Author Topic: 77 Lemans - Extensive Fettle  (Read 70356 times)
Re: 77 Lemans - Extensive Fettle
« Reply #30 on: July 31, 2020, 06:11:50 PM »
I always love having the wheels done, done.  It feels like the project is really getting somewhere.
New rubber, drive spline and cush rubbers,  disks ground by TrueDisk, and set up for tubeless.
« Reply #31 on: August 31, 2020, 07:54:17 PM »
As I teardown the engine for inspection I have had my doubts, thinking that I should just leave it alone.  But since it is out and on the bench I am going to go through it to satisfy my curiosity and to make sure all is right with the world.
I found a problem when removing the tachometer drive.  The tach drive appeared to have only one washer!  The pocket was missing the drive washer.
I checked everywhere for the washer, and then upon looking closely the one washer did look a bit thick!
I am happy I solved the mystery of the "missing" hard washer.  Since this engine was run very little after it was gone through the lower pocket in the outer cover still looks serviceable.
Quite a pleasant surprise was to find this!!  A nice set of aluminum timing gears.
« Reply #32 on: September 05, 2020, 06:13:15 PM »
Engine inspection complete.  The rear was seal replaced as a precaution as long as the engine was out.
I also upgraded to a deep spline clutch with the good bonded, and riveted clutch plates.
Going back together.  Next is going through the transmission.
I am having my right hip replaced October 5th, and hope to have most of it together before the saw bones comes after me!!
« Last Edit: September 05, 2020, 06:14:46 PM by Dave Swanson »
« Reply #33 on: September 05, 2020, 07:48:25 PM »
« Reply #34 on: September 06, 2020, 05:05:04 PM »
I disassembled the transmission, scrubbed the housings, replaced the front and rear main seals.  The front seal had been leaking quite a bit.  Bench checked the shifting before joining to the engine.  It seems to shift quite nicely.
Now it is time to get serious!!
« Reply #35 on: September 07, 2020, 12:55:45 PM »
Offline Klinkhammer
  • 2024 Board Donor
« Reply #36 on: September 08, 2020, 01:02:35 PM »
Oh, this is probably my favorite phase of a rebuild. Everything is still perfect -in your mind. Soon all the compromises start...
850T Endurance racer lookalike 1974
992 Le Mans III Agostini 1983
V1000 ConverT 1976
850 Le Mans II 1979
BMW R1250GS HP 2019
V7 sport 1972 (Sold)
850T3 California 1977 (Sold)
850T 1974 (Sold)
« Reply #37 on: September 09, 2020, 09:05:57 PM »
It is always a nice step in the right direction when the wooden support box comes out and it is standing on it's own.
« Reply #38 on: September 11, 2020, 05:02:33 PM »
It is time to mount the swingarm so I was giving the ujoint carrier bearing a once over.  It felt a bit rough when turning.   When looking at it closely I could see 5 cracks in the inner bearing race!
I had conjured up disaster in my mind that the inner race would fall apart while pounding on it with a long drift and then force me to find a good Tig welder to weld a bar on the outer race in an attempt to save my swingarm.  I then remembered reading Charlie's method of using a blind bearing puller and pushing it out with a press from the other end!  PERFECT!  The collet when expanded kept the broken inner race from coming apart and the bearing pushed out with no drama!
Thanks Charlie, you didn't know it but you saved the day again!   :bow:
« Reply #39 on: September 11, 2020, 07:00:16 PM »
 :grin: Glad my bass-ackwards method of doing things sometimes, helped someone.
« Reply #40 on: September 12, 2020, 08:18:48 AM »
Yes it certainly did.
The carrier bearing is the biggest problem I have come upon that would have become a large problem if I hadn't torn this bike down.  Needless to say I am happy I went the longer teardown route.
So far this has been what I have found.
Rear spline wear beyond my comfort level.
Carrier bearing cracked.
One of the shock studs on the frame had the 8mm bolt hole stripped out.  I was happy to find a 8mm set of helicoils that I stashed away.
Improper washer installation on tachometer drive
Washers missing from  many of the 6mm socket head bolts.
Some bodgy wiring.
« Last Edit: September 12, 2020, 04:36:48 PM by Dave Swanson »
« Reply #41 on: September 12, 2020, 04:35:14 PM »
I made some good progress today.  I always look forward to having it standing on it's own 2 wheels!
« Reply #42 on: September 14, 2020, 08:31:47 AM »
Looking great resting on its own two wheels👍
« Reply #43 on: September 14, 2020, 08:51:48 AM »
I'm hoping to reach that point today or tomorrow on the V7 Sport. Been far too long...
« Reply #44 on: September 14, 2020, 05:38:34 PM »
I bought these head guards awhile back on Ebay.  I think they look pretty good!
« Last Edit: September 14, 2020, 05:38:57 PM by Dave Swanson »
« Reply #45 on: September 19, 2020, 12:59:00 PM »
Brakes are good to go.  Bleeding went well with no drama.  Exhaust back on.  I marvel at the condition of this original exhaust!  I guess spending most of it's life in Arizona, and then post AZ was stored kept in living quarters helped.
« Last Edit: September 19, 2020, 01:05:39 PM by Dave Swanson »
« Reply #46 on: September 19, 2020, 05:11:53 PM »
« Reply #47 on: September 20, 2020, 04:50:01 PM »
The skeleton is now fully formed.  The carbs look like they mean business!
I know the market heavily favors the 77  Ducati 900 SS over a 77 Lemans but I have always very much preferred the MG Lemans.  To me it has it all over the 900SS in the style department.
« Reply #48 on: September 26, 2020, 09:28:23 PM »
Moving right along.   Wiring has officially started, which is always a pleasure with one of Greg Bender's harness sets.
Offline moto-uno
« Reply #49 on: September 27, 2020, 04:03:22 PM »
  Lucky you to have a set of Lafraconi mufflers ( they should've been stock) .
  I'm curious about your tires , it appears the tread pattern is in opposite directions on them ?
  Man that is one sweet looking set of wheels  :thumb: .  Peter
« Reply #50 on: September 27, 2020, 04:46:17 PM »
The tires are Avon AM 26 Roadriders.  Opposite tread patterns depending on front or rear mounting.
I agree, I am lucky to have those period LaFranconis.  They could almost pass for NOS.
« Last Edit: September 27, 2020, 04:49:21 PM by Dave Swanson »
« Reply #51 on: September 27, 2020, 05:39:03 PM »
My Lemans had a bit of an oddity it seems.
Every picture I have seen of an early Lemans has the canted rearward rear turn signal stems.   Like this.
My Lemans has the straight stems.
The only pictorial I have found with the straight stems is the early Lemans parts book.
The finish of my stems matches the finish of the frame so I am not going to worry about changing them.  My theory is that the DOT required them to be within a certain distance from the brake light.  Just my house of defecation  theory.   :grin:
« Last Edit: September 27, 2020, 05:40:28 PM by Dave Swanson »
« Reply #52 on: September 27, 2020, 06:44:20 PM »
My '79 SP had the canted rearward stems, which broke not long after my purchase. Maybe the same thing happened to your Le Mans at some point and the owner just substituted the straight stems which were likely easier to get and cheaper.
Offline berniebee
« Reply #53 on: September 28, 2020, 07:04:23 PM »
Looking great! Those head guards are the nicest ones I've ever seen.
« Reply #54 on: October 12, 2020, 01:20:45 PM »
My rehab is moving along well and feel good enough to spend a couple hours down in the shop.
The throttle and choke cables and apparatus are back in place.
« Reply #55 on: October 13, 2020, 02:21:56 PM »
Before.   Both of the plastic housings were broken and unusable.   Instruments banged up.
After Palo Alto refurb, and new plastic housings.
« Last Edit: October 13, 2020, 02:29:28 PM by Dave Swanson »
« Reply #56 on: October 13, 2020, 05:01:08 PM »
« Reply #57 on: October 14, 2020, 04:26:48 PM »
Moving along
Before
Offline s1120
« Reply #58 on: October 14, 2020, 04:40:21 PM »
Looks amazing!!!!!!
Paul B
« Reply #59 on: October 19, 2020, 08:02:00 PM »
The wiring is complete!  It is ready for a live fire exercise!
https://youtu.be/D6-5CRHhWwU
