Author Topic: EV1100 tank removal-Help!  (Read 1275 times)
Offline Burkslaw
« on: August 16, 2020, 06:47:05 PM »
After 2 hours I have determined that the "quick disconnect" fuel fitting is neither quick nor will it disconnect. I'm going to cut the fuel line and use a BMW metal disconnect, or just a brass barb union fitting. Anyone know the ID of the line running from the notsoquick nodisconnector to the Y branch going to each injector? I'm hoping that I can get by with a splice, using FI rated hose clamps.
Any advice would be appreciated. Except any advice telling me that the best way is to use the factory disconnect. That may be met with violence.  Thanks.
Online Tom H
Re: EV1100 tank removal-Help!
« Reply #1 on: August 16, 2020, 07:03:11 PM »
One thing that needs to be done is remove pressure from the fuel line. Lift tank and remove the fuel pump wire connector. Start bike, it will run out in a few seconds.
Once done, I do not have a clear answer. I kinda push it in while holding the outer and then pull off. Maybe someone can give a better explanation of the way the lock works.
Offline balvenie
« Reply #2 on: August 17, 2020, 04:26:08 AM »
I ended up buying a part from www.beemerboneyard. com in 2012 and never looked back.
CODE  cpcqkdiscon1
Chrome plated bras fuel line quick disconnect
Check with their website first tho. The invoice I am going off is 12 yo :grin:
« Last Edit: August 17, 2020, 04:28:05 AM by balvenie »
Oz
04 Cali
