Author Topic: Plastic Repair on Fairing Exterior  (Read 2294 times)
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« on: November 07, 2024, 02:07:51 PM »
I’ve repaired ABS on the backside where looks don’t matter much, but is there anything I can do to repair the Lario’s fairing to where I can get it back to looking like new’ish on the exterior side? The fairing has begun sagging and bouncing a little due to the upper mounts being weak, and the counterforce of the immovable brake reservoir is leading to the damage, or so I’ve surmised since this all happened before I bought the bike.
Fiberglass backing on the inside > Bondo? > sand and polish?
Also: looks like there already was a previous repair attempt, based off the melted look of the plastic.
Pics below:
« Last Edit: November 07, 2024, 06:35:41 PM by Dirk_S »
Online nc43bsa
Re: Plastic Repair on Fairing Exterior
« Reply #1 on: November 09, 2024, 06:24:23 PM »
I've had success on small repairs with ABS glue or acetone and LEGO blocks.  Rough up the original surface, mix up a thick paste, and spread it on.  Once it sets, grind or sand it even and repeat until smooth.
I haven't tried this method on a large repair such as yours.
1990 MilleGT
Offline Dukedesmo
« Reply #2 on: November 10, 2024, 06:11:27 AM »
What plastic is it?
Fibreglass will need fibreglass repair but if it's the stuff modern bikes/cars are made from it may respond well to plastic welding - done with a large, flat soldering iron and some cable ties as filler.
My Son recently hit a deer in his car which smashed up the front end and whilst I did get a new front for it, the temporary repair that I did by welding held up really well and the only reason I got a new front was that it (aftermarket) was cheaper than getting the repaired front professionally resprayed.
Le Mans II
Ducati 916
Ducati M900
