Author Topic: Norge display question  (Read 876 times)
Offline Kaladin
« on: November 02, 2022, 01:44:52 PM »
After my trip to Moab I notice that under the trip meter there is a small font number that says 123 with some letters after it that I can't make out.   Any idea what this is?
k
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be.  And when you find it you discover "that's where it should have been."
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Offline CoolBreezeBreva
Re: Norge display question
« Reply #1 on: November 02, 2022, 02:52:07 PM »
Can you upload a pic of the display that you're seeing?
Offline Huzo
« Reply #2 on: November 02, 2022, 03:14:44 PM »
It will be the fuel consumption, average and highest speed reached, or similar.
You’ll see here that mine is on litres/100 km and the figure is 9.0…!
That is because I had just ascended the Stelvio Pass in 3rd and 4th gear (mostly) at a VERY steep grade…(you’ll notice the temperature is @ +1 deg C).
The fuel figure is usually around 4.8-5.0 l/100 km at highway speeds.
Here you can see it’s just been reset to zero.
Also yes, I have deleted the service wrench icon. The code is 28315 that you have to enter into the system before you can get into the diagnostics menu and it’s a bit complicated to go into here, but we can somewhere else.
There is a large button above the turn signal switch on the left handlebar, if you flick it left or right you will cycle through the different displays.
It’s the top one..
Holding it left or right for a couple of seconds will cycle through the two trip meters and holding it down will zero everything except the total distance on the main odometer.
It does take some practice… :wink:
You will inevitably notice that your hand will inadvertently brush it as you operate the turn signal, altering the desired display.
You’ll get used to it… :clock: :clock: :clock:
« Last Edit: November 02, 2022, 03:32:01 PM by Huzo »
Offline Kaladin
« Reply #3 on: November 03, 2022, 12:32:32 PM »
After getting down there with some reading glasses I see that it says 123 MPH.
I know that it couldn't be 123 MPG
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
Offline Huzo
« Reply #4 on: November 03, 2022, 01:05:41 PM »
That sounds like highest speed reached since reset.
Could that be right ?  :copcar:
Just hold the button down for a few seconds and see if it resets .
By “down”, I mean press it in, not vertically down towards the road…
« Last Edit: November 03, 2022, 01:07:27 PM by Huzo »
Offline Kaladin
« Reply #5 on: November 04, 2022, 10:04:37 AM »
I might have let loose for a short while while out in the desert.   :rolleyes:
I didn't realize that there might be evidence.
2007 Norge
2000 BMW R1150GS
2003 Jaguar XKR
