...).  Hopefully this one will last more than 5 months.
I wish PINGEL made a petcock for Moto Guzzi...but they don't...(Harley's only).  Those are some high quality fuel valves!
Online JJ
« Reply #20 on: May 26, 2020, 09:50:01 AM »
Day 3 - - and still no LEAKS!!  (*** Happiness!! ***) :smiley: :smiley: - - We'll see how long this one lasts... :shocked: :huh:
