Author Topic: Coolest Guzzi Speed  (Read 1393 times)
Offline SmithSwede
  • I don't want a pickle
Coolest Guzzi Speed
« on: September 05, 2020, 01:06:18 PM »
So I’m thinking the heat generated by an an air cooled engine increases significantly as the load/speed increases.  On the other hand, more cooling occurs the faster the air flows over the fins.  But I bet at some point the lines cross and the increased heat from going faster outpaces the increased cooling from more air flow.  In other words, max cool is not idling (min load; min airflow) nor is it WOT (max load; max cooling).
Does anyone know what steady speed produces the lowest engine temperature on an air-cooled Guzzi?
I’d guess about 40 to 45 mph, but have never played around with a oil temperature gauge or a cylinder head temp gauge.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline moto-uno
Re: Coolest Guzzi Speed
« Reply #1 on: September 05, 2020, 01:30:11 PM »
  Downhill idling in neutral ?  :) . Peter
Offline 1down5up
« Reply #2 on: September 05, 2020, 03:28:11 PM »
Lowest ridable rpm in top gear....
Offline Guzzi Gal
    • Sonoran Sunriders, YouTube
« Reply #3 on: September 05, 2020, 04:12:56 PM »
Whenever the ambient temps are below a helmet baking 115? :evil:
Actually, the coolest speed is whatever speed you happen to be going on a Guzzi because it is the coolest thing on the road.
« Last Edit: September 05, 2020, 05:44:53 PM by Guzzi Gal »
"Velvet" '16 Honda CTX 700,
"Miri" and Mori"
« Reply #4 on: September 05, 2020, 07:07:21 PM »
The koolest speed is whatever speed you are going at 4200 rpm. For whatever reason, that (to me) seems to be the sweet spot on Guzzis.  :smiley:
As for when is is running the coolest? I don't care. I've *abused* a Guzzi and it just shrugged it off.
Offline Murray
« Reply #5 on: September 06, 2020, 02:34:38 AM »
Why have the motor running?
Offline chuck peterson
« Reply #6 on: September 06, 2020, 07:03:26 AM »
75.0 for a small block
84.9 for the V9
94.9 for v1000
110.0 for the V11/Breva
120.0 for the Sport
140.0 For the big Cali!
 :popcorn:
How’d i do?
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline s1120
« Reply #7 on: September 06, 2020, 07:40:03 AM »
Mine runs so cool at pretty much any speed...  But that being said, I would say in 3 rd, or 4th gear with the engine running about 4k rpms would be pretty close to best engine load, and wind speed..  5th gear you would have a lot more load from wind resistance, and 1st, and 2nd you would be going a lot slower so less air movement.
Paul B
Offline Zoom Zoom
« Reply #8 on: September 07, 2020, 08:59:34 AM »
Going West on the Going To The Sun Highway, I coasted from the Logan Pass Visitor Center to the bottom engine off, 13 miles. (Glacier National Park for those that don't know.) One of my most memorable experiences. I did spend a lot of time on the brakes.
John Henry
