Author Topic: Dash Disassembly? (for Idiot Light Replacement)  (Read 3835 times)
Offline Mwether
« on: July 30, 2025, 08:49:07 AM »
Hi, all.
Can someone please point me to a resource for taking the EV dash apart? I figure I'll check/replace the high beam bulb.
Removing the three 4mm bolts at the bottom and the three 3mm bolts in the plastic "chrome" cover gets you this far, and it's obvious that the T-shaped insert slides back away from the aluminum plate that holds the gauges.
However, the clearances are tight, and I don't want to break/strain cables or connections. It feels like something else might be holding the light assembly to the dash?
ETA: Do the speedo and tach have to come out too?
Found these two shop manuals, but I don't think either addresses this...
https://thisoldtractor.com/mg_manuals/workshop_manual_california_update_en_de_ne.pdf
https://cadrecycle.com/manuals/technical/California%20EV%20V1100.pdf
EDITED TO ADD: Duh! See page 212 of manual!
« Last Edit: August 08, 2025, 06:36:19 PM by Mwether »
2004 Moto Guzzi California EV1100 Touring
2021 Piaggio Liberty S 150
Re: Dash Disassembly?
« Reply #1 on: July 30, 2025, 09:01:34 AM »
Helps to take off fairing, disconnect speedo & tach, flip it over and there are screws in holes in T shaped part in center.
Offline Mwether
« Reply #2 on: July 30, 2025, 09:21:02 AM »
Thanks, Steve! Huge help.
It's more involved than I thought but will definitely help me get to know the bike better! :thumb:
Offline Mwether
« Reply #3 on: July 30, 2025, 03:15:50 PM »
Okay, learning as we go. Thanks again, Steve! :thumb:
Those are some TINY bulbs!
Harper's has them here.
https://harpermoto.com/products/blub-all-glass-164634
Maybe I should replace all six since I'm in here? Or is that overkill? They ARE twenty-one-years old...
Online AJ Huff
« Reply #4 on: July 30, 2025, 04:03:52 PM »
Somebody just last week was talking about replacing those with LED. Now might be a good time to consider that.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Online AJ Huff
« Reply #5 on: July 30, 2025, 04:07:20 PM »
Well maybe 2 weeks ago.
https://wildguzzi.com/forum/index.php?topic=123513.0
You'll find other discussions regarding LED swaps with the search function.
-AJ
'71 Ambassador
'05 Road King
MGNOC# L-753
Offline Mwether
« Reply #6 on: July 30, 2025, 04:23:00 PM »
Thanks, AJ.
I was wondering about LEDs too and mentioned the possibility to Curtis Harper, when I called him today.
Funnily enough, he's dealing with an LED-caused problem on a bike that's in the shop currently and advised using original equipment.
That was plenty good enough for me! :grin:
Online Tom H
« Reply #7 on: July 30, 2025, 04:25:09 PM »
You could likely find those bulbs at an auto parts store. There should be a number printed on them, so you should also be able to find them on the bay of fleas and the river site.
Personally I would stick with regular bulbs.
I can't remember if it was the EV series of bikes, but using LED in the dash could cause an issue with the turn signal lights??? I don't remember for sure???
« Last Edit: July 30, 2025, 04:34:36 PM by Tom H »
Offline 73 sport
« Reply #8 on: July 30, 2025, 04:26:59 PM »
   That bulb is a standard t5 w2x4.6d. check "Super Bright Leds"
Offline Mwether
« Reply #9 on: July 30, 2025, 08:50:35 PM »
I think you're right about that, Tom. There are workarounds, but if the incandescents last twenty-one to twenty-two years, that suits me fine!  :thumb:
Offline michaell32
« Reply #10 on: July 31, 2025, 12:38:41 AM »
IIRC the only ones that I put LEDs in was the low fuel and neutral lights.  I wanted them easier to see during the day with a tinted visor on my helmet.  They would be too bright for the high beam indicator and could be annoying at night.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline Mwether
« Reply #11 on: July 31, 2025, 06:00:27 PM »
Wanted to record here that the OEM incandescent bulb is #93450140 superseded to #164634.
And Gregory Bender sells them for .75¢ each!
https://www.thisoldtractor.com/for_sale_wiring_harness_small_blocks_93450140.html
That's the best price I've found, by far.
Offline SemperVee
  • USMC Retired
« Reply #12 on: August 01, 2025, 12:45:24 AM »
Good info!
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline Mwether
Re: Dash Disassembly? (for Idiot Light Replacement)
« Reply #13 on: August 08, 2025, 06:36:02 PM »
Just circling back with the resolution. Ultimately, I had success here but probably by doing it a more difficult way...?
The manual (photo added to original post) advises taking the headlight off, which allows better access to the back of the dash panel.
Prior to reading the manual, I'd already started going in through the front and had to use tweezers both to remove and install the bulb down in its plastic "well" (pic in Reply #3).
It was effective but probably a lot more fiddly than it had to be!
