Author Topic: Late to the rollerization party...but I have a question  (Read 3586 times)
Offline GerryL
« on: January 11, 2021, 02:09:19 PM »
Hi all!  So I have a low mileage 2012 Stelvio, original flat tappet engine.  Decided to swap to roller tappets before there is an issue.  I got the kit last summer, just getting to it today.  The bottom of the cam box is quite a bit different.  My question is with regard to the sealing between the bottom of the cam box and the top of the head around the spark plug hole.  My cam box has a sleeve with an o-ring groove in both the head and the cam box.  The new cam box has no o-ring groove.  What is the proper assembly?  I do have a set of o-rings in the kit.  Do I just remove the sleeve from my old cam box, insert it in the head, put an o-ring around it and sandwich it between the cam box and head?  Please see photo.
« Last Edit: January 11, 2021, 02:50:16 PM by GerryL »
Re: Late to the rollerization party...but I have a question
« Reply #1 on: January 11, 2021, 03:28:44 PM »
You need the newer style valve covers w/flat rubber seal if you have a cambox w/o a tube oring groove.
Pretty sure on this but let me check.
Edit:    Got it wrong, if cambox/rocker tower has no oring groove it is for non-floating covers.
« Last Edit: January 11, 2021, 06:34:39 PM by guzzisteve »
Offline lucky phil
« Reply #2 on: January 11, 2021, 03:55:39 PM »
Dont know if it's an issue with the image but the cam in that roller lifter assembly looks cooked. Is this a new kit?
Ciao
« Reply #3 on: January 11, 2021, 04:06:05 PM »
That's the black grease that comes on cam.
Offline GerryL
« Reply #4 on: January 11, 2021, 04:08:03 PM »
Yes, new kit.  And yes, it's smeared with grease or moly; something for initial lube.
Offline GerryL
« Reply #5 on: January 11, 2021, 04:13:28 PM »
And I’m glad I got the kit; here is a photo of one of the  tappets.  16000mi
« Reply #6 on: January 11, 2021, 04:16:22 PM »
Which kit?
Offline lucky phil
« Reply #7 on: January 11, 2021, 04:18:55 PM »
Ah, got it thanks. I thought that something was amiss as what appeared to be damage was also on the base circle.
Ciao
« Last Edit: January 11, 2021, 04:22:01 PM by lucky phil »
Offline lucky phil
« Reply #8 on: January 11, 2021, 04:19:51 PM »
Seems they all go that way eventually.
Ciao
« Reply #9 on: January 11, 2021, 04:34:30 PM »
Does the new design also need something under the cam box to seal it to the head, since there is no tube?
Offline Rolf Halvorsen
« Reply #10 on: January 11, 2021, 04:41:28 PM »
According to my notes - it is the A-kit that will be correct for your 2012 Stelvio.
Rolf
« Reply #11 on: January 11, 2021, 04:43:32 PM »
The A-kit has part No: GU1002060
Rolf
Offline lucky phil
« Reply #12 on: January 11, 2021, 04:54:47 PM »
I'm reliably informed you have the B kit when you need the A kit.
Ciao
Offline GerryL
« Reply #13 on: January 11, 2021, 04:58:55 PM »
Uh-oh.  What's the difference?  My cylinders have the drill spot if that helps.
« Reply #14 on: January 11, 2021, 05:02:17 PM »
Covers that float are A & D kits, covers w/tube are B & C kits
Marks are for B kit
« Last Edit: January 11, 2021, 05:03:56 PM by guzzisteve »
« Reply #15 on: January 11, 2021, 05:15:54 PM »
Maybe they supplied you w/wrong rocker tower cambox. should have a # cast in  ending in 2067 R/H and 2064 L/H
Late model floating rocker tower/cambox #    2062 R/H  &  2061 L/H
Offline MotoG5
« Reply #16 on: January 11, 2021, 05:34:03 PM »
I ran into the same problem with my 12' Stelvio. Received the B kit and had it installed and when I went to put on the valve covers discovered it was not the correct kit. Had to pull it off and return it to dealer to swap for the A kit. Lucky for me the dealer had some one that had run into the reverse problem so we exchanged kits. Hopefully your supplier can do an exchange for you.
Nebraska MGNOC State Rep
« Reply #17 on: January 11, 2021, 05:50:40 PM »
They all have tubes!!   Floating cover have a short one PT# 879987,  non-floater has a long one PT# 873668
« Reply #18 on: January 11, 2021, 06:27:42 PM »
The factory really laid an egg with the design from the beginning and now they flub the solution. What a series of blunders.
« Reply #19 on: January 11, 2021, 06:42:20 PM »
I thought I remembered this issue
« Reply #20 on: January 11, 2021, 07:30:40 PM »
hooray  for this forum...     :cheesy:
Offline MotoG5
« Reply #21 on: January 11, 2021, 08:20:46 PM »
No kidding, this whole thing was so unfortunate and it gave a black eye to what were and still are a great line of bikes. I loved my Stelvio and once correctly rollered I put many miles on it with no issues. Only reluctantly let it go when due to my age not the bikes a lighter ride became what I needed to keep on the road.
« Reply #22 on: January 11, 2021, 08:32:26 PM »
Well, there's a solution if kit is wrong, just get the other valve covers.
Edit: That doesn't work either according to Pete, different tower heights and they'll crack.
Make's me glad I retired.
There are still mass amounts of bikes to be fixed, unwanted.
« Last Edit: January 11, 2021, 11:36:28 PM by guzzisteve »
Offline GerryL
« Reply #23 on: January 12, 2021, 07:55:48 AM »
Well, this sure is a can of worms then, isn’t it?  I’m glad I’m finding it now.  I don’t see any casting number that matches the above in my new pieces.  I’ll put photos of my new right side box here.  Can anyone ID these numbers?  BTW, I have .6625 long tubes if that matters.
I’m retiring in a couple months and need to get this sorted and reliable for some good riding
.  I sure appreciate the help!
« Reply #24 on: January 12, 2021, 10:03:25 AM »
I ran those part # at AF1 site w/no results. Numbers I posted were from Technical Bulletin #2014-004 that's in my service files from working at dealer. You first start by what covers you have. This to see which kit A & D or B & C.
It should say what kit you have printed on box. I been out of this for 4yrs(last one I changed). Pete R is still doing them he's over at the Ghetto. Michael is doing the hard stuff. We are all retiring. Glad I don't own any newer Guzzi's.
Offline Dilliw
« Reply #25 on: January 12, 2021, 10:28:26 AM »
A post over at the Ghetto is probably your best bet...
George Westbury
Austin, TX
Offline Motormike
« Reply #26 on: January 12, 2021, 11:20:53 AM »
If it makes you feel any better, when I rollerized my Griso I ordered the wrong kit as well. A lot of bad information on the internet as to which kit goes where. Put it on the bike only to have it leak oil like the Exxon Valdez. Got the correct kit and did it all again.  Practice makes perfect I guess. Was able to sell the wrong kit online to recover most of my money.
Offline GerryL
« Reply #27 on: January 12, 2021, 01:43:42 PM »
I actually ordered it by year and engine serial number.  I didn't specify A,B, C, or D kit.  I'm trying to work through this issue now.
« Reply #28 on: January 12, 2021, 06:50:57 PM »
Let me get you Pete's email address.. I'll send it to you in a PM. He'll know exactly what you need.
« Reply #29 on: January 12, 2021, 07:02:18 PM »
Yes,   Pete's been watching this thread.  Way to go.
