Author Topic: Final drive level plug threads leaking. Repair...?  (Read 3362 times)
Offline radguzzi
« on: November 17, 2021, 05:48:24 PM »
So I winterized a couple of motorcycles a week or so back and the Hack received oil, filter, trans and final drive fluids...   As I put the level plug back into the final drive I could "feel" that uneasy hint of a weak thread happening, I proceeded gingerly snugging the plug against the crush washer.
Low and behold, that plug is indeed leaking, just a bit of a weep really.
Before I take it down to check whether the threads are actually compromised I need to know whether that thread is repairable.   This unit is a late model 7/33 on the '99 EV.
1/  Is there enough room for a Helicoil...?
2/  Does the entire case need to be emptied to do this type of repair...?
I may just swap out the unit with the original '99EV 8/33 while I investigate the issue.
Thanks for any insight here.
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Re: Final drive level plug threads leaking. Repair...?
« Reply #1 on: November 17, 2021, 06:15:25 PM »
(1) my guess is it will require an insert of some kind rather than a helicoil. That case is pretty thin.
(2) yes
Offline lucian
« Reply #2 on: November 17, 2021, 06:17:06 PM »
I would try Loctite 545 thread sealant , As long as the threads still have a little bite you'll be good to go. They do make Heli coils for shallow threads  as well' Maybe get a crush washer with the rubber center along with the Loctite.  Good luck !
Found this , never used it but could be worth a try
 https://www.summitracing.com/parts/lct-28654?seid=srese1&gclid=CjwKCAiA7dKMBhBCEiwAO_crFEo0PfUsWu6ksT4FS7sIBGTyMfb_pYcfabukreyPAKtoIwkz8JVorBoCT_oQAvD_BwE
« Last Edit: November 17, 2021, 06:36:02 PM by lucian »
Online John A
« Reply #3 on: November 17, 2021, 06:33:44 PM »
Sometimes a longer plug works and then you can fix it at your leisure.
« Last Edit: November 17, 2021, 07:45:08 PM by John A »
« Reply #4 on: November 17, 2021, 08:21:53 PM »
I never use the level plug on big-blocks as they're rarely accurate - drain, measure the correct amount and fill. Try the longer plug as John A suggests and if not already using "dowty washers"/"stat-o-seal" type washers as lucian suggests, then you might consider it. Less torque to seal and reusable. I get mine from McMaster-Carr: https://www.mcmaster.com/93786A175
Offline henwilv
« Reply #5 on: November 17, 2021, 09:05:48 PM »
Rob
You can try plumber's PTFE tape (3M makes it, amongst others) and if it doesn't leak, never remove it and refill by measuring the correct quantity. That diff never gets as hot as the hot water in your pipes.
« Last Edit: November 17, 2021, 09:06:51 PM by henwilv »
Online Moparnut72
« Reply #6 on: November 17, 2021, 09:24:09 PM »
I know that NAPA sells oversize drainplugs for autos for situations like this. Maybe one would fit for this application. They would probably need to be special ordered.  You would need to know tread size and pitch. You would also need a savvy counterman.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online jhem68
« Reply #7 on: November 17, 2021, 09:33:49 PM »
I'll submit that if you don't value using the level plug as an accurate check on the oil level, then simply remove the  plug clean the plug threads and case. JB Weld the plug into place and from here on in use the drain and measure upon changing oil as Charlie has rightly suggested. Easiest and most pragmatic solution IF you can live with the "cobble" nature of the repair.
None of the newer Guzzi's bother with the level plug.
« Reply #8 on: November 17, 2021, 09:40:02 PM »
I got a few to do for a customer also change all seals on restoration. Just got a timesert kit.
Offline huub
« Reply #9 on: November 18, 2021, 02:36:21 AM »
a heli coil works fine ,
 i did quite a few
Offline Rolf Halvorsen
« Reply #10 on: November 18, 2021, 03:17:50 AM »
1 - yes
2 - yes - in a fixture
Helicoil - yes
« Last Edit: November 18, 2021, 03:19:52 AM by Rolf Halvorsen »
Offline mtiberio
    • TiberioRacing
« Reply #11 on: November 18, 2021, 04:37:46 AM »
glue/epoxy level plug in place and never use again. Drain, fill w/250cc, check via zip tie inserted from fill plug hole. Send tie toward rear and down. Not hard to tell if you have enuf oil. Never touch the drain unless absolutely necessary. My rear drives come off often enough, I either drain through the fill hole or out the pinion cavity.
« Last Edit: November 18, 2021, 05:06:18 AM by mtiberio »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Stevex
« Reply #12 on: November 18, 2021, 07:35:54 AM »
Those washers with the rubber seal inserts are called Dowty washers over here (UK).
I'm replacing bevel and gearbox oils this winter and am going to syphon out the old oil with a large syringe and thin bleed tube and then use a homemade dipstick to check levels, which I've being doing for the last year or so with good results. Save's ever having to disturb those threads.
« Last Edit: November 18, 2021, 07:36:46 AM by Stevex »
Offline larrys
« Reply #13 on: November 18, 2021, 08:12:37 AM »
My Cal has the same issue. Weeps just enough to make a mess. The PO must have been a gorilla. Every bolt and nut he touched was way overtightened. Great suggestions here. I will opt for the JB weld fix.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
« Reply #14 on: November 18, 2021, 08:43:41 AM »
Clean it up. Put sealant on it. Screw it in. Never remove it again.
The level plug is sort of bogus. Drain it from the bottom plug and fill it with a measured amount. The end.
I once helicoiled a bottom drain plug and it worked out well. And since it is NOT a pipe thread, teflon tape is of course the wrong thing to do.
Offline huub
« Reply #15 on: November 18, 2021, 01:40:35 PM »
I know guzzi riders are cheap, but glue a level plug in place? seriously?
A M10 heli coils kit cost 10 euro, and is a nice tool to have anyway.
the tube of jb weld is probably more expensive.
i am always amazed at the bodges i find on used bikes.
fortunately never found level plugs glued in ..yet
« Last Edit: November 19, 2021, 02:00:35 AM by huub »
Offline mtiberio
    • TiberioRacing
« Reply #16 on: November 18, 2021, 03:38:04 PM »
A M10 heli coils cost 10 euro, and is a nice tool to ave anyway.
the tube of jb weld is probably more expesive.
Helicoil is a boge. Pick your posion.
Offline radguzzi
« Reply #17 on: November 18, 2021, 06:24:37 PM »
All good guys, thanks.
I hate to defer maintenance however, due to the late date and more cycles to put up for Winter, I have prepared the Hack to be put away without changing the final drive plug.
I took a few minutes to pull the level plug out and the threads re indeed totaled, thread tape did nada to firm up the grip.  In the Spring I will entertain doing the plug it and leave it method whether with epoxy or some other means.
If I have the time prior to completely storing the rig I May swap the final drive before closing the doors on the season, hope to find time for that.
With that unit off I can decide what to do with it.   Fortunate that I have that spare (original) final drive.
I appreciate the input folks.  And just to mention it, I am not ham-fisted at all so this pulled thread has me scratchin' me head.   Hard steel pug against an aluminum case though...
Again lucky to have a way out of a dilemma.
Thanks,
rad__
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
« Reply #18 on: November 19, 2021, 08:01:09 AM »
 :smiley: This isn't an unheard of issue.. you are definitely not the first.
Online John A
« Reply #19 on: November 19, 2021, 08:45:53 AM »
I think he should be designated first as a ceremonial title. :azn:
Online Matteo
  • Alaska Guzzi's on Facebook
« Reply #20 on: November 19, 2021, 10:51:46 AM »
Attsa good thread!  :laugh:
Online Tom H
« Reply #21 on: November 19, 2021, 11:08:27 AM »
I would try a longer bolt. I had the same problem. Guzzi uses a rather short bolt. I had one about 5mm longer and it holds just fine. Just don't go too long.
Offline radguzzi
« Reply #22 on: November 19, 2021, 06:29:47 PM »
I see what you did there...  :grin:   This however, is not...  :shocked:  You can see that the steel bolt had been spinning the threads right out of the hole.
I could not leave the Hack alone.   The Winterizing had been done, the Hack was stored in it's trailer for the Winter but I pulled it back out this morning and swapped the final drive out for the original 8/33.  Put in the 250cc of new gear oil Never touching the level plug and put the Hack back in the trailer.
The temptation to go for a test ride was great but I resisted, fuel stabilized, oil changed and all that.  It will keep until Spring.
Just for grins I did this, cut off a 10mm bolt at about that same length and the thread engaged with what is remaining for threads in the hole, which ain't much.  Nice tight fit.
That will be a candidate to either Helicoil repair or epoxy that bad Larry into place.
Another thing about this unit is that I cannot seem to pull the pinion assembly out.  I want to check on the actual gearing, I bought it years ago as a 7/33 but I really do not know what the gearing is.  I have the flange soaking in Aero Kroil and I'll try again in the AM.
The 8/33s that I have here, this one and the one on the '04 EVT are stamped right on the case.  Not so with this (hopefully) 7/33.
Thanks all,
Rob
Oh, thanks...  :bow: :grin: :boozing:  I am a relative new-comer.   :smiley:
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
Offline henwilv
« Reply #23 on: November 20, 2021, 11:36:10 AM »
Please note, we are talking about a bodge job here so NOTHING/EVERYTHING is the wrong thing to do
Offline henwilv
« Reply #24 on: November 20, 2021, 11:44:57 AM »
« Reply #25 on: November 20, 2021, 12:36:35 PM »
"Gluing" the plug in place is a short term quick fix alternative when one wants to keep the machine in service, until a more permanent fix can be done.
To install a Helicoil or other thread repair insert correctly, the rear drive should really be totally disassembled and mounted into a milling machine or at least a drill press. Doing it free-hand or by "eye-ball" usually results in the hole and threads being crooked and then the sealing washer doesn't. Not everyone has the skill or machinery to do this.
Online Bulldog9
« Reply #26 on: November 20, 2021, 07:21:52 PM »
I dont have much experience with helicoils or tserts, but on a couple of my older bikes and cars when this has happened, I've used a new/longer plug which has helped, along with a crush washer with the rubber ring on the inside and used the locktite 565.  The last time I changed the transmission oil on the Griso, I felt that 'weak thread' sensation, and I bought a slightly longer plug so I am ready next time. Hopefully won't need more than that.
MGNOC#23231
Offline radguzzi
« Reply #27 on: November 20, 2021, 07:34:25 PM »
I know that we have covered this ad nauseum, pros and cons of a quick repair vs a proper repair.   Cheap bodge fix or not etc...
Funny that I am leaning toward a tab of Belzona Molecular or Super Metal (JB Weld type epoxy) in the hole and re-tapping for the bolt/plug.  Putting a bolt into that newly threaded hole and Never moving it again.
This is the 7/33 final drive that I need for the Hack.  I will keep the Hack until I am lowered into the ground, my Son has instructions to carry me to my final resting place with the Hack.
Along with the pages of notes on every motorcycle that I have here, I keep impeccable records and I will make a note of this repair If I go that way.
Charlie,
I do have a drill and access to a Bridgeport so the repair can be done correctly.
In the Spring I will try out the 8/33 to see if I really need it on the Hack, probably will swap it back.
Thanks all,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
