Author Topic: Norge LCD Replacement  (Read 6596 times)
Online blackcat
« on: May 27, 2025, 07:42:50 AM »
It appears that the LCD on my 07 Norge has gone bad so I need to have it fixed or buy a new one.  I have found a later model dash which they claim will work on a 1200 Breva/Norge from a source in Italy for $700 delivered compared to well over $1,200 from AF1. Has anyone installed a dash from a later model Norge on an early model bike? From my research on WG, the other option is to send the unit to Carmo Electronics in Amsterdam and see if they can fix the unit but that seems to be a hit and miss success.
As a side note, has anyone removed the back panel on the LCD to gain access to the corrupted board?
Offline moto
  • Fear the deer!
Re: Norge LCD Replacement
« Reply #1 on: May 27, 2025, 09:13:40 AM »
Yes, others have opened the dash to reveal the circuit board. I found a good discussion and photos here:
https://www.guzzitech.com/forums/threads/bns12-dash-repair.15418/
A brush-on conformal coating will prevent further damage if you are able to fix it. Be careful not to cover the air pressure sensor.
I remember a substitution of one version of this dash for another one. Some functions did not work, though the result was usable. You might compare the pin-out of the dashes in the appropriate manuals.
I took my Griso's circuit board to a computer repair tech who did micro-soldering. He said the board's components were all ordinary and that he could easily repair the unit. (The Griso dash is a simpler version.)
I've lost track of him.
850 T-3
Griso 1100 corretto
Online blackcat
« Reply #2 on: May 27, 2025, 09:38:13 AM »
Thanks, I got the face off and will try to remove the needles now that I see that this how to get to the board. I’ll post some pictures when I get it opened.
Online blackcat
« Reply #3 on: May 27, 2025, 10:12:15 AM »
I have found the problem:
I wonder if that small black part can be replaced by a computer guy?:
Offline nc43bsa
« Reply #4 on: May 27, 2025, 11:01:01 AM »
I think what I see in your photo is a resistor.  GM had many clusters in the 1990s that had problems with resistors that would fall off the circuit board and the display would go blank.
Where are you located?
1990 MilleGT
Online DoubleGuzzi
  • '08 750Breva; '19 V7III CS; '79 V50;(Triumph S400)
« Reply #5 on: May 27, 2025, 11:11:43 AM »
Easily fixed (for many). Don't need a computer guy but an electronics tech. or just someone that's decent at soldering.
Once the correct part (a couple of bucks worth) is sourced, it would take about 5 minutes to replace, taking one's time.
« Last Edit: May 27, 2025, 11:16:54 AM by DoubleGuzzi »
Nearly natural progression..
Past: SS50, Z200, Z250B, Z400J, (H100), GT750, K100, ZR1100, 900 Trident, 955 Sprint ST, (ZR550, M600), 900 ST. Present: (B750), V7III CS, (V50II).
Offline Pescatore
« Reply #6 on: May 27, 2025, 12:05:56 PM »
I'm not sure what it is.  Could be a resistor, a cap or even a diode.
A cap sometimes fails like that on its own.
If not a cap that component didn't smoke on its own.
Something died on that board and created a lot of current.
A close up shot might help tell what it is.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Online DoubleGuzzi
« Reply #7 on: May 27, 2025, 12:57:39 PM »
Click on the pic - you can see the insulation has broken down.
There's been a lot of heat in that area and agreed it isn't easy to determine the root cause of the failure but it may just be down to that one component going faulty. A circuit diagram or electronics guru should help identify the component.
Online blackcat
« Reply #8 on: May 27, 2025, 01:10:01 PM »
The writing on the part indicates that it might be a diode #PJ65-GS1M
https://www.digikey.com/en/products/detail/smc-diode-solutions/GS1M/6022522
Offline Pescatore
« Reply #9 on: May 28, 2025, 01:36:10 PM »
Idk, Without a schematic or possibly tracing the connections, it's a gamble.
I would have Carmo repair it because I see two burn marks on the plastic.
More stuff broken besided the diode.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Online blackcat
« Reply #10 on: May 28, 2025, 03:39:06 PM »
Yes, there does appear to be two burn marks but for the life of me I can't see where the second burn is on the board. I will contact Carmo and see if I can send them the photo's and see what they say as I really don't want to send this to Amsterdam and they can't fix the problem.
Offline moto
  • Fear the deer!
« Reply #11 on: May 28, 2025, 03:54:26 PM »
I looked at Carmo's page yesterday I believe they will say it will cost $400 for them to repair it no matter what was wrong. I would try to do my own repair first before agreeing to that. After all, I don't see why they would object to repairing it for $400 after I tried and failed.
850 T-3
Griso 1100 corretto
Online blackcat
« Reply #12 on: May 28, 2025, 04:41:23 PM »
If I'm going to spend $400 bucks plus shipping there and back, it will be over $500 and at that price I'll just buy a new one for $700 bucks delivered. But I did send Carmo the photo's so will see what they say.
Online DoubleGuzzi
« Reply #13 on: May 28, 2025, 04:44:00 PM »
If we assume that the component IS the same as the other three in that bank, then I'd be inclined to buy 4 (or 5 may be cheaper) and replace all of them.
Online DoubleGuzzi
« Reply #14 on: June 10, 2025, 04:07:48 AM »
Wondering if any progress has been made..
 :popcorn:
« Reply #15 on: June 10, 2025, 08:54:31 AM »
 :popcorn:
I sent Tom another dash to try. Mailed on May 29th, it was in Pensacola (where he lives) on June 4th, but then the USPS decided it needed to take a tour of the west, so on the 7th it was in Avondale, AZ! WTF?
Online DoubleGuzzi
« Reply #16 on: June 10, 2025, 09:29:09 AM »
.. but then the USPS ..
At least it ain't UPS "Consider it nicked" - they 'lost' a parcel that I got sent to AZ, a couple of decades ago.  :lipsrsealed:
Online blackcat
« Reply #17 on: June 11, 2025, 07:35:02 AM »
It arrived back in town today and I may go to the local PO and ask them to make sure it doesn't leave town again. Unfortunately if it doesn't get here today (unlikely) I am leaving town tomorrow and will be in Virginia until Monday, had I known it was going to take this long I would have just taken an extra trip to Charlies to pick up the dash.
Edit: Just got a text that it's out for delivery!
« Last Edit: June 11, 2025, 08:29:19 AM by blackcat »
Online blackcat
« Reply #18 on: June 11, 2025, 11:30:00 AM »
It showed up and I plugged it in, entered all zeros, I hit the button and the bike started!  The service code popped up but not the oil can which is where this started but I replaced the oil sender switch. I need to erase the code or codes and see if that removes the message but it does have the service wrench on the screen so maybe that is the issue? The battery is charging right now so will see what happens after it’s been charged or I will just swap in another battery.  When I did try to start it again, it asked for the code but I assume that I need to specifically enter a new code in the program. But it’s promising.
Thanks again Charlie.
Online DoubleGuzzi
« Reply #19 on: June 11, 2025, 11:32:44 AM »
So will you attempt a repair of the original, yourself?
 :popcorn:
Online blackcat
« Reply #20 on: June 11, 2025, 01:28:48 PM »
 :popcorn:
No, I am going to take it to a couple of local computer repair places and see if they will solder in one or two diodes unless they want a stupid amount of money and if that doesn't pan out I am going to contact the guy who replaced the diodes on the dash of our 05 Prius. Removing that dash was not a nightmare but wasn't exactly fun and I didn't want to attempt that fix twice or possibly ruin the board so I paid him the $40 bucks for the guaranteed fix.
But before I install this dash from Charlie I'm going to do the search for whatever product others recommended for coating the circuit board to protect it from water.
Offline moto
  • Fear the deer!
« Reply #21 on: June 11, 2025, 02:10:51 PM »
This is the coating I used, and a UV flashlight I bought to check its coverage (both from Amazon).
There was a very fragile, multi wire connector between the main PCB and something else that had to be removed or detached before I could get to the other side of the PCB in order to coat it also. I nearly broke it. I don't see this in your photo so maybe the design was changed, but this is something to watch out for and maybe to ask your electronics guru to help you with.
« Last Edit: June 11, 2025, 02:30:52 PM by moto »
850 T-3
Griso 1100 corretto
Offline moto
  • Fear the deer!
« Reply #22 on: June 11, 2025, 02:39:28 PM »
By the way, that black rectangular plastic housing with four corners cut out that you can see in this clipping from your photo contains the air pressure sensor that your bike needs to set the mixture. So don't cover it up with conformal coating.
850 T-3
Griso 1100 corretto
Online blackcat
« Reply #23 on: June 11, 2025, 02:44:46 PM »
Have a hitch, the dash will light up and bike will start only after the code is inserted, there are no ECU errors but there are dash errors:
01: Immobiliser fault: key code read but not recognized or key code not read
03: Immobiliser fault: antenna broken(open or short circuit)
04: Immobiliser fault: internal controller fault
06: Air temperature sensor fault
07: Oil sensor fault DSB
Thanks Moto, I will purchase the coating and UV flashlight once I get this all resolved.
Edit:  I figured it out, the original key had to be matched to the dash so now it starts without the code and the warnings on the dash are gone.
« Last Edit: June 11, 2025, 04:22:13 PM by blackcat »
Offline Huzo
« Reply #24 on: June 11, 2025, 03:26:10 PM »
Jeez I hate this crap…!
Just thinking about those beautiful 1100 Sports with smelly snorting carbs and loving the relative simplicity of them.
Offline Huzo
« Reply #25 on: June 11, 2025, 03:27:31 PM »
Are they as misty in reality as they appear in the shot ?
These are mine on an ‘07
« Last Edit: June 11, 2025, 03:34:45 PM by Huzo »
Online blackcat
« Reply #26 on: June 11, 2025, 03:47:26 PM »
I'm pretty sure that is a piece of packing plastic covering the dash.
Offline Huzo
« Reply #27 on: June 11, 2025, 03:54:56 PM »
Ahhh….
Proper reading of original post and glasses on now… :embarrassed: :undecided:  :rolleyes:
Offline old head
« Reply #28 on: June 11, 2025, 04:37:40 PM »
FYI, I have emailed Carmo a couple of times, never got an answer.
So if they respond to you let us know, as I need my LCD replaced.  it has a big blank spot in the middle, making the screen useless
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Online blackcat
« Reply #29 on: June 11, 2025, 05:04:29 PM »
They never returned a response to my email and I decided that if I'm going to spend a minimum of $500 with shipping back and forth of my old dash that I would just buy a new one from the supplier in Italy who did respond to me regarding the code. $645.51 + approximately $46 for shipping.
If you are going to take that route they are on eBay:MOTO GUZZI BREVA NORGE SPORT 1200 INSTRUMENTATION DASHBOARD MPH/KM GREY-show original title
deal_ricambi
(774)
