Yes, that bike came with the plastic caged bearings.Yes, the labor costs to replace are pretty high. And the bearings are a bit pricey too.But, just use dead dino juice and ride it.Worry less, ride more.Maybe think about replacing them if you have the clutch replaced. Ignore it otherwise.
I just pressed the hypothetical “like” button
Evidently hasn't broken in 24 years like they haven't broken in my 23 year old Stone. I don't lose any sleep over it. Ride it and use dead dinosaur oil.
Does anyone know what years of Guzzi 5 speeds have the plastic caged bearings? I remember my 73 eldo did not have them, from back when I shimmed my shift drum.Rick.
Regarding plastic caged bearings, something about that seems prone to failure. And that worries me because the words prone to failure on a motorcycle makes me a little nervous. Is this something I should be looking into swapping out or should I just not worry about it on my 24 year old Jackal? Is swapping them out an expensive or over burdensome venture?I guess I am probably looking to calm my nerves about it more than anything but I also want to know, ya know?
I was wondering if my 98 EV would have the plastic bearing cages? In reading that Georges EV had the issue, and it looks like his is a 2003, I would guess my 98 has the plastic cages, as well.Rick.
LOL! The myth continues.
Dino vs non-dino???
Are you talking about George the iowa MGNOC rep?
Though it's well understood what is meant by "dino oil," the term is a misnomer.https://www.powells.com/post/original-essays/does-oil-come-from-dinosaurs
You guys got me curious, so I sent a message to the experts inquiring about lubrication for bearings with "plastic" cages.https://www.skf.com/us/support/contactI saw my first one ever yesterday. SKF # BB1B 420205. Non-standard size 25mm x 52mm x 12mmI agree with Charlie, I was a bit surprised to only see 8 balls between the races. I think a more "normal" number would have been 10-12.If I hear back from SKF, I'll let you know what they recommend.
