Author Topic: Where do I get custom intake rubbers with keihin carbs?  (Read 324 times)
Offline NCAmother
« on: August 30, 2025, 04:49:29 PM »
Hi, I have a 77 lemans motor and a set of aluminum intakes.  I need the rubber intake hose from manifold to 39mm keihin fcr.  Does anyone have a vendor recommendation for custom intake rubbers or part number?  The outer diameter of the keihin carb is 48mm,  thank you very much
Howdy
Offline NCAmother
Re: Where do I get custom intake rubbers with keihin carbs?
« Reply #1 on: August 30, 2025, 05:10:46 PM »
Oh, the intake spigot is 44mm, so it’s 44mm to 48mm rubber step up.  Can’t seem to find one, thanks
Howdy
« Reply #2 on: August 30, 2025, 06:14:29 PM »
I have used radiator hose before, that's what BMW airhead guys did back 40yrs ago. Not politically correct but works.
Offline RinkRat II
  • Lake Powell AZ
« Reply #3 on: August 30, 2025, 08:07:54 PM »
    Your local hardware supply should carry a " no hub " connector in various pipe sizes that may fit the bill.  The rubber sleeve comes out and is pretty pliable.  A 1 1/2 no hub may work.
   Paul B :boozing:
Offline Turin
« Reply #4 on: August 30, 2025, 08:46:13 PM »
I used factory lemans 1000 intake manifolds and rubber connector. also did the same with the mikuni hsrs
« Last Edit: August 30, 2025, 08:50:08 PM by Turin »
1986 Sidlow Guzzi
1996 Triumph Daytona 900
« Reply #5 on: August 31, 2025, 01:21:34 AM »
I used a BMW car radiator hose to mount PHF 30 mm carbs to intake stubs on a V65. The changed diameter at the end and fit perfectly. I had to buy two and cut the ends off. Back then they were about twenty bucks apiece. I don’t know the part number or what car they were used on so if you can get a parts guy to look for tapered radiator hoses you might find what you need. They told me they wouldn’t last, they were right. After thirty years they got hard, no longer pliable.
Online Cdn850T5NT
  • Cdn850T5NT
« Reply #6 on: August 31, 2025, 11:52:03 AM »
John A - 30 years is pretty good 😉.
« Last Edit: August 31, 2025, 11:52:52 AM by Cdn850T5NT »
1985 Eurospec 850 T5 NT (Nuovo Tipo - New Type... i.e. Series III)
Offline NCAmother
« Reply #7 on: August 31, 2025, 02:22:12 PM »
Also, how close should I place the carb to the intake?  Is the rubber from the no hub connector fuel proof? Thanks
Howdy
Offline RinkRat II
  • Lake Powell AZ
« Reply #8 on: August 31, 2025, 04:26:32 PM »
     Most no hubs are neoprene so they're suitable for petroleum, acids, refrigerants etc.
     Paul B :boozing:
Offline NCAmother
« Reply #9 on: August 31, 2025, 04:34:14 PM »
     Paul B :boozing:
Thanks, I think I’m gonna go this route as it won’t hurt my wallet so bad!
Howdy
Offline NCAmother
Howdy
Offline 73 sport
« Reply #12 on: September 01, 2025, 04:12:22 PM »
    Flourosilicone is compatible with fuels. If in doubt about Charlies' recommendation, call the Mfgr.
Offline 73 sport
« Reply #13 on: September 01, 2025, 04:19:43 PM »
      PS on my last. I use quality radiator hose for my carb hook-ups.
