Author Topic: V85TT starter button no go.  (Read 1393 times)
Offline steven c
« on: September 10, 2023, 03:56:10 PM »
 My new to me 2020 V85TT, has this issue where the starter will not engage when the button is push,but it always does start after a couple of tries. Well today getting ready to live IMOC it took many tries before it started and that was after I hit the off button a couple of times. Will a new switch cure this? I have check  the battery connections. My wife thinks I should have kept the VStrom.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Huzo
Re: V85TT starter button no go.
« Reply #1 on: September 10, 2023, 04:11:29 PM »
The spade connector that goes onto the solenoid is quite weak and frail in it’s engagement, get a test light and see if you are getting current to there when you push the button, if you are then work on improving the integrity of the connection there.
Jump the battery to the starter and see if the starter will crank when supplied…(make sure the damn thing is in neutral).
If you suspect the battery, hook up a set of good jumper leads from your car and see if that cures the issue.
If/when you check the battery lead terminals, check BOTH ends of BOTH leads.
« Last Edit: September 10, 2023, 04:46:17 PM by Huzo »
« Reply #2 on: September 10, 2023, 05:14:03 PM »
Gotta love wives.   :violent1:
LOL!
Offline steven c
« Reply #3 on: September 10, 2023, 07:31:16 PM »
 Thanks I'll check those ares. When I got home I shut it off and it fired right up, fired right up this morning, It wasn't until I fiddled with the stop button that the switch worked.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Online Vagrant
« Reply #4 on: September 10, 2023, 07:41:29 PM »
Try to spray the button and off switch with preferably Deoxit or electrical cleaner. Very common on v7 series.
Offline Tkelly
« Reply #5 on: September 10, 2023, 08:40:32 PM »
Same issue on a 2013 v7.
