Author Topic: V85TT OEM TPMS  (Read 2876 times)
Offline azccj
V85TT OEM TPMS
« on: February 15, 2024, 10:22:56 PM »
So today I went for a 300 mile ride on my V85TT. As I was heading home, about 10 miles from my house and just after I hopped on a freeway, I noticed my dash had changed to the TPMS screen and there was a red triangle next to the rear tire indicator with 15 PSI showing. I quickly pulled to the right lane, slowed then stopped in the gravel about 20 feet from the emergency lane, as the rear tire indicator showed 7 PSI. Bummer!! BUt I did have my emergency bag which contains my mini compressor, tire plug tool, and a light so I can see what I'm doing. Upon looking at the rear tire, which was still hissing, I quickly discover it had been punctured by a 3 inch wood screw.  I think no problem, I'll be back on the road in 15 minutes or so with the back tire plugged well enough to get me home. BUt then I discover that I must have forgotten to put my all time favorite tire plug tool back into the emergency bag when I came back from Washington last September. I call my girlfriend who was nice enough to stop at an auto parts store and get a tubeless tire repair kit. She arrived about 45 minutes later, and I quickly plugged the tire and rode home.
I will say that I do like having the OEM TPMS on the V85TT, but the way MG decided to alert the rider when there's a tire problem could have been done a lot better. By the time I finally noticed the screen, the tire pressure was down to 15 PSI, I have no idea how long the screen was indicating a tire problem, as nothing on the dash was flashing to get your attention, unlike that stupid cruise control light does to warn you that the world is about to end because the cruise control is turned on but not engaged. MG logic??? :shocked:
Best ever tubeless tire repair tool,
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Re: V85TT OEM TPMS
« Reply #1 on: February 16, 2024, 05:58:48 AM »
The V85TT has TPMS?
Offline azccj
Re: V85TT OEM TPMS
« Reply #2 on: February 16, 2024, 11:10:30 AM »
The 2022 V85tt Travel version came with the TPMS. I don’t know if it was included with the 2023 models.
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Re: V85TT OEM TPMS
« Reply #3 on: February 16, 2024, 09:40:52 PM »
Interesting.  Wish I had know that when I got the tires changed.  Would like to add TPMS for touring.
Offline guzziart
Re: V85TT OEM TPMS
« Reply #4 on: February 17, 2024, 06:44:04 AM »
FWIW......https://www.walmart.com/ip/Motorcycle-TPMS-Solar-Power-Tire-Pressure-Monitor-Real-Time-Tire-Pressure-Monitoring-System-Temperature-Sensor/5309621136
However, I'm kinda skeptical about the accuracy & reliability.
Art
'72 CL350, '72 Eldo '87 LMIVSE, '91 CT70, '08 Wing, '23 v85 Travel
Re: V85TT OEM TPMS
« Reply #5 on: February 17, 2024, 07:37:05 AM »
Art
Interesting.  It doesn't have to be accurate, but does need to be reliable.  Set the tire pressure with whatever means you trust, screw it in and that is your new normal PSI.  I am more interested in knowing when I am losing air than what the air pressure is on a given day.
Online Wayne Orwig
Re: V85TT OEM TPMS
« Reply #6 on: February 17, 2024, 08:31:03 AM »
I'm with you on the cruise control light. Is that the oddest thing.
Blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink, blink.
Online Moparnut72
Re: V85TT OEM TPMS
« Reply #7 on: February 17, 2024, 08:56:21 AM »
You will get used to it. It drove me nuts for awhile on my 1400 but I got used to it. On my V100 I hardly even notice it.  :thumb:
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
Offline QuickLime
Re: V85TT OEM TPMS
« Reply #8 on: February 22, 2024, 02:46:55 PM »
AF1 sells the TPMS kit, it's around $300 calibrated I believe, so not cheap, but also not insane for a factory integrated system. It's pretty accurate in my experience.
Online Perazzimx14
Re: V85TT OEM TPMS
« Reply #9 on: February 22, 2024, 03:37:04 PM »
Art
I ran several set of these type aftermarket TPMS and they were accurate to 1 PSI +/- of my digital gauge. IN fact I still have two sets in the garage. I paid $15 on Amazon a year or so back for them.
After 5000 miles using the shortest rubber valve stems possible (TR412) this is what they looked like:
If you are going to use aftermarket external TPMS with a peckerhead sensor I encourage you to change over to metal valve stems.
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline egschade
  • Eric - MGNOC NJ Rep - mgnocnj.forumotion.com
Re: V85TT OEM TPMS
« Reply #10 on: February 23, 2024, 06:24:35 AM »
I'm using a $30 Amazon unit that has been working fine for the past 2+ years. Is accurate to within a couple PSI and offers good peace of mind for both punctures and me running sealed rims on my V85TT.
The elder Eric in NJ
2024 Triumph 400X Scrambler
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
