Author Topic: Need help identifying a nipple  (Read 2039 times)
GeorgiaGuzzi
« on: July 01, 2020, 09:00:35 PM »
I installed manual petcocks on my Quota. However, there is an unknown nipple that is on the right side of their e tank. In the pic you can see it under the hose. Nothing was attached to it when I disassembled it, so if I need to hook up a hose or plug it off I’d appreciate finding out from you good folks.
Offline skippy
Re: Need help identifying a nipple
« Reply #1 on: July 01, 2020, 09:11:23 PM »
With a thread title like this I am sure you are going to get a lot of traffic. I am sure someone will be along shortly to help out.
Skippy
23 V100 Mandello
20 V85TT
Online bmc5733946
« Reply #2 on: July 01, 2020, 09:15:27 PM »
Air vent for regulator, no hose. Allows atmospheric pressure to one side of regulator diaphragm . In some other applications, mostly automotive, it hooks to manifold vacuum to help control fuel pressure. I have not seen that nipple used on Guzzis.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline bad Chad
« Reply #3 on: July 01, 2020, 09:33:24 PM »
I’ve seen that nipple before, but I can’t remember her name.
GeorgiaGuzzi
« Reply #4 on: July 01, 2020, 09:54:30 PM »
Brian
Thanks very much
Offline TheHungarian
  • ‘13 V7
« Reply #5 on: July 02, 2020, 01:45:01 PM »
Change your nickname to “ClickBait”.   :thumb:
I’m glad I didn’t fall for your shenanigans.
« Last Edit: July 02, 2020, 01:47:06 PM by TheHungarian »
I've owned (at one time or another):
1976 Yamaha MX125
1978 Puch moped
1985 Honda Nighthawk 700S
1993 Suzuki GSX750 Katana
1996 Honda VFR750
2013 Moto Guzzi V7 Stone
« Reply #6 on: July 02, 2020, 01:49:35 PM »
 The technical name for what he is asking about is nipple , what would you have called it ?
Online n3303j
  • Ron Cichowski
« Reply #7 on: July 02, 2020, 02:00:15 PM »
Actually a nipple is a straight pipe fitting with theads on each end (sort of like a hollow stud).
The "extra" connection on the regulator is a barb.
« Last Edit: July 02, 2020, 02:01:18 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #8 on: July 02, 2020, 02:09:08 PM »
 I stand corrected .
 Why am I now hearing the Beach Boys ?
Online n3303j
  • Ron Cichowski
« Reply #9 on: July 02, 2020, 02:12:05 PM »
I stand corrected .
..because you are more fortunate than those of us who are condemned to hear the voices of good & evil battling it out within.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #10 on: July 02, 2020, 02:33:48 PM »
 ^^^ :laugh: :huh: :boxing:
Loop Tonti EV
« Reply #11 on: July 02, 2020, 03:04:58 PM »
Maybe we could refer to it as a "barbed nipple", ouch.
« Reply #12 on: July 02, 2020, 03:10:06 PM »
PIERCED?? :thumb:
« Reply #13 on: July 02, 2020, 03:56:00 PM »
"In plumbing and piping, a nipple is a fitting, consisting of a short piece of pipe, usually provided with a male pipe thread at each end, for connecting two other fittings.
The length of the nipple is usually specified by the overall length with thread. It may have a hexagonal section in the center for a wrench to grasp (sometimes referred to as a "hex nipple"), or it may simply be made from a short piece of pipe (sometimes referred to as a "barrel nipple" or "pipe nipple"). A "close nipple" has no unthreaded area; when screwed tightly between two female fittings, very little of the nipple remains exposed. A close nipple can only be unscrewed by gripping one threaded end with a pipe wrench which will damage the threads and necessitate replacing the nipple, or by using a specialty tool known as a nipple wrench (or known as an internal pipe wrench) which grips the inside of the pipe, leaving the threads undamaged. When the ends are of two different sizes it is called a reducer or unequal nipple."   :tongue:
Offline Motormike
« Reply #14 on: July 02, 2020, 04:29:43 PM »
I could have sworn they usually came in pairs.
Offline Zoom Zoom
« Reply #15 on: July 02, 2020, 05:05:33 PM »
Only if you have two throttle bodies. And well, other unrelated things... :evil:
John Henry
Online Cam3512
« Reply #16 on: July 02, 2020, 05:09:45 PM »
Or "Barbs Nipple"?  But what about Rhonda?
GeorgiaGuzzi
« Reply #17 on: July 02, 2020, 07:36:52 PM »
Lol! Well, I did consider “gas tank thingy” but figured that was worse, if such a thing is possible! 😂
Offline rschrum
« Reply #18 on: July 02, 2020, 10:54:56 PM »
You connect a hose from said niparb to the pressurized side of your forced induction, thus increasing fuel pressure proportional to boost. Keeps your pistons from melting.
15 GRISO
21 streetfighter v4s
24 zx14r 40th anniversary
01 ZRX 1200R
74 Norton Commando
23 Bimota KB4
97 Ducati 916SPS
Central Iowa
Offline dguzzi
  • Sorry, I'm woke so I'll be quiet.
« Reply #19 on: July 03, 2020, 06:05:52 PM »
I wish Mr. Roper was listening to you guys....
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'90 Miata
'16 Mustang
Offline bad Chad
« Reply #20 on: July 03, 2020, 06:19:21 PM »
I still can’t believe no one has posted a pic of a proper nipple yet! :popcorn:
Offline Motormike
« Reply #21 on: July 04, 2020, 01:27:56 PM »
I tried to do that years ago...a wonderful picture of Ann Margret in a shear blouse...it got banned.  :cry:
