Author Topic: The ECU landscape for early FI Guzzis  (Read 15394 times)
Offline vignelli
« on: August 18, 2025, 02:40:13 PM »
Hi yall, I was a member here a decade+ ago and left my account dormant, so I'm starting from scratch.
I've bought a Centauro and I'm researching the ECU. I've read a few threads with the different solutions mentioned but couldn't find a recent summary of them all. I'm a bit green here, but I'm familiar with MaxxECU as I'm using it on my Alfa GT. Maps are freely shared in that world so we tend to choose the ECU platform based on local tuner's preference.
Here's how I understand our options (with plenty of newby assumptions):
  • Stock Marelli ECU - live with "the stumble". Or else have someone who knows what they're doing flash the ECU with fueling/advance maps that they like. Or have someone make a chip for you.
  • Will Creedon chip - Remove a chip from your Marelli and insert Will's. Get the maps that Will dyno developed onto your ECU. I also assume his maps aren't otherwise shared freely (perhaps he sells his base maps?)
  • Cliff Jefferies MyECU - A full ECU replacement, tailored to replace the Marelli unit without fuss. Plug and play with harness, calibrate your sensors, and run the maps Jefferies likes for you bike. Presumably different than Will's maps. Appears to support DIY road tuning and closed loop data logging for fueling refinement. I've found dyno operators to be picky about which ECUs they will work with, so not sure I could get on a dyno with this.
  • Full aftermarket - A decent unit like the MaxxECU mini is double the cost of MyECU, but they have wide dyno support and the tuning software is great. Unless you can buy one of the base maps above, you are starting from scratch and doing everything on a dyno.
It seems like many are happy with Will's maps, and others didn't get a great tune until they got a MyECU (possibly some Marelli hardware glitches to fault). It even sounds like some did both, although it wouldn't be clear to me which maps they'd be running.
Is the only way to get Will's And Cliff's maps to buy both units?
« Last Edit: August 18, 2025, 05:55:10 PM by vignelli »
Re: The ECU landscape for early FI Guzzis
« Reply #1 on: August 18, 2025, 03:19:10 PM »
I been tuning that 16M ECU since day one and I believe you need a chip maker and I haven't seen anyone download anything into it. I also have a MyECU from Cliff & run open loop. Seems no one out there runs a P8 MyECU cept Cliff & I and he does closed loop. So I started with his map & modified it, then made my own w/no dyno. I replaced the chips in both P8 & 16M when they were available. Never had an issue tuning any glitches out w/o a dyno. 15M is downloadable & newer ECU's are too.
It all depends on what's out there now days & how your bike is set up w/intake & exhaust. Most I did had no airbox & open exhaust not stock
I'm also retired now & worked with the dealer equipment so don't know about aftermarket ECU's cept MyECU
Talk to the Guy's on COG or V11LeMans forum they know who's doing what nowdays.
GOOD LUCK in your search.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #2 on: August 18, 2025, 05:00:53 PM »
Other option, use a Marelli 15m, it's a bit smaller unit, but can be written with maps. So you need no chips getting burned.
The air pressure sensor is inside, so you loose that.
And the connector is a 26 pin superseal, or cut the stock one off the loom, and crimp contacts for the new connector on. Or find the injection loom for a v11 or one of the cali's that have the 15m.
Paul
Daytona 1225, Stelvio 1151
Offline vignelli
« Reply #3 on: August 18, 2025, 05:42:15 PM »
Does this mean the Will Creedon chips are NLA? That would certainly limit my options.
It appears you can edit maps on the 15M with some combination of GuzziDiag and TunerStudio. In that case I guess you're just choosing between that hacked Marelli ecosystem and Cliff's custom ecosystem. I also noticed since my first post that there is a myECU forum with a couple published Centauro maps.
I am keeping my eye on the COG forum, hoping it comes back online soon. I do wish there was an archive somewhere!
Online PeteS
« Reply #4 on: August 18, 2025, 06:49:29 PM »
Have you ridden the bike yet and does it have the stumble? I would be surprised if someone hasn’t already done something with it already. They were almost unrideable stock.
Offline vignelli
« Reply #5 on: August 18, 2025, 07:07:49 PM »
I haven't, I'm picking it up later this week. Given how deep I've had to dive with the Alfa ECU it's just top of mind, wanted to know what's out there for the Guzzi. I'm not specifically worried about the stumble, I'll likely want control over fueling/ignition maps either way.
Online PeteS
« Reply #6 on: August 18, 2025, 07:23:03 PM »
The original CPU came with a Eprom map. To change it you have program another chip or replace the CPU all together.
I am not aware of a Power Commander for this bike like one that was available for P8s used in the EVs of that era.
« Last Edit: August 18, 2025, 07:25:14 PM by PeteS »
« Reply #7 on: August 18, 2025, 08:24:31 PM »
I think you can still get his latest, I don't have his info. I think he's still out there.
Offline Turin
« Reply #8 on: August 18, 2025, 10:10:47 PM »
Which Centauro are you buying? There's been a few up for sale lately.
I'm pretty sure Will is still burning chips. Best bang for the buck IMO.
Chances are your New Centy will already be chipped, and have one of his chips.
Guzzitech used to sell the Power Commander USB for these bikes. I had on my Daytona RS until I installed the C-kit cams and got a new C-kit chip from Will.
The Daytona RS chip may end up in my Centauro when I open it up.
1985 Sidlow Guzzi
Offline vignelli
« Reply #9 on: August 19, 2025, 12:12:37 AM »
I bought the one Iconic was selling in LA, came from NorCal originally I believe. We'll see what's installed in it. I appreciate the input from everyone, it's good to know what the options are if I want more control over the maps.
I did leave the Power Commander out... I get the appeal of leaving the original ECU intact, but something about doubling (triple with ignition?) the number of ECUs in the chain overloads my simple brain.
« Reply #10 on: August 19, 2025, 08:02:24 AM »
The original Centauro chip had a flaw in the code. It would often stumble. The factory never homologated and released the updated chip. But we got the factory code and spread it. About any after market chip will have the updated code that reduced the stumble.
Not sure if my chip burner still works.
Offline Turin
« Reply #11 on: August 20, 2025, 09:51:41 AM »
The black one... very nice and very well bought.
COG is down, but there are probably enough guys on this forum who are familiar with Hi-Cam Guzzi's.
« Last Edit: August 20, 2025, 12:06:19 PM by Turin »
1985 Sidlow Guzzi
Offline vignelli
« Reply #12 on: August 25, 2025, 01:34:07 AM »
Got the bike back home today after a two day ride on coastal/canyon roads. Popped the ECU cover and the chip has a paper label with "CentiX2" written on it. Google isn't turning up a verbatim match for that.
It does have a miss/hesitation somewhere lower in the rev range, can't say where for sure since it has a bouncy tach, but feels like 3k-4k. Engine didn't rev as freely as my carb Sport 1100, I assume that's not right either.
The biggest issue was a harsh transition between throttle closed and 1% open (in either direction). There's a sharp jolt to the rear tire each time you cross that threshold, no way to smoothly enter engine braking or apply throttle out of a corner.
It probably needs some sorting all around, it's been on non-op for 20 years. I don't want to judge the fueling/ignition just yet. Maybe a throttle sync, check timing and pickup/sensor clearance and whatever else might cause issues.
Online BMCMOTO
« Reply #13 on: August 25, 2025, 05:19:30 AM »
Careful attention to correct (zero) throttle free play pays off hugely on the early high cams. Idle speed also plays a part in the herky jerky throttle business. You should be feeling a rush of acceleration above about 4k rpm, almost too quick to roll off before redline. They are great bikes once sorted. Have fun!
Brian
« Last Edit: August 25, 2025, 09:14:14 AM by bmc5733946 »
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline sign216
« Reply #14 on: August 25, 2025, 07:52:42 AM »
I bought a MyECU decades ago, and still run it on my primary bike, an '09 V7 Classic that I big bored to 820cc.  The MyECU was terrific, letting me control aspects of the bike's operation through an app to my cell or tablet.  People trade maps, adjust them, etc.  Very nice, back then.  Now my unit isn't fully working and MyECU support is diminished.
The MyECU shop "upgraded" the software, leaving older units like mine, unable to communicate with the app.  I talked w their shop, and the answer is to replace the MyECU bluetooth adapter to a newer version, and program it to communicate between the MyECU and my tablet or cell.  I got the adapter, but ran into problems getting it communicate.  The adapter's software needed adjustment/rewrite.  The answer from the MyECU shop was "use ChatGPT to solve it."  Not very satisfactory.
My bike rides fine, and I'll deal w getting the MyECU unit working, during the winter.   It was a terrific unit to start with.  Hopefully I can get it resolved.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #15 on: August 25, 2025, 09:09:13 AM »
I used chips from Moto Int & FIM in AU sold in US at the time. Didn't make any notes on what they were tagged. Didn't know about Will C at the time.
Offline FarmallA
« Reply #16 on: August 25, 2025, 09:44:36 PM »
FWIW this is the chip I found installed in my ‘97 Sporti.  I’m pretty sure it’s a Will Creedon.
It seems to still have an occasional 3k rpm hiccup, and an occasional stoplight stall.  But from I’ve read, the factory chip is almost unrideable.
I’ve made it much better the when I first got it. The most effective cure for me, after cam chain tensioner replacement, tps adjustment, and probably a few other things I’ve forgotten about, was valve adjustment to the Raceco specs (.008 intake, .010 exhaust).
That’s all I got.
FarmallA
Steve
Offline Turin
« Reply #17 on: August 25, 2025, 10:20:46 PM »
make sure your throttle bodies are synced before you mess with the chip. The white adjustment knob (visible on the left side) tends to rotate on it's own and can cause a snatchy throttle response.
1985 Sidlow Guzzi
Offline vignelli
« Reply #18 on: August 25, 2025, 10:29:49 PM »
I did notice there was a lot of throttle free play after I got home. I don't think that fully explains it... I was closing the throttle a hair's width at a time, and it would still jerk into engine braking. The bike does idle around 1200 which I figured was high. And I can see how a faulty TPS reading would confuse things.
Confirmed tonight that grounding the tach body didn't fix my bouncy tach. So looks like I'll be stashing this one and going aftermarket for the short term.
Will try yalls other suggestions, set valve lash, tps, belt tension. I'm going ahead and doing the oil pump (maybe more Caruso bits depending on what condition I find things in there) and the belts, so I can verify timing, pickup clearances, etc.
I'll hold off on myECU until I've seen how this chip runs with the rest of the bike in tune.
Offline vignelli
« Reply #19 on: August 25, 2025, 10:31:19 PM »
Will do. I saw Guzziology recommends a jam nut to hold it in place.
Offline Turin
« Reply #20 on: August 25, 2025, 10:37:19 PM »
I'm a big fan of will creedons chips. I've have 3. I'm pretty sure he only charges $100 for the chip.
Cheap and easy.
1985 Sidlow Guzzi
Online BMCMOTO
« Reply #21 on: August 26, 2025, 08:06:00 AM »
That jam nut is essential!  Known amongst some of us as the Shelby nut. Shelby Kennard was the parts guy at MGNA at the time and came up with the idea.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline vignelli
« Reply #22 on: June 21, 2026, 03:39:57 PM »
Well, I'm back on this issue after a long period not riding the bike.
Got the fueling basics set up: Throttle cable slack removed, TPS set precisely to 150mv, throttles manometer balanced at 4k RPM using the linkage, idle balanced with LH air bleed, idle set at 1200 (looping through that process a few times). Set trim screw on the 16M to just above a stumble at idle, which landed it right in the middle.
I rode it again, and the harsh throttle transition from 0% to 1% throttle (and vice versa) hasn't improved.
I haven't gone into valve lash or belt tension yet, this feels so much like a fueling/ignition/mapping issue. I found this section in the Guzzi EFI tech bulletin that talks about overrun mapping. This is what it feels like, overzealous cutting of fuel when the TPS hits 0%. I'm wondering if I read this chip in something like TunerPro if I'd see zeroes in the part of the table where load is low and RPM is high.
I think I'm going to buy a TL866 (seems to be the correct chip reader/writer?) and a stack of blank chips. Read the two chips I got with the bike and see if I can do any better. I have an XDF file for the Daytona that GuzziDiag published as well.
Does anyone have an XDF for the "corrected" fueling/ignition that Guzzi circulated via Creedon and others?
« Reply #23 on: June 21, 2026, 03:45:15 PM »
WOW, 10mo later
Offline vignelli
« Reply #24 on: June 21, 2026, 03:49:40 PM »
This bike hasn't been registered since 2006, so more like 20 years later
« Reply #25 on: June 21, 2026, 04:04:16 PM »
Buy a ColorTune to set the idle mixture on the ECU, it's a glass bottom spark plug. To adjust the flame, watch it go from orange to blue. Much cheaper than an O2 sniffer for exhaust. It will make a big difference to get it correct. Controls up to 2500rpm and more.
Offline vignelli
« Reply #26 on: June 21, 2026, 04:16:17 PM »
I don't spend much time below 3K on my local roads, this symptom happens everywhere in the rev range. If I close the throttle at 6K it bucks forward like someone grabbed the front brake.
I did give the trim screw a solid go. Road up and down my road with it set to 50%, 75%, and 100% without much change. Below 50% it's too lean to idle. I do have a remote lambda setup I could take readings from if I need to, just a bit of pain to set up.
« Last Edit: June 21, 2026, 04:16:45 PM by vignelli »
« Reply #27 on: June 21, 2026, 05:28:34 PM »
I haven't found you set it by seat of pants. That's why they make tools.
Offline vignelli
« Reply #28 on: June 21, 2026, 06:17:55 PM »
Sure, I can take set up the lambda sensor and take a reading if you think the trim setting could cause my symptoms. The manual made it sound like it only affected idle.
