Author Topic: G5 Rear Drive Disassembly  (Read 1180 times)
Offline Scout63
« on: March 12, 2021, 07:56:48 AM »
I hate the thought of rebuilding my entire bike without putting eyes on the rear drive internals and vapor blasting the case.  Is it one of those systems that is better left alone?  Will I need any super expensive special tools?
Ben Zehnder - Orleans, MA USA
Re: G5 Rear Drive Disassembly
« Reply #1 on: March 12, 2021, 08:06:35 AM »
No special tools. The flange with large seal and bearing can sometimes be difficult to remove. I use a 3-legged puller with the legs reversed (hooks pointed outward) to catch the splines in the hub and pull it out.
If you're stripping it completely down to replace both seals, you'll need to warm the housing to ~ 200 degrees F in order for the outer race of the needle bearing to drop out, for access to the small seal.
Offline Groover
    • Scooteropolis
« Reply #2 on: March 12, 2021, 09:18:16 AM »
What Charlie said. Do the inner seal if messing with it, that one will get you when you least expect it (when you decide to go for a long ride and are far from home)
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Online n3303j
  • Ron Cichowski
« Reply #3 on: March 12, 2021, 09:51:50 AM »
If you change cover gasket thickness you will change the gear contact patch. You don't really want to change the gear contact patch. So just be aware when you replace the gasket (or re-use the original with a bit of sealant).
I'm only commenting because I've seen quite a difference in thickness on purchased paper gaskets.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Scout63
« Reply #4 on: March 12, 2021, 09:07:58 PM »
Thanks guys.  I hate the idea of leaving one assembly not checked. I’m going in.
Offline DAMMAG
« Reply #5 on: March 13, 2021, 03:42:53 PM »
Would be good to see some pics  :grin:
