Author Topic: Cafe-inspired V9 Project  (Read 26000 times)
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: V9 Project
« Reply #30 on: July 21, 2025, 07:01:02 AM »
Reading this article and seeing a video about this build they had to modify the rear drive somehow, which is not clear, but it wasn't a bolt on job.
Yeah, I spoke with him briefly yesterday. He said it was the only part they had to make from scratch for their builds.
« Last Edit: July 21, 2025, 08:36:54 AM by Dirk_S »
Offline Aldo
Re: Monza/Le Mans-inspired V9 Project
« Reply #31 on: July 21, 2025, 08:12:39 AM »
Great looking bike, really love how it came out!
What did you do regarding the fuel pump etc? Is everything external now or did you modify the Monza tank?
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambo 1000 Automatic
1960 Gilera Giubileo 98
Online Dirk_S
« Reply #32 on: July 21, 2025, 08:45:23 AM »
I bought a used external system off an early 00s EV big block. The one I bought had the regulator that runs inline with the pump and filter, but then I bought a tank-fitted regulator and placed on the right side petcock fitting. Using a high-flow manual petcock on the left.
I’d love to install an in-tank setup. Maybe one day, but I don’t know if I can avoid the internally welded nuts part. Might have to bite the bullet there.
BTW, big shout-out to Charlie @ Antietam Classic Cycle for helping me LOADS with the fueling system.
Online DoubleGuzzi
« Reply #33 on: July 21, 2025, 04:51:34 PM »
I wonder if pop rivet captive nuts (blind rivet nuts) would be a good alternative - easier than welding? There are versions with an integrated seal.
« Last Edit: July 21, 2025, 08:21:28 PM by DoubleGuzzi »
Nearly natural progression..
Online Dirk_S
« Reply #34 on: July 21, 2025, 08:26:34 PM »
RIVET NUTS ARE A THING!? With a seal, that could indeed be an enticing option.
Online DoubleGuzzi
« Reply #35 on: July 22, 2025, 03:49:30 AM »
https://www.huyett.com/blog/what-is-a-blind-rivet
I assume these ones are expensive:
https://www.boellhoff.com/gb-en/news/2021/blind-rivet-nuts-and-studs-with-integrated-sealing-solution-rivkle-seal-ring/
https://www.gesipa.co.uk/products/technologies/g-sealed-blind-rivet-nut/
https://www.bossard.com/eshop/global-en/rivet-technology/blind-rivet-nuts/closed-end-blind-rivet-nuts/tubtara-dpx/p/25108/?category=02.200.200.10&index=26&q=%3Arelevance#tab-features
Shop around.  :wink:
IF the fuel pump flange seal fits around the perimeter, outside the retaining bolt holes, then you'd likely get away with not needing the sealed rivet nuts. You may get dribbles of fuel sitting in the flange void though. YMMV
A while back, I bought a boxed assortment from AliXpress, for my various farkles. Non-specific/generic rivet nuts tend to have a larger minimum contact area though i.e. the material thickness that you want to attach them to.
« Last Edit: July 22, 2025, 04:12:11 AM by DoubleGuzzi »
Online Dirk_S
« Reply #36 on: November 17, 2025, 03:52:35 PM »
Before I put the bike in storage for the winter, I was able to take care of one more modification. Just like on my V7 III enduro, I dumped the stock 350mm shocks for a pair of 380mm Hagons fit to my weight. Aesthetically I felt the rear of the bike sagged down, harkening to its cruiser style origin, and I wanted to push for a slightly more fast-aggressive look. The lower shock mounts sit maybe an inch farther back on the V9’s final drive than on the older style pumpkin of the V7 III, so the rear sits a hair lower—and doesn’t stress the UJ as much—than my V7. I like the look, especially because the tank doesn’t appear to climb in the front as much.
Before:
…And after:
Over the winter I hope to swap out the V9 triples and wheels for a V7’s, clean up the bikini fairing a little…and who knows what else.
« Last Edit: November 17, 2025, 04:02:34 PM by Dirk_S »
Offline bad Chad
« Reply #37 on: November 17, 2025, 05:55:15 PM »
Really looks great!    I would ditch the ballon front tire (I am not a fan of fat front tires, just personal taste) put on something a bit more svelte and you will have a show winner.
Online Dirk_S
« Reply #38 on: November 17, 2025, 06:51:49 PM »
Appreciate that, Chad, and agreed! I’ve seen some custom sporties that used the balloon tires, but a skinnier 18” front will handle so much better. Heck, I’m considering lacing up an 18” for the rear, or just sticking with a V7 17” rear. If I can get it close to this concept that I rendered, I’ll be a pretty happy camper:
« Last Edit: November 17, 2025, 07:51:21 PM by Dirk_S »
Online faffi
« Reply #39 on: November 18, 2025, 01:59:54 AM »
17in wheels would likely be cheaper conversion, but 18in would be more true to the original Monza and LeMans. Both would be a huge improvement over the fat 16inchers.
Also, I believe the double U-joint system will tolerate the more acute swingarm angle with longer shocks better than the older system.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
« Reply #40 on: November 18, 2025, 05:18:22 AM »
It’s well on the way…
Rear is a bit too low, the top frame rail should be parallel with the ground. Also, are you going to ditch the wagon wheels ?
One thing is certain, it’s more attractive than a V9…
Online Dirk_S
« Reply #41 on: November 18, 2025, 08:23:59 AM »
Yep, looking to replace the wheels. I mentioned that below the photos, but that text is easy to miss.
Huzo, you think the rear still sags a bit much, even with the new shocks added (bottom two pics)? Some of that may be optical illusion, as the front of the tank does stick up a tad in relation to the horizon of the frame. This is partly due to the extra big heads of the V9 preventing me from properly setting the tank perfectly level, but also, the V50 Monza never had the perfectly straight juxtaposition of line aesthetics like its Le Mans III big sister. I will probably redo the rear mounts for the seat to lift the back up a hair more, which should help.
I was hoping to do cast wheels, but if I decide to go 18” in the rear, I’m not sure that the old V50/V65 18” wheel will mate to the final drive and caliper without modification. I could possibly add spacers or modify things just enough to work, or I could make life simpler by building a spoked wheel.
Re: V9 Project
« Reply #42 on: November 18, 2025, 10:33:16 AM »
After going through the hoses a few times, tightening clamps here and there, she’s back on the road. Here are some pics:
And the walk-around video:
https://youtu.be/xusNY1T-I8M?si=HzI2OMwuKV20wrWa
I still want to add a headlight cowl/fairing, clip-ons, lift the rear, paint the rims, clean up some areas (rear seat bracket), set the foot controls back, maybe some bar-end mirrors, and give it a paint job. Maybe a stainless exhaust one day, too.
I like the styling but don't get the fat tires.  That negates the performance and the sporty styling.
Re: V9 Project
« Reply #43 on: November 18, 2025, 10:45:59 AM »
Umm... did you read his latest post?
…And after:
Online Dirk_S
Re: V9 Project
« Reply #44 on: November 18, 2025, 10:53:37 AM »
The wheels and tires will be ethically tossed off the pier, given to the local go-kart track as a tax-exempt, charitable donation, or sold.
« Last Edit: November 18, 2025, 11:07:58 AM by Dirk_S »
« Reply #45 on: November 18, 2025, 02:06:29 PM »
You already have a bit more angle on the universal joint than ideal and if you lengthen the rear shocks any more, you’ll exacerbate that. In addition there is not enough clearance between the front fender and motor.
To get rid of the “dropped rear” look, you’d have to raise the back and/or lower the front, neither of which is a viable option.
Thinning out the wheels by installing spoked items would massively improve the above situation and removing a lot of the black will take away the “heavy/fat” look. As you’ve acknowledged, it’s the wheels that really are the elephant in the room, but I congratulate you on succeeding in getting another V9 off the public roads, whilst still being able to enjoy what is reputedly a beautiful incarnation of Guzzi’s 850 V twin.
Grafting an 18” wire wheel into the rear of your bike might be massively difficult, but if you can find a spoked hub that will mate up, or can be made to do so, then the rest is easy(ish).
Front is no problem.
Measure and compare the outside diameter of an 18” tyre versus what’s currently in your bike, if the 18” is larger, then that’s the way to go.
It’s a damn interesting project though…. :popcorn:
Online Turin
« Reply #46 on: November 18, 2025, 02:12:26 PM »
Looking really slick! :thumb:
1985 Sidlow Guzzi
« Reply #47 on: November 18, 2025, 02:39:57 PM »
Dirk- This looks awesome, love where you are headed!!  As someone else said (do we have genZ'ers in here now?) This goes hard AF
Online faffi
« Reply #48 on: November 19, 2025, 01:18:49 AM »
Theoretically, a 100/90-18 is 25.1in i diameter. A 130/90-16 is 25.2in, so marginally larger. A 110/90-18 is 25.8in in diameter.
You can play all day long here https://www.calculator.net/tire-size-calculator.html. I like it because you can compare two sizes at once, and you can change just one value at the time without putting in all the information over and over.
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online Dirk_S
« Reply #49 on: November 19, 2025, 06:23:15 AM »
Ive used those tire calculators a few times for both this custom and also my V7 III enduro build, when I was deciding whether or not to build an 18” rear. Anyway, I’m planning to go with an 18” for the classic look and to make it lighter both aesthetically and physically.
« Last Edit: November 19, 2025, 06:46:00 AM by Dirk_S »
Online Dirk_S
Re: Cafe-Inspired V9 Project
« Reply #50 on: April 28, 2026, 02:41:04 PM »
Update time!
I ditched the Monza look. I knew I wouldn’t be happy with the lines, and I’d be chasing mods forever. Looked too much like a sport cruiser to me. I figured I’d be better off going back to my usual affinity for cafe racers.
A few things bug me about the factory cafe bikes that Guzzi has offered over the years, so this V9 platform offers me a chance to personalize to my taste and see if I can do a little better, subjectively speaking.
I threw the Monza tank and saddle into the ocean, but kept the rear mudguard and lights. Tossed on the V7 tank from my modded V7 III Rough (bought another used V7 tank for that one). The knee pads will be removed at some point. I bought a stock V7 seat and plan to make a rear cowl for solo riding. Installed a set of headlight mounts that poke out a bit farther so that the headlight cowl fits a little better. The headlight cowl will eventually be painted, but I also don’t guarantee that it’ll always stay on. With the dash gauge lowered and clip-ons installed, the front profile looks quite classic cafe IMO. I have V7 III triples installed now, with the V7 forks, allowing for a 2.50x18 V7 front wheel to hop on.
The icing on the cake is definitely the 2.50x18 rear wheel, which I added along with a V7 swingarm, final drive, and driveshaft. Got tired of trying to make the spare V9 final drive. Jumping over to a V7 rear drive line shaves weight, and that skinny rear looks the part.
Still to do:
  • Remove the stock airbox and install a pod filter
  • Swap out the V9 cans for upswept mufflers that also sit closer to the frame.
  • Get rid of the black on the pipes
  • Make a removable seat cowl
  • Swap out the V9 lower frame rails for a set of standard or racer V7 frame rails (to move the foot controls back).
  • Decide whether to stick with the modern egg-shaped blinkers (front) or the old rectangular corner lights (on the rear).
This is a definitely a look that I’m not struggling with. And oh, how nice it is to have the V9 out of the basement and back on the road. The punch of the V9 motor mated with the cafe aesthetics, a smirk arises everytime I’ve ridden so far.
« Last Edit: April 28, 2026, 03:49:32 PM by Dirk_S »
Online turboguzzi
« Reply #51 on: April 28, 2026, 03:43:22 PM »
nice too, but got to say that previous iteration was much more special.
im a sport riding guy, but that "fatboy le-mans" was VERY unique IMHO. Never seen anything like it, and in the good sense...
now its more of "another cafe racer"
nothing wrong in that of course
Offline Motormike
« Reply #52 on: April 28, 2026, 03:43:45 PM »
I think it looks great!  The Lemans' fairing really finishes the look.  Interestingly, I think the large front tire works better without the fairing and using the oversize headlight.  With the fairing, the fat tire is more out of place.  Fantastic result in any event.
Online faffi
« Reply #53 on: April 28, 2026, 04:16:17 PM »
Funny, it's just a couple of days ago that I thought about how difficult it would be to make Lemon replica out of the V9, and if the swingarm and final drive from the V7 Classic would fit. Then I see you have already done this, and more :thumb:
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online Dirk_S
« Reply #54 on: April 28, 2026, 05:02:50 PM »
Yup—up to ‘21, the V9 shares the same transmission output shaft as the pre-‘21 V7s.
« Last Edit: May 02, 2026, 02:22:38 PM by Dirk_S »
