Author Topic: Help identifying “hydro” valve fix please!  (Read 1683 times)
Offline inditx
« on: July 12, 2022, 11:40:55 AM »
Need your help.
I see the “shiny hats” but is this the best and final fix that I read about on the hydro?
It’s on a 2004 EV that I’m looking to buy.
Pics of single or dual clutch to follow.
Thanks in advance for your expeditious help.
inditx
what does screen resolution do
« Last Edit: July 12, 2022, 09:35:53 PM by inditx »
inditx
This is the day.....
Online Tom H
Re: Help identifying valve fix please!
« Reply #1 on: July 12, 2022, 07:27:49 PM »
Yes it has had a recall done. I "think" the only way to tell which one is the cam and the hydro lifters?
The only thing that bothers me in the pics is the brass shims. I need to look at my EVT, but I think there should only be one brass shim per rocker, it looks like you have 2 per rocker. The other thing is that "normally" the shim and spring would be set up with the shim against the rocker block and the spring against the rocker. I don't know if that makes any difference, but "most" bikes have the spring against the rocker.
Hope this helps a bit,
Offline inditx
« Reply #2 on: July 12, 2022, 09:14:36 PM »
It does, I guess the thing I’m seeing is the broken off studs and shiny hats so it should be good to go?
inditx
inditx
Offline lucky phil
« Reply #3 on: July 12, 2022, 11:54:49 PM »
Nope 2 per rocker otherwise you have a cast steel rocker bearing against an alloy rocker support.
Phil
Offline inditx
« Reply #4 on: July 13, 2022, 09:20:56 AM »
Phil
Thanks Phil!
inditx
Re: Help identifying “hydro” valve fix please!
« Reply #5 on: July 13, 2022, 10:42:41 AM »
IIRC, on square-fins there are two brass shims on either side of the rocker and a steel shim against the alloy rocker support, spring between the brass and steel. That's why I made an alignment drift - to get all the bits lined up so I could get the pin back in more easily.
Online Tom H
« Reply #6 on: July 13, 2022, 11:46:25 AM »
I didn't know that the square fins were set up this way. Thanks for the info!!
Offline inditx
« Reply #7 on: July 13, 2022, 03:39:53 PM »
inditx
Offline egschade
« Reply #8 on: July 13, 2022, 09:14:59 PM »
This is how my EV looked after the work was done. Snapped off valve adjuster is the indicator.
The elder Eric in NJ
2016 V7 Stornello #394
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Offline inditx
« Reply #9 on: July 14, 2022, 07:51:27 AM »
inditx
