Author Topic: 3 more transmission questions  (Read 1049 times)
Offline amamet
« on: May 23, 2020, 02:08:14 PM »
first off:
1- what the heck is this?  left over extra material? it fell out of the shift drum as I was installing the rod. its about 5mmx1.5mm
2- im rebuild 1 transmission from 2 for my eldorado, one transmission is from the eldorado one from a g5.  the shift drums are opposite each other.  if I use the g5 drum will my shift now be reversed? (gp shift)
3- should I use the later shift return mechanism or the original
Re: 3 more transmission questions
« Reply #1 on: May 23, 2020, 03:39:42 PM »
1. Maybe left over from punching/machining the shift drum and never cleaned out. I'd guess where the neutral bump goes into the drum.
2. Original shift pattern was "reverse"/"GP", the G5 drum will make it "normal".
3. Use the later shift selector.
Offline amamet
« Reply #2 on: May 23, 2020, 05:43:08 PM »
thx Charlie :) I may just keep it gp style. ive always liked that on my ducati 750gt
