Author Topic: I've put it off long enough  (Read 3592 times)
Offline pariah
« on: January 09, 2024, 02:15:06 PM »
Hello. About to start sorting out the wiring on my 1980 'Mock 1' Le Mans. If that doesn't go up in smoke I'll then roll onto the 1973 850 GT.
I'll likely be asking the odd question along the way.
I'm not going the Motogadget way, I'll be upgrading or replacing the existing loom and adding relays, fuses, maybe updating some components.
Re: I've put it off long enough
« Reply #1 on: January 09, 2024, 03:24:32 PM »
Your best source for new harnesses: https://www.thisoldtractor.com/for_sale_wiring_harness.html
Offline Perazzimx14
« Reply #2 on: January 09, 2024, 03:53:59 PM »
Agreed 1000%.
The small amount of money the new harness costs eliminates 10X its cost in frustration and cobbling together 50-year-old discolored wiring and brittle connectors.
Online Bulldog9
« Reply #3 on: January 09, 2024, 05:23:35 PM »
Beat me to it Charlie! I did the full harness on my Convert, was super easy, plug and play, and worked perfectly. Greg is an awesome vendor and enthusiast.
MGNOC#23231
Offline pariah
« Reply #4 on: January 10, 2024, 01:23:11 AM »
I've been looking at Greg's harnesses but I may build my own, for a bunch of reasons. I'm over in Finland so importing stuff isn't cheap is one.
I'm also retired and enjoy wiring, and there seems to be a lot wrong with the original Guzzi harness design that I'd like to improve. The whole hot ignition, lights and coils for example, and the starter circuit. I'm looking to relay lights, horn and coils. I'd also like to install Deutsch weatherproof connectors on the harness.
My Le Mans was a LM II conversion and has piranha electronic ignition, stock fusebox, regulator and rectifier, coils under the tank and I think it has the Bosch alternator with the energised rotor. I'd like to add a weatherproof fuse/relay unit, new coils, and likely change the electronic ignition.
Switches, lights, the whole front end was rewired, but I've only just started digging so I'll see how it looks
Offline Scout63
« Reply #5 on: January 10, 2024, 07:46:22 AM »
Wiring is an exercise in chasing perfection. Like lacing wheels, it has to be learned slowly.  I’ve done Motogadget and it was a great but time consuming and expensive experience. In retrospect I wish I had started with a simpler bike first, not the G5. Quality wire in different colors, tools,  terminal gear, looms and heat shrink get expensive quickly.  I cut out and re-fabricated so many sections that didn’t fit or look right as I went along. I’m lucky that my current v7 sport project came with a full Greg Bender harness ready to install.  It’s sitting in the garage, exquisitely bagged and labeled and whispering to me…
Ben Zehnder - Orleans, MA USA
« Reply #6 on: January 10, 2024, 09:56:58 AM »
Perhaps put a location in your profile? That helps us to recommend sources (or not).
Offline Moparnut72
« Reply #7 on: January 10, 2024, 10:17:04 AM »
I wish everyone would put their location, or at least a general location. There are at times I would respond with advice but don't bother not knowing where the OP is located which is needed in some cases.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Vagrant
« Reply #8 on: January 10, 2024, 10:29:04 AM »
AMEN! No matter where you live hordes of bike thieves will not show up looking for your Guzzi!
Offline acguzzi
« Reply #9 on: January 10, 2024, 12:43:28 PM »
mine also runs piranha ignition, never had an issue.
Offline Stretch
« Reply #10 on: January 11, 2024, 06:34:45 AM »
I've got some things in my garage like that, too!  :grin:
                                                 -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline pariah
« Reply #11 on: January 12, 2024, 03:18:02 AM »
Done, and thanks for the reminder
Offline pariah
« Reply #12 on: January 12, 2024, 03:20:01 AM »
Good to hear. I've found some information on the system, originally by Newtronic? It's working so I'll run with it for now.
Offline pariah
« Reply #13 on: January 12, 2024, 03:25:12 AM »
I have to say I laughed out loud when I saw this. The LM 1 conversion appears to consist of cutting off the three original Molex connectors, then splicing in the handlebar switchgear, headlight, indicators, horn and ignition. No correct wires, insulated crimps (badly done, a few came apart in my hands), no relays
Birdsnest wrapped in old inner tube
Online Mayor_of_BBQ
« Reply #14 on: January 15, 2024, 12:19:22 PM »
Wow, what a mess! LoL
« Reply #15 on: January 16, 2024, 01:22:49 PM »
What could possibly go wrong?  :smiley:
Offline pariah
« Reply #16 on: January 26, 2024, 02:44:20 AM »
Got the loom off at last. Tagged everything I could, resisted the temptation to just cut it out.
Snakes alive!
picupload
Alternator revealed. Assume this is the Bosch system with the charging coil I've been reading about?
image post
Today is multimeter day, need to ID all the handlebar switch wires (every single wire is connected to brown :) ) and test some of the bits like coils, reg/rec etc
Online John A
« Reply #17 on: January 26, 2024, 08:15:52 AM »
You didn’t need to strip all that wiring off, just run new wire over the top of it!  Har Har!
Seriously though, rewiring makes one plan ahead. The three yellows from the alternator usually need some attention at their first connectors behind the steering head. They have a habit of getting loose and corroding .
« Reply #18 on: January 26, 2024, 08:51:00 AM »
Snakes alive!
picupload
image post
If you try to re-use that plastic(bakelite?) connector you will need female connectors with a tab to keep the three wires connected to the plastic part.
