Author Topic: Rear wheel removal V7 Special 850  (Read 2330 times)
Offline Cal3Me
« on: October 08, 2025, 07:33:30 PM »
Say it isn't so ,,,,,, do I have to remove the rear drive unit to remove my rear wheel that has a flat tire on it on my 850 soecial. I have already buggered up two hex factory fasteners trying to break things loose. :cry:
TMS
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Rear wheel removal V7 Special 850
« Reply #1 on: October 08, 2025, 07:42:38 PM »
What can’t you break loose?
Offline Kev m
« Reply #2 on: October 08, 2025, 07:59:33 PM »
You don't have to remove the rear drive on any of the 750 models, so probably not, but I haven't done it yet on a new 850.
Offline buck
« Reply #3 on: October 10, 2025, 08:28:47 AM »
The rear drive does not need to be pulled. Jack up the bike, remove the brake caliper pin in the swing arm, remove the axle and slide the wheel off of the drive flanges. I can’t remember if stock mufflers get in the way of removing the axle (my bike has agostinis), but you might have to remove a muffler. Not difficult at all.
Offline Cal3Me
« Reply #4 on: October 10, 2025, 08:44:52 AM »
The problem is the brake the brake caliper pin and the rear drive fingers are in the way and the fat tire does not clear them. But now the mention of removing the caliper pin that might give me the room I need. I'll report back if this works ,,,,,,,, fingers crossed.
TIA
TMS
Online Dirk_S
« Reply #5 on: October 10, 2025, 08:48:08 AM »
Removing the caliper pin and dropping the caliper is indeed essential (along with removing the left shock), and is shown in the service manual.
« Last Edit: October 10, 2025, 09:07:28 AM by Dirk_S »
Offline Kev m
« Reply #6 on: October 10, 2025, 09:02:26 AM »
A buddy of mine supports the bike, then unbolts BOTH shocks and he made brackets to reattach/hold the shocks so the axle sits just below the exhaust. Thereby he doesn't touch the exhaust.
Offline Moparnut72
« Reply #7 on: October 10, 2025, 09:32:40 AM »
I don't know about the 850 but with the 3 series it helps to deflate the tire, but in this case the tire is already flat. :angry: Once you get the leak fixed and beads seated let the air back out. Makes it a little easier to get the wheel back in. Securing the rubber cushions with some type of adhesive will help towards maintaining G rated vocabulary.  :evil:
kk
Mopar or Nocar
2023 V100 Navale
2019 V7lll Special
MGNOC #24053
« Reply #8 on: October 10, 2025, 09:35:20 AM »
Helps to let air out of tire also to let it slide through.
Beat me to it
« Last Edit: October 10, 2025, 09:36:05 AM by guzzisteve »
Offline Bulldog9
« Reply #9 on: October 10, 2025, 01:02:54 PM »
***********EDITED FOR LESS IDIOCY............. ....*************** :bow:
After attempting to un____ this, I'm just gonna go stand in the corner............ :drool:
« Last Edit: October 10, 2025, 03:41:28 PM by Bulldog9 »
MGNOC#23231
Offline faffi
« Reply #10 on: October 10, 2025, 01:29:36 PM »
I believe the V9 has the same width rear tire of 150 mm (theoretically), and it is a PITA to fit. I now use a 140/90 instead of the stock 150/80 on my V9, and even that needs some gentle persuasion to move over the final drive. I also place my bike on a block of wood under the center stand, then remove both mufflers because it is easier than anything else. Shocks stay in place. IIRC, I only remove the pin of the rear brake unit. Biggest pain is refitting the wheel with rubber cushions onto the final drive, but a little bit of glue or silicone to keep them rubbers in place makes life much easier less annoying. AFAIK, the V9 and V7 850 are pretty similar in overall design, but just about every detail is different.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Kev m
« Reply #11 on: October 10, 2025, 02:27:07 PM »
1. Remove Cotter Pin and loosen castellated nut
You lost me at "cotter" what and "castellated" who?!?
Online Dirk_S
« Reply #12 on: October 10, 2025, 02:50:45 PM »
Yeah, Bulldog. You sure your Guzzi isn’t actually a KLR that somebody slapped an Eagle sticker on?
« Last Edit: October 10, 2025, 02:54:45 PM by Dirk_S »
Offline Bulldog9
« Reply #13 on: October 10, 2025, 03:24:53 PM »
You know, one of these.... https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Fwww.tcfixings.co.uk%2Fimages%2Fproduct_image%2FNCAUNF118.jpg&f=1&nofb=1&ipt=c9aa40a60a9980bfaa1423855d7be778dffa4b150ccfb92a3907434a5f807ada
 :drool: :drool: :drool: Sorry, crossing genre's...... My XS bikes have the castellated nut and cotter pin............. 45 years working on that bike, only 10 on Guzzi's. It's all mixed in a bunch of mush...........
« Last Edit: October 10, 2025, 03:26:29 PM by Bulldog9 »
MGNOC#23231
Offline Bulldog9
« Reply #14 on: October 10, 2025, 03:37:13 PM »
Ah.............. and I can't even blame it on bourbon or lack of coffee............. .. Just a brain fart and conflation.  The XS bike and the Guzzi's are all shaft drives and have similar azle changing procedures..... I've done it 20 times on the XS bikes and only 5-6 on my Guzzi's and 3 of them are CARC bikes with SSSA.
MGNOC#23231
Offline Cal3Me
« Reply #15 on: October 10, 2025, 04:20:43 PM »
Solved .......... as mentioned on this discussion list lots of ideas and knowledge. As it turns out all you 850 owners need to do is remove the caliper pin. And then the fat 150 tire goes right in, a third hand would be nice to help hold the tire while someone slides the axle, spacer and caliper bracket in. I did remove both mufflers just in case though. I used a little light grease on the rubbers to help slide the wheel on. Not one time did the rubbers ever come out even while the new tire was being mounted. I did have to replace one allen head bolt because it rounded off the points
 trying to remove it.
Thanks to one & all for the tips & tricks , carry on
« Last Edit: October 10, 2025, 04:22:14 PM by Cal3Me »
TMS
