Can I remove the speedometer housing on my 83 Cal II
Topic: Can I remove the speedometer housing on my 83 Cal II (Read 1008 times)
T4halo
Gosling
July 15, 2020, 09:38:24 PM »
I have a small leak from my speedometer housing. Can I remove the housing? I know on my Ambassador there is a small bearing that falls out if you pull the housing. The gasket needs to be replaced.
Thanks, T4
7th & 10th SF retired
Antietam Classic Cycle
Happily stuck in the past.
Re: Can I remove the speedometer housing on my 83 Cal II
Reply #1 on:
July 15, 2020, 10:19:37 PM »
There's no gasket. What could drop down is a hardened thrust washer. If you carefully remove the housing while pushing down on the shaft in the center, you can avoid this. A little sealer on the threads of the housing should cure the leak.
T4halo
Gosling
Reply #2 on:
July 16, 2020, 07:34:57 AM »
Thanks Charlie.
Tony
