Author Topic: Breva 1100 battery replacement  (Read 2324 times)
Offline Neil
« on: September 24, 2020, 02:19:10 PM »
      Have to replace the battery in the bike. Doing a search here, looking at previous posts on the subject of battery replacement can leave one more confused than before. Sometimes you CAN have too many choices.  Plus some of the threads were from a few years ago, maybe newer,better choices exist, or some attitudes toward newer technology has changed.
      I expect to keep the bike for a long time, as I'm very happy with it , it checks all the boxes.  What say the collective wisdom here? Thanks in advance.
Re: Breva 1100 battery replacement
« Reply #1 on: September 24, 2020, 02:35:15 PM »
I know Motobatt last a long time, some friends have been using them for years.
Offline bad Chad
« Reply #2 on: September 24, 2020, 03:06:38 PM »
 Don’t get a Bikemaster,  short life from two in a row.
Yusa good but pricey.
I’m trying a Chrome.  Made in Taiwan with a good warranty shipped to my door for $50.
Offline Bisbonian
  • Living the Dream
« Reply #4 on: September 24, 2020, 03:40:10 PM »
I hated the Motobat in my 1200 Sport. The little adapters would loosen up and make for a bad connection. If the connections provided allowed for no adapters to be used then it would be much better.
Offline Huzo
« Reply #5 on: September 24, 2020, 04:16:49 PM »
You can chuck the adapters away and screw straight into the terminal with the use of a spacer.
Offline moto-uno
« Reply #6 on: September 24, 2020, 04:55:40 PM »
 Have 3 different Guzzi's , all have the privilege of using Yuasa's , the gold standard ! I've jump started my car (and wife's PT cruiser with the
20 amp and 24 amp batteries) . They really are excellent . Yep and they cost . Peter
Offline Huzo
« Reply #7 on: September 24, 2020, 05:03:02 PM »
Yep..
I bought a new one in Denmark 2016 for my Norge and it’s still fabulous.
Offline flower_king001
« Reply #8 on: September 24, 2020, 05:04:03 PM »
I use nothing but a Yuasa in my Breva 1100.
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline bad Chad
« Reply #9 on: September 24, 2020, 05:42:44 PM »
I have purchased two Yusa batteries, and they worked as expected.   If you want to be sure and don’t mind paying a premium , then Yusa is the way.
« Reply #10 on: September 24, 2020, 05:50:24 PM »
In total agreement with you.  I generally got four full riding seasons out of a Yuasa.  The only one that didn't fortunately kicked the bucket in less tha one year, and the dealer called Yuasa and got me a new one under warranty, with no proration for the time (9 months) I used the battery.
This is the Yuasa that worked in my 12S and Griso 8vSE.  Double ck, but probably the same as the battery used in the B11.
Yuasa YTX20CH-BS
12V – 18AH – 270 CCA (cold cranking amps)
Bob
Offline Neil
« Reply #11 on: September 24, 2020, 05:59:54 PM »
Thanks for the replies. Sounds like all the suggestions so far have been for a lead-acid type battery. What about the AGM's or lithium type batteries? Yeah, I know - another can of worms.
« Reply #12 on: September 24, 2020, 08:57:49 PM »
Seems all of the suggestions so far have been AGM type.
« Reply #13 on: September 24, 2020, 09:06:53 PM »
Almost all batteries are AGM these days Absorbed Glass Mat I think it stands for.
I would go Yuasa.
Pizza Guzzi
« Reply #14 on: September 24, 2020, 09:47:40 PM »
I replaced the ancient Yuasa in my B12 with another Yuasa.
I don't think anyone ever regretted fitting a Yuasa battery.
Offline bad Chad
« Reply #15 on: September 25, 2020, 02:12:40 PM »
Yes, all mentioned are AGM.  I wouldn’t go with Lithium, more of a headache than a benefit for this motorcycle.
« Reply #16 on: September 25, 2020, 05:26:54 PM »
Note that this model Yuasa was the OEM battery that came with my 1200S and 8vSE .
Yuasa YTX20CH-BS
If you replace with this identical Yuasa battery, you may want to ask the shop where you purchase it to:
- add the acid (these don't come with acid or pre-charged.)
- place on the correct battery charger per Yuasa's instructions.
- charge for recommended interval before installing.
Bob
« Last Edit: September 26, 2020, 07:28:06 AM by ohiorider »
Offline old head
« Reply #17 on: September 25, 2020, 08:28:59 PM »
well, my OEM Yusa lasted about 6 years.
I bought a Shorai lithium, cranked faster and much lighter, but anything below 60 and it takes awhile to start, just clicks.
if below 50 it will have to be jumped off.  Shorai did replace the battery at the 2 year mark, no charge dead cell.
I bought a Chrome 2 years ago, and it wouldn't start it at anything over 50 degrees, rode it back from Dallas in 40 degree weather and had to push start it 3 times.
got home and replaced the wire from solenoid to relay, replaced relay, ran a new hot wire from battery to relay.  Not much better, just clicks.
put in old Lithium battery and it cranks.  Not impressed with Chrome, maybe I got a bad one, who knows.
the Shorai is running on 9 years old and it will crank it fine unless its below 60.
I will be going back to a AGM battery when i replace the Shorai battery.  probably be a Yusa as it never let me down before it failed, cranked in any weather.
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
