Author Topic: Greasing splines  (Read 3390 times)
Online nwguy
    • Jim Gallant's home page
Greasing splines
« on: June 02, 2025, 12:32:19 PM »
Still going through my 99 Bassa with 66k miles, now with the rear wheel removed for cleaning and bearing replacement. While the wheel's off I understand I should grease certain splines. Am I correct, after cleaning things, I should grease the splines shown in the pics below? Wheel bearing grease OK?
Based on comments in this thread:
https://wildguzzi.com/forum/index.php?topic=78660.0
I should also, ideally remove the swingarm to inspect the cardan joint and grease the swingarm bearings. I've been reading the manual I have and it looks like a significant job with special tools. Am I wrong about this?
Online pehayes
Re: Greasing splines
« Reply #1 on: June 02, 2025, 04:31:37 PM »
Yes and yes.
Sparingly on the wheel spline or it will fling up on the wheel.
More liberal on the drive shaft inside the swing arm.
Offline moto-uno
« Reply #2 on: June 02, 2025, 04:38:23 PM »
  I tend to grease the rear wheel and drive shaft splines every time I remove the rear wheel , so I'm not looking for some magical life time lube ( in other words almost any high pressure grease is fine) . Lubing the swingarm is another matter , wheel off , I then remove the 2 lower frame bolts and nuts (2 on each side) , this allows easier removal of the swingarm assembly (shocks will require removal from swingarm) . Mark each swingarm nut . Remove the plastic caps from each nut , under them is a allen bolt receptacle , then crack the locking nut and continue to unscrew it with the allen key , this will allow you to correctly position the swingarm when reassembling . Might be a good idea to have a new boot handy and to soak the inside of the frame around the swingarm bolts with WD40 before undoing them ! Good Luck .
« Reply #3 on: June 02, 2025, 05:36:07 PM »
Make sure the boot is clamped evenly, the one on my V7III was held in place by a Q strap which is totally inadequate, water sprayed up from the front wheel would hit the boot right where the tail goes through the ratchet and enter the shaft tunnel, causing the splines to rust and level in rear pumpkin to be over fill.
I found a better worm drive clip that seems to have resolved that problem.
Offline bronzestar1
« Reply #4 on: June 02, 2025, 10:15:02 PM »
Just as with different colors of coolant, I seem to remember there being different colors of grease as well.  I usually have some dark green grease for general purpose use, but I also have a tub of a reddish-pink color grease, which I think is what can be used on the splines and other parts of the shaft drive.  I miss that about my old '95 1100 Sport, it had an exposed drive shaft with grease fittings for the u-joints at the front and back.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #5 on: June 03, 2025, 10:33:09 AM »
One should NEVER underestimate the importance of color co-ordination when it comes to lubricants!!
2019 Beta EVO 250
Online nwguy
« Reply #6 on: June 03, 2025, 01:47:16 PM »
My new Chinese wheel bearings had blue grease.
Offline moto-uno
« Reply #7 on: June 03, 2025, 02:51:34 PM »
  And I guess I should've mentioned to clean the old grease out before using new grease . All those little wear bits stay in the grease .
Online SIR REAL ED
« Reply #8 on: June 03, 2025, 05:47:14 PM »
Does it match the paint?
2019 Beta EVO 250
