If I was on a budget, the Fleabay one should be fine from that seller. Steve is listing from a reliable source, but a tad more expensive.
If you want to pull your TPS, you can look at the, Ummm, ramp of the TPS with a voltmeter set on continuity, If you have an oscilloscope, that will give you a much better visual reading of the ramp/progression of the TPS. You do not want any drop outs while advancing the TPS.
OR....just simply buy another one and move forward with it
