Author Topic: WW2 Radial Engine Start Noise  (Read 3319 times)
Offline tris
« on: December 22, 2021, 09:14:06 AM »
I know that someone on here will know the answer to this!
I've noticed that when they start a big radial there is a whine that is in some way the starter but its not connected to the engine until the pilot later engages something when he's ready
https://www.youtube.com/watch?v=L8PGxaqJVgs
It's obviously not connected directly to the crank, but what is it going on?
Is it building air pressure to feed directly to the cylinders or a fly wheel storing energy to spin the engine over
Cheers
Tris
1993 TW125 "POS" - Resting
Re: WW2 Radial Engine Start Noise
« Reply #1 on: December 22, 2021, 09:21:47 AM »
It’s an inertial starter, basically a flywheel that is spun up and engaged when it gets up to speed.
That one is being spun up with an electric motor. Some use an air turbine and some have a hand crank provision. Cool stuff
« Last Edit: December 22, 2021, 09:29:49 AM by John A »
Offline tris
« Reply #2 on: December 22, 2021, 09:26:09 AM »
I knew that someone would know!
Cheers John  :thumb:
Offline Moparnut72
« Reply #3 on: December 22, 2021, 09:28:13 AM »
Exactly correct. Of the engines we did when I worked on radials I think it was the Pratts that used those starters.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline wavedog
« Reply #4 on: December 22, 2021, 04:48:09 PM »
Yeah, inertial starter. The Dromaders that I flew had eastern block inertial starters. Your hands were dancing around the cockpit getting one of those cranked over.
 The P&W radials on the C47 and the Convairs just had electric starters.
Offline grebmrof
« Reply #5 on: December 22, 2021, 04:57:20 PM »
It is also interesting how the videos don't depict the true rotation of the props...I think their scan rate acts a bit like a strobe and slows down the prop rotations sometimes showing them going backwards other times standing almost still.  Somebody chime in on what we are seeing when that happens?
'08 Triumph Bonneville T100
« Reply #6 on: December 22, 2021, 06:22:16 PM »
Some of the ME-109 fighters equipped with Daimler Benz V12 engines used an inertia starter that required some manpower to spin up the flywheel.
https://www.youtube.com/watch?v=LgTw-w4k87E
Bob
Offline Murray
« Reply #7 on: December 22, 2021, 07:07:23 PM »
Bob
As well as the AN2 and the tiger tank.
« Reply #8 on: December 22, 2021, 08:48:53 PM »
When I was in Bellingham, WA , I was able to see the first two of supposedly forty AN2’s a guy had bought in Russia after the Soviet fall. They were primitive with wing skin like barn tin and they were big enough to hold 30 skydivers. Big Polish radial engine that rotated opposite of ours. They could fly at thirty mph and had a big red hammer and sickle on the tail with CCCP in large red letters on the fuselage. Battery operated inertial starter on those monsters https://youtu.be/awVmSJe4nLI
« Last Edit: December 23, 2021, 07:48:51 AM by John A »
Offline tris
« Reply #9 on: December 23, 2021, 01:35:21 AM »
When I was in Bellingham, WA , I was able to see the first two of supposedly forty AN2’s a guy had bought in Russia after the Soviet fall. They were primitive with wing skin like barn tin and they were big enough to hold 30 skydivers. Big Polish radial engine that rotated opposite of ours. They could fly at thirty mph and had a big red hammer and sickle with CCCP in large red letters. Battery operated inertial starter on those monsters https://youtu.be/awVmSJe4nLI
That's cool that AN2 :thumb:
Offline Murray
« Reply #10 on: December 23, 2021, 02:01:16 AM »
The flight manual says something about an emergency starting procedure with a handle and what is described as a "strong man". So it's likely near impossible from the average person been the Russians not prone to hyperbole.
Offline Calidavid
« Reply #11 on: December 23, 2021, 02:29:33 AM »
Catch-22. The best movie opening scene for warbird fans. Skip the credits if you are impatient.
https://www.youtube.com/watch?v=VHDRURvU5PA
Offline huub
« Reply #12 on: December 23, 2021, 02:34:39 AM »
we had a AN2 running from a local small airfield for some years ,
the startup procedure was interesting , first turn the prop by hand a couple of revs, ( big prop , lots of compression,  great exercise ) to clear the cylinders from oil, the vertical ones fill up with oil after standing for some time.
than getting the inertia starter up to speed , which cost another minute or so.
if it started it burned all the oil that was just pumped out ( some 5 liters of it)
It covered the whole airfield in a thick layer of smoke.
i did a couple of sightseeing flights with it ,
the takeoff speed was amazingly slow , one moment you were taxying , the next moment you were flying at 30 MPH....
Offline tris
« Reply #13 on: December 23, 2021, 03:27:50 AM »
Well thanks chaps, now I know what to look for I could do a bit of a Google search and found this
https://www.youtube.com/watch?v=sU3fRqj_bmE
The CGI is a little irritating, but the message, at least for the German machines, is clear
Thanks again :bow:
Offline wavedog
« Reply #14 on: December 23, 2021, 08:20:54 AM »
I used to remove a spark plug from the bottom cylinders (each had 2) when the plane had been sitting a while to let the oil drain out. On the Dromader I had cans with wire loops and would hang them on the cylinders. On the C47 it was a little more complex with the cowling removal. The Convair, with the 2800- fergit it. Just crank it over unless it had been sitting a long long time, which it never did. With the radials on the Ag-cat and the Air tractor it was the same thing- make sure there was no oil in the cylinder. They all still smoked on start up when the engine was cold. That was kind of cool.  The turbine motors were much better in some ways but lost a little soul.
Offline tparr
« Reply #15 on: December 23, 2021, 06:03:20 PM »
Nothing like the rumble of a big radial engine. Remember the movie Flight of the Phoenix starring Jimmy Stewart? The aircraft was a Fairchild C-82. In the movie they used a type of charged shell to start the big radial. A "shotgun starter" known as the Coffman engine starter. Link to a wiki article https://en.wikipedia.org/wiki/Coffman_engine_starter
1969 Moto Guzzi Ambassador "A" model
2019 Moto Guzzi V7III
2013 Ural Gear Up
Online brider
« Reply #16 on: December 23, 2021, 07:13:02 PM »
I saw one of those rascals at an airshow in CA about 30 yrs ago. The announcer told the crowd "Folks, you won't believe how slow this thing will fly...", and I watched it start it's run and couldn't believe something that big could go airborne moving that slow. That is COOL, and I have a lot of respect for the Russian design philosophy of designing for EXACTLY the need or requirement, and everything else is secondary. Like survivability or comfort in a T-series tank.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
« Reply #17 on: December 23, 2021, 08:01:13 PM »
The starter cartridges we used on B- 52’s were black powder. I don’t remember how much, either 5 or 15 pounds. Lot of smoke. But they were turbines, not half as interesting as a radial and just made noise, not half as good as a radial.
Online Gliderjohn
« Reply #18 on: December 23, 2021, 09:05:52 PM »
Had a B-17 ride a few years ago. Was seated in the plane before startup. I was positioned next to the right side gunner window so plenty of smoke and noise when the engines were fired up. The run ups were fun too. Also did a flight in a Stearman with a much smaller radial. Back in the early 80s attended an airshow in Topeka that featured 50 warbirds in formation lead by three B-17s. Now that was some wonderful noise. Yea, old radials are very cool.
East Mountains, NM
Offline Murray
« Reply #19 on: December 23, 2021, 09:14:36 PM »
Interesting can't remember what the start carts were on the pigs, it was nasty and you made sure you didn't breath the gases in and they were handled as an explosive. Black powder I associate with a more explosive response to ignition where was the starter carts were a more constant response. Not black powder initiated per chance?
« Reply #20 on: December 23, 2021, 09:39:26 PM »
It was a canister with a squib to light it. It produced high volume low pressure gas to spin the starter in the same way as the air huffer cart.
Offline Moparnut72
« Reply #21 on: December 24, 2021, 11:40:33 AM »
My old boss had a Stearman. It came from the factory with a 220hp Lycoming. He bumped his to 300hp with some trickery. He is in an extended care facility, I don’t know what happened to the plane. It was spotless and  painted like a Navy Trainer.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #22 on: December 24, 2021, 05:05:01 PM »
This has always been one of my favorites to be close to at startup:
https://youtu.be/v0iEqLorxF4
I can imagine more than one passenger gazing out the window, "Um, stewardess..."
Offline wavedog
« Reply #23 on: December 24, 2021, 05:50:47 PM »
The super Connie! The Constellation is the most beautiful airliner ever.
I got to ride on one from California to Japan way back in the day. 36 hour flight, stopped in Hawaii, Wake island and the plane went around Mt Fuji so everyone could get a good view.
Yes at night there was a sheet of flame from the motors. Very cool memories.
Online Gliderjohn
« Reply #24 on: December 24, 2021, 06:06:57 PM »
There has been a Connie parked at the Salina, KS airport for decades. There was a couple feeble attempts back in the 80s to try and restore it but nothing ever happened. Don't have any idea who actually owns it currently.
East Mountains, NM
Offline wavedog
« Reply #25 on: December 27, 2021, 10:42:50 AM »
  Here is a video from a friend I used to fly with back in the day. This is starting a PZL M-18 Dromader. We used these firefighting for a while.
    https://youtu.be/hyP5NP-BmNE
