Author Topic: V85 Mud guard  (Read 4005 times)
Offline inditx
V85 Mud guard
« on: October 27, 2023, 03:58:50 PM »
Thanks to egschade I got this one mounted.
Can’t ride as it’s not nice outside but I think it’ll be a big improvement over the high mounted fender alone.
inditx
inditx
This is the day.....
Offline SailorJack
Re: V85 Mud guard
« Reply #1 on: December 11, 2023, 07:40:46 AM »
Hi Inditx, can you provide info on that mudguard?  How has it been working out?  I like the similar "pyramid" version but for $170, I'd like a cheaper alternative.
« Last Edit: December 11, 2023, 07:48:02 AM by SailorJack »
23 V85TT Adventure
98 VFR800 "Mrs Jones"
Offline jrt
Re: V85 Mud guard
« Reply #2 on: December 11, 2023, 08:58:27 AM »
Another alternative is the fender from a Caponord 1200 Rally, part #2B0024475.  Bolt-on.  At least, that worked on my 2020 version (can't imagine it has changed).
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Re: V85 Mud guard
« Reply #3 on: December 11, 2023, 11:17:59 AM »
I had the Caponord fender on my '22, but lost it in the deer strike.  I don't think I will replace it.  It really didn't keep debris off the engine.  Adding a "fenda extenda" to the Caponord fender is just "too much" for my tastes.
Offline QuickLime
Re: V85 Mud guard
« Reply #4 on: December 11, 2023, 12:12:11 PM »
The new 2024+ V85TT front fender should be available some time next year and looks like it would fit pretty well. Seems like it's essentially the back half of the caponord fender.
Re: V85 Mud guard
« Reply #5 on: December 11, 2023, 12:30:48 PM »
I put the extender on the Caponord fender.  Looks or no, it makes it useful.
I get it, though.
Offline inditx
Re: V85 Mud guard
« Reply #6 on: December 11, 2023, 12:35:03 PM »
It works but IF the 2024 front fender fits and isn’t an arm and a leg, I’d probably opt for that on looks alone.
I like a low front fender personally.
inditx
inditx
Offline QuickLime
Re: V85 Mud guard
« Reply #7 on: December 11, 2023, 01:01:43 PM »
inditx
Yeah, I have the pyramid one and it seems to keep the stator cover pretty clean all things considered. At a certain point there's only so much any fender can do without being unreasonably large ..
Offline Trialsman
Re: V85 Mud guard
« Reply #8 on: December 11, 2023, 02:05:29 PM »
Maybe it is just the old school enduro rider in me but, why not just use a mudflap?  I fashioned one from 1/8" sheet rubber for my first V85.  It worked so well that I did it again for my second one.  In about 25k collective miles on the two bikes there is not one bit of damage on either engine.  The cost was probably about $6.
« Last Edit: December 11, 2023, 02:10:25 PM by Trialsman »
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2026 Bonnell 805 EX
Re: V85 Mud guard
« Reply #9 on: December 11, 2023, 02:21:26 PM »
So, when you stop that bike after a ride and turn the handlebars to full lock to walk away from the bike is the mudflap sitting against the exhaust header?
Is there anything behind there that should be getting more air flow?
Offline Trialsman
Re: V85 Mud guard
« Reply #10 on: December 11, 2023, 03:50:51 PM »
Air flow has never been an issue and I just went out to the garage to check the clearance.  At full lock there is about 1 inch of clearance between the mudflap and the exhaust.
2010 FE570 Husaberg
2024 Stelvio V100
2026 Bonnell 805 EX
Offline egschade
Re: V85 Mud guard
« Reply #11 on: December 12, 2023, 12:48:59 PM »
Which year Caponord front fender fits?
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: V85 Mud guard
« Reply #12 on: December 12, 2023, 01:13:44 PM »
I had to raise this one slightly to get the right look.
« Last Edit: December 13, 2023, 03:48:41 AM by Huzo »
Offline ridingron
Re: V85 Mud guard
« Reply #13 on: December 12, 2023, 04:13:08 PM »
I had to raise this one slightly to get the right clearance.
What tires are you running? I'm running the stock Michelin Anakee tires with no rub on the Caponord front fender.
Offline ridingron
Re: V85 Mud guard
« Reply #14 on: December 12, 2023, 04:16:11 PM »
I'm not sure of the year or if there is a different fender version. This is what I bought. It is working (has clearance) with the '23 stock Michelin Anakee. Like Huzo said, you need to raise it a bit, it's a fairly easy fix.
https://www.af1racing.com/2b001431-usa-front-mudguard-aka-v85-front-fender-2b001431-ex-2b0024475
from an earlier post:
« Last Edit: December 12, 2023, 04:41:24 PM by ridingron »
Re: V85 Mud guard
« Reply #15 on: December 12, 2023, 07:09:58 PM »
Michelin Pilot 5’s
It wasn’t a clearance issue, just the radius was wrong so had to go up 20mm
Offline Speedfrog
  • Vieux motard que jamais!
Re: V85 Mud guard
« Reply #16 on: December 13, 2023, 11:20:49 AM »
I get it, though.
Could you post a picture of it with the Extenda fender?
'04 V11 Café Sport - '14 Griso 8V SE
