Author Topic: 77 Lemans - Extensive Fettle  (Read 71883 times)
Offline Motorad64
Re: 77 Lemans - Extensive Fettle
« Reply #60 on: October 19, 2020, 09:41:36 PM »
Looks great!  Where'd you source your plastic gauge housing?  Yours has the later ignition hole nicely blocked off like the originals.   Haven't been able to find one to replace my cracked original.
« Reply #61 on: October 19, 2020, 10:28:45 PM »
I used the commonly available housing,  filed the 2 notches for the ignition switch off to make the hole round, and used a piece of the cracked housing as a donor to make the round filler.
« Last Edit: October 19, 2020, 10:30:31 PM by Dave Swanson »
« Reply #62 on: October 20, 2020, 11:16:34 AM »
So close!    I wont be able to ride it until Spring due to being only 2 weeks since my hip surgery.  I do want to at least start it though.
« Reply #63 on: October 20, 2020, 11:47:08 AM »
 :thumb: :thumb:
« Reply #64 on: October 20, 2020, 12:38:06 PM »
Here's a summary of work done.
ENGINE
The engine was partially disassembled for inspection and found to be in very good condition.
Rear main seal replaced, and gave the exterior a detail.
CLUTCH
Replaced clutch and upgraded to the deep spline.
TRANSMISSION
Disassembled for inspection and found to be in good condition.
Rear and front main seals replaced.   Front seal had been leaking.
DRIVELINE
U-Joint replaced and all spline drive shaft and couplings.
U-joint carrier bearing replaced.  The bearing felt rough and upon removal found the inner race had 3 cracks.
Rear drive spline and mating drive spline on rear wheel replaced, along with new cush rubbers.
BRAKES
All 3 brake rotors were refinished by TrueDisk.
All brake pads replaced with "best" Brembo carbon ceramic pads.
New front master cylinder rebuild kit.
Brake lines replaced with black steel braided lines.
MISCELLANEOUS
Damaged instruments repaired by Palo Alto Speedometer Service
Damaged instrument cluster housings replaced
New wiring harness from Greg Bender.  A thing of beauty!
Fresh paint by PaintWorks.  Craig did his usual amazing work including the satin black finish on the fuel tank.
New exact reproduction seat from Guzzibits.
All rusty hardware was zinc plated at Manner Plating (local).
Fresh Avon AM 26 RoadRiders and converted to tubeless.
Fork seals and many other rubber bits replaced.
jwinwi
« Reply #65 on: October 20, 2020, 01:10:16 PM »
Nice work Dave! Looks *almost* too nice to ride...
« Reply #66 on: October 21, 2020, 05:08:26 PM »
« Reply #67 on: October 21, 2020, 06:27:24 PM »
Nice job Dave! Looks fantastic  :thumb:
Online Turin
« Reply #68 on: October 21, 2020, 10:54:33 PM »
Wow that is pretty. I can't have my stuff that nice !
1985 Sidlow Guzzi
« Reply #69 on: October 26, 2020, 07:29:00 AM »
Playing around with Iphone camera.
« Reply #70 on: October 27, 2020, 07:39:38 AM »
I made a big assumption that the Dyna III was in running condition when I tore the bike down.  I did not start the bike before teardown.    I have now found that the ignition module has a bad right channel.   I spent some time eliminating other components such as the pick ups or coils before I called Dynatek and ordered a new module.  I did notice that mount position of the module was fouling against the tank.  I am not sure if that helped the failure along, but it wasn't good.
I am mounting the module on one of the tubes in the battery compartment.  It is hidden behind the side cover.
I have also decided to add one of Greg Bender's relay solutions to this bike to protect the un-obtanium switchgear.
« Last Edit: October 27, 2020, 07:49:17 AM by Dave Swanson »
« Reply #71 on: October 27, 2020, 08:30:48 AM »
As long as the Dyna module has good air flow and a good ground, that location will work.
The relay solution is definitely a good idea, especially for the ignition circuit.
« Reply #72 on: October 31, 2020, 08:25:35 AM »
New Dyna III module installed last night.   Now sparking on both!   I should be able to start it this weekend.
Also I installed Greg Bender's Relay Solution this week.  It works perfectly.  No surprise there.
« Last Edit: October 31, 2020, 08:27:13 AM by Dave Swanson »
« Reply #73 on: November 02, 2020, 02:55:58 PM »
Running very nicely!  I decided to replace the old throttle cables.  Road test should happen later this week.
https://youtu.be/oeQyb_YnRGs
« Reply #74 on: November 07, 2020, 07:30:37 AM »
The Lemans is 100% ready for a road test, and we have a spurt of almost summer like weather to get it done.   There are 2 things holding me back.
First is my hip.  I am sure I could probably pull off a short road test without harming anything, but there is a small voice in my head saying that 5 weeks from my hip surgery is too soon.
Then the weather will be changing soon.  At this point the bike is ready for the winter.  The gas tank hasn't had fuel as I have been using a fuel bottle for tuning, and I have already drained and dried the float bowls and fuel lines. If I was to gas it up I would have to go through the fuel emptying process again.
The Lemans will have to wait until Spring for its road test.
« Reply #75 on: November 07, 2020, 03:03:55 PM »
Wise decision!
The bike looks and sounds great, another great restoration!  :bow:
What is next in the pipe line for winter?
 :popcorn:
« Reply #76 on: November 07, 2020, 03:55:41 PM »
Wise decision!
 :popcorn:
The T3 California is next up.    Then I will get to 55 Triumph T110 that has been waiting patiently.  Then the 64 XLCH, 65 BSA, 73 CL350, couple of chopper projects....
« Last Edit: November 07, 2020, 03:57:17 PM by Dave Swanson »
« Reply #77 on: November 07, 2020, 06:07:13 PM »
Wow, you got a long list, excellent!
 :popcorn:
Online Turin
« Reply #78 on: November 07, 2020, 07:48:12 PM »
Yikes! I'd go nuts with a back bench of projects like that.
1985 Sidlow Guzzi
Offline s1120
« Reply #79 on: November 09, 2020, 07:39:39 AM »
Even though thats a tough decision, its a good one..  Spring will come, and you can enjoy it then. She looks amazing, and sounds great!
Paul B
Offline leroy_can
« Reply #80 on: January 19, 2021, 07:22:42 PM »
 HI Dave, I figured out who the Les P. you mentioned is, major compliment thank-you. Every time I see one of your threads it is yet another awesome restoration of some very desirable Guzzi and although you only list Guzzis on your bikes owned list  I think you have a much more extensive collection. When I pulled my LMIV down last week I found the same 6 cracks in the inner race as you and that is the second time for me. I have never had a tight to install u-joint and they were always quite loose on disassembly. I came up with a mod to the swing arm so I can assemble the bearing to the joint and then install it all in the swingarm. I will do a story on it once I take some photos.
1973 XLCH cafe Shovester #1
1973 XLCH cafe Shovester #2
1971 Homemade cafe '08 XB12S motor 71 CH frame
2002 Buell M2 Cyclone
1987 LMIV SE 1400 conversion in progress
Offline Scout63
« Reply #81 on: February 13, 2021, 10:27:03 PM »
I’ve been remiss in looking at build threads.  Great freshening up on the LM. I can’t wait to read about and hear it run this Spring.
Ben Zehnder - Orleans, MA USA
« Reply #82 on: April 03, 2021, 11:58:47 PM »
I had my first opportunity to give the Lemans its road test.  I am happy to report that the bike functions flawlessly.
I was wondering if it would live up to the hype.  It does!  I am amazed how powerful this 850 cc is in Lemans spec.  I wonder how it would do against the new V7-850?   It easily has the best sound of any bike I have ever ridden.
« Last Edit: April 03, 2021, 11:59:22 PM by Dave Swanson »
« Reply #83 on: April 04, 2021, 08:59:26 AM »
« Reply #84 on: April 04, 2021, 09:34:08 AM »
Not quite Charlie!  The left petcock is leaking.  I think I will put new ones in.
« Reply #85 on: April 04, 2021, 07:15:57 PM »
A 45 year old design that still looks great today!
« Reply #86 on: April 05, 2021, 07:04:45 PM »
This one is back for further sorting - 30 (illegal) miles back in January weren't enough to work out all of the bugs. Engine built by Manfred Hecht (992 cc, unknown cam, ported and dual-plugged heads, lightened flywheel, Carillo rods, titanium valve spring retainers, PHM 40s), Charley Cole did the transmission and rear drive. Staintune exhaust. Ohlins shocks. It isn't pretty, but it runs super strong.
« Reply #87 on: April 10, 2021, 10:22:07 AM »
Here is a post carb balance rev up video.
https://youtu.be/eFpi__xGu_U
The Harmonizer is hands down the sllickest and easiest balance tool I have ever used.
