Author Topic: Start of a new project, "1200 Ambassador".  (Read 9305 times)
« on: February 27, 2021, 09:00:49 PM »
Customer John S. dropped this stuff off today.
A few years back, I started building an "Ambovert" and this was the rolling chassis. When I abandoned that project, John bought it from me along with a bunch of other bits (5 spd. transmission, new crashbars, handlebars, fork tubes, etc.). His intent all along was to use the Norge engine, that he already had, in it. Now the project is here for me to build it to his specifications.
The engine will just fit, mounts will need to be made and welded to the frame. It's been done before, by a gent "Stephen" on the Loopframe Facebook group.
I plan to use a pair of Mikuni 40 mm flat-slides that John supplied. The ignition system is where the questions start. Stephen fitted a Sachse unit meant to be mounted to the front of a Ducati PM alternator.
I want to use the original Norge ignition (coils, pickup, ECU) if possible. John supplied me with a full wiring harness, coils, ECU(s), and just about everything else (including a dash!).
My question is, does anyone know if can I just remove all of the bits of the harness that I won't need (f.i., ABS, dash, etc.) and create a stand-alone ignition system utilizing just the pickup, coils and ECU? Looking at the wiring diagram, it sure looks like it could be very simple.
https://www.thisoldtractor.com/mg_manuals/wiring_diagram_norge_1200_gt_8v.pdf
The coils are #46 & #47, the pickup is #53.
« Last Edit: March 29, 2021, 01:03:58 PM by Antietam Classic Cycle »
Re: Start of a new project, "1200 Ambassador", ignition question.
« Reply #1 on: February 27, 2021, 10:16:03 PM »
Interesting, I thought the dash was integral to the system?
 :popcorn:
« Last Edit: February 28, 2021, 10:01:53 AM by fotoguzzi »
Offline 80CX100
« Reply #2 on: February 27, 2021, 11:14:56 PM »
Interesting, I though the dash was integral to the system?
 :popcorn:
     Very interesting build Charlie  :bow: :thumb:
     From the reading I've done, I didn't think there was an easy work around solution for the dash issue.
     I hope kiwiroy sees this and jumps in, I'm sure I've read him describe how the canbus system on the CARC bikes  need a signal from all sorts of wires and sensors for the basic ignition and fuel injection to work.
     Will be an interesting build to follow, I'm sure lots of CARC owners with faulty/flakey dashes will be eager to see you come up with a simpler working solution.
    good luck with it
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Ariel
« Reply #3 on: February 28, 2021, 12:36:23 AM »
Hi Charlie,
I installed a 1100 Stone engine on a 1982 G5.
I used 40mm Dellortos and a Sachse Ignition mounted on the Alternator.
It works great.
I made a new harness myself.
I think this is easier than modifying an original harness.
Are you going to use the Fuel Injection System, or Carbs?
Also, how difficult or easy is it to fit the old style gearbox in a CARC engine?
Ariel
LesP
« Reply #4 on: February 28, 2021, 01:01:05 AM »
If the stock ECU and fuel injection is going in the bin, the ignition should be easy (as long as the curve is correct)
A then stand alone ignition (once attached with machining) does not know what it is attached to, it just does its job when it see's a signal.
Fantastic project and look forward to future posts.
« Reply #5 on: February 28, 2021, 01:24:42 AM »
Should be a fun project.
I think the ignition will be fairly straight forward pickup item (51) except you won't have a Throttle Position Sensor. The ignition will fire ok but it will just fire at one spot.
Beetle would be the guy to ask if you needed a TPS or some other method of advancing the spark, I'm sure you could rig up a TPS somehow on the carb linkage, it doesn't need to be a precision device since you won't need it to control the injectors.
I have a Hall Effect sensor I could send you, that would be a nice way to replace the regular TPS
https://www.thisoldtractor.com/guzzi007/schematics/2007_Norge.gif
Of course you won't need the fuel pump with carbs, it would have too much pressure for the float needles.
« Last Edit: February 28, 2021, 01:40:23 AM by Kiwi_Roy »
« Reply #6 on: February 28, 2021, 08:59:51 AM »
Hi Charlie,
It works great.
Ariel
It's a bit different with the Norge engine - no crank mounted alternator to attach the Sachse pickup directly to. Stephen attached it to the alternator belt cover, which doesn't seem to be optimal to me.
I'll have Greg Bender make a new main harness, but if I can use part of the Norge harness for just the ignition, I will.
I have both carbs and f.i. to choose from, but we've pretty much decided to use the Mikuni 40 mm flat-slides.
The 5 spd. simply slips right onto the Norge engine - no modifications.
Sure I can do an aftermarket ignition, like Stephen did, but I thought it would be nice to utilize the Norge parts I already have, if at all possible. Possibly less work, less costly, a cleaner installation and no doubts about the correct curve.
Even if I need to add the TPS, it wouldn't be too hard. How would the Hall Effect sensor replace the TPS and where would it go/how would it be wired in?
I don't have the Norge pump and since it was in the tank, wouldn't consider using it anyway. Gravity will work just fine.
Offline Groover
    • Scooteropolis
« Reply #7 on: February 28, 2021, 09:46:49 AM »
Another great project to watch!  :thumb:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #8 on: February 28, 2021, 02:00:08 PM »
I think your on the right track with using the ECU for the ignition. I'm not sure if the timing needs a TPS??? I think it's only needed for the injectors???
The dash, I have no idea. Does the dash have a lockout feature? Coded key?
Good luck,
« Reply #9 on: February 28, 2021, 02:23:11 PM »
The Hall effect sensor is actually a TPS off a car, it would wire straight to the ECU in place of the throttle sensor (40)
Needs some form of linear to rotary motion.
« Last Edit: February 28, 2021, 02:31:12 PM by Kiwi_Roy »
Offline jacksonracingcomau
« Reply #10 on: February 28, 2021, 04:18:48 PM »
Late Keihan flat slides have tps as std, should be easy to find used from 450 mx bike in suitable size
Or maybe adapt the fitting to fit your mikunis
No idea if they “talk” to your ecu but Roy or Beetle would know
« Reply #11 on: February 28, 2021, 04:36:57 PM »
Can you post a photo of what it looks like? The Norge TPS would need the same "linear to rotary motion".
If these Mikunis (TMX) had bellcrank tops, it would be easier to adapt the Norge TPS. Unfortunately, they don't, just simple flat tops. I'm sure I can still figure something out though.
Edit: Searched cable operated TPS and found that such a thing exists! Here's one example:
Probably wouldn't be too difficult to machine an adapter for the Norge TPS to make it cable operated. We plan to use a Tommaselli 2C throttle and the Mikunis came with cables and one-into-2 splitter. So I could run one cable direct from the 2C to the TPS and then the other to both carbs via the splitter.
« Last Edit: February 28, 2021, 05:11:49 PM by Antietam Classic Cycle »
Offline Frenchfrog
« Reply #12 on: February 28, 2021, 04:51:49 PM »
very interesting project..this could be a red herring but these guys make highly rated ignition systems and may be able to help...it is a long way to go though !  https://www.ignitech.cz/en/
« Reply #13 on: February 28, 2021, 10:25:04 PM »
I will do, I dont believe the TPS is so critical if you aren't using it for the fuel injection
Offline lucky phil
« Reply #14 on: March 01, 2021, 01:11:58 AM »
Good luck,
Nope, ignition as well. Ignition and fuel maps both use the TPS as a reference. Ditching the EFI is such a backward step. It's the luddite option.
Ciao
« Last Edit: March 01, 2021, 02:24:34 AM by lucky phil »
Offline tris
« Reply #15 on: March 01, 2021, 01:39:36 AM »
 :popcorn:
I thought you would need the dash too.
However a few years ago when I thought that the dash on my B11 was about to die I looked at the Megasquirt / Microsquirt aftermarket ECU.
It struck me that every sensor that the engine needed was already fitted. I just need to be able to talk to it and the Microsquirt had the ability to do that
See here https://www.diyautotune.com/shop/megasquirt-assembled/microsquirt/
1993 TW125 "POS" - Resting
« Reply #16 on: March 01, 2021, 08:52:53 AM »
Ciao
Guilty as charged. This project is going to be daunting enough without throwing EFI into the mix.
Online TN Mark
« Reply #17 on: March 01, 2021, 09:59:21 AM »
Is there a feasible way to mount or install and use the dash panel from the Norge onto the Ambassador? Even if it's tucked away for aesthetic reasoning. You'd then be able to use EFI instead of carbs.
« Reply #18 on: March 01, 2021, 10:09:39 AM »
Other than the challenge and the fact that he has the engine, what is plus for using a 2 valve Norge engine?
« Reply #19 on: March 01, 2021, 10:15:48 AM »
No way in Hades that I'd incorporate that fragile, troublesome POS into the system.  :evil: There are ways of using EFI without it anyway.
But, as I wrote above, this project will be big enough (not only do I have to install the Norge engine and make it work, but I also have to restore the entire Ambo chassis) without adding the complication of EFI. There is a budget that I need to work within as well and the hours it takes for me to figure out all of the EFI installation would definitely cause me to go way over that.
I can hear it now though "err, it's not really that difficult to install", "it'll run so much better", etc. Fine. Then you build a Loopframe with Norge engine and show me how it's done!  :evil: :laugh:
"There's no replacement for displacement". In a word: "power".
Offline lucian
« Reply #20 on: March 01, 2021, 11:39:02 AM »
I can't see a problem with eliminating the dash . As long as you can get around the ignition immobilizer function . Other than that its only function is the ability to store a few sensor faults. I am not certain, but  it seems  to me that the advance curve in the ecu would only require input from the rpm sensor not tps.  At least I hope that is the case. Good luck with it , you certainly have a project.  Looking forward to following. :bow:
« Reply #21 on: March 01, 2021, 12:44:39 PM »
When you get it figured out, I will bring you my ambo parts bike and a breva 1100 engine-- hopefully I can find a cheap convert for the disc/fork conversion by then
« Reply #22 on: March 01, 2021, 01:01:23 PM »
Might want to find a 5 spd. and Tonti rear drive too.  :wink:
Online TN Mark
« Reply #23 on: March 01, 2021, 01:19:24 PM »
I certainly admire your ability to get these things figured out and working as they should. This will be a very educational thread to follow. Thank you for allowing us to tag along.
« Reply #24 on: March 01, 2021, 01:23:33 PM »
I'll be starting a build thread in the "Bike Builds, Rebuilds And Restorations Only" section once I get started. Right now I'm still in the "thinking it through" and "collecting what's missing" stage.  :azn:
Offline lucky phil
« Reply #25 on: March 01, 2021, 01:40:27 PM »
Nope, requires both. Ignition map is rpm V throttle position. Baro pressure engine temp and OAT also trim the ignition values. A small Part of the reason EFI is better.
Ciao
« Last Edit: March 01, 2021, 04:05:57 PM by lucky phil »
Re: Start of a new project, "1200 Ambassador" - questions.
« Reply #26 on: March 01, 2021, 04:09:48 PM »
Next question: EV (8 spring) flywheel and clutch or Norge (10 spring)? I don't have either, both are on ebay for reasonable $$. Just worried that the Norge unit may be too hard to pull with a cable and Convert handlebar lever assembly. We don't want to go hydraulic. Opinions?
« Reply #27 on: March 01, 2021, 04:13:42 PM »
TPS
Unlike the usual TPS it doesn't have a mechanical stop, it will just rotate forever it just has a range of 90 degrees it responds to so you will need to figure out the coupling. it has 1/4" shaft with a flat.
The Norge TPS doesn't have a 160 millivolt zero set point like a 2000 era bike
« Last Edit: March 01, 2021, 04:23:49 PM by Kiwi_Roy »
« Reply #28 on: March 01, 2021, 04:16:18 PM »
Offline lucian
« Reply #29 on: March 01, 2021, 04:43:41 PM »
Do they have a lighter spring option for the 10 spring clutch as they do for the eight?  j I just put the surflex springs in the 8 spring lmIII and was pleasantly surprised by the lighter pull.  Maybe you could go hyd and go cable to a hidden MC . Have your cake and eat it too.
