P0335 Camshaft sensor: no signal
Topic: P0335 Camshaft sensor: no signal (Read 19916 times)
Kaladin
Gosling
October 11, 2025, 01:39:16 PM »
My 2007 Norge has the red triangle warning come on intermittently, but getting more mittent. Guzzi Diag says P0335 Camshaft sensor: no signal.
The bike still runs like a well-oiled top.
Any ideas?
thanks
mark
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be. And when you find it you discover "that's where it should have been."
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
RinkRat II
Lake Powell AZ
Re: P0335 Camshaft sensor: no signal
Reply #1 on:
October 11, 2025, 02:30:12 PM »
Likely swarf on the end of the sensor. Pull it out and clean it off see what happens. My $.02
Paul B
guzzisteve
"Just Ride It"
Reply #2 on:
October 11, 2025, 02:53:08 PM »
You got your warning, I'd get one. That's just me though, if you pull it have a new one in case there's no issue.
pressureangle
'97 1100 Sport i, '89 Mille GT
Reply #3 on:
October 12, 2025, 11:46:46 AM »
intermittent failures of inductive sensors are most often wiring faults. Pull the harness connector, clean it with Caig DeOxit, and see what happens.
You won't have swarf because it's inside the engine unless you have more serious issues internally.
The sensor is captured so it can't back out or have bad bearing clearance like automotive ABS sensors.
*if* the sensor is going bad internally, which they do, the failure will show up when the sensor is hot, such as idling in traffic on a hot day then return to service as it cools. This starts slowly and becomes more frequent and at lower temperatures until complete failure.
RinkRat II
Lake Powell AZ
Reply #4 on:
October 12, 2025, 01:22:27 PM »
Actually, the sensor see's all kinds of hot oil which carries microscopic metallic particulates the oil filter doesn't remove and over time it builds up on the end or the sensor.
Paul B
Kaladin
Gosling
Reply #5 on:
October 15, 2025, 11:38:02 AM »
Thanks. The triangle usually comes on when it's cold.
Do I have to pull the tank to get to it?
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
jrt
Reply #6 on:
October 15, 2025, 02:40:07 PM »
When mine when out, it went intermittently- worked when cold, not when it warmed up. And when I checked the resistance (cold), it was within spec. Never checked it warm.
So, I agree with Steve to have one on hand.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
guzzisteve
"Just Ride It"
Reply #7 on:
October 15, 2025, 04:31:50 PM »
Left hand side of front cover where the timing chain is housed.
Kaladin
Gosling
Reply #8 on:
October 19, 2025, 05:26:19 PM »
I found it, but I am at a loss of how to get to it. What do I need to disassemble to remove it?
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
jrt
Reply #9 on:
October 20, 2025, 09:40:13 AM »
I don't recall any difficulty in accessing it, but I have an EV, not a Norge. Maybe remove the fuel tank? On my bike, that area is relatively uncluttered.
Does the sensor look like oil is moving through it or it is leaking? If so, time for a new one most likely.
Oh- here are some maybe useful bits of info. This first one I copied off the internet- I'm sorry, but I don't recall the source, and it is only good for the two-hole model of CPS:
Crankshaft position sensor
For older fuel-injected Monsters and Supersports (with two holes, saying “Marelli 8i3” on it), the part number is the same as on an Alfa Romeo 145 or 146, on a Fiat Tip, Tempra, Ducato, or a Lancia Dedra. The part numbers are: Fiat 7679221, 7694335, 60603937; Alfa Romeo/Lancia: 60603937, 60810103, 7733001; FAE 79015; Meat & Doria 87074; Standard 18783.
And here is a diagram to add LED's across the fuel pump and injectors- which let you know that they are powered up. This is thanks to KiwiRoy- he gets all credit. When you turn the key, both LED's will light up. The one on the pump/coil will shut off after ~3 seconds. When you crank the motor over, it should come back on and both should stay on.
Last Edit: October 20, 2025, 09:45:12 AM by jrt
L-720
1973 Eldorado
2020 R1250RS
Kaladin
Gosling
Reply #10 on:
November 01, 2025, 09:10:49 PM »
To answer my own question, I found that if I loosen the fairing by taking out a bunch of screws I can take off the exhaust pipe and access the camshaft sensor with some difficulty. I never learned how to fix things by swearing, but I was able to get it out despite this handicap. 4mm allen wrench using a 1/4 inch socket wrench and extenders for anyone who is interested.
It looks like I will also need to remove the tank and air box in order to find the wire connector, which I will do when I get the new sensor.
more as it happens. . .
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Kaladin
Gosling
Reply #11 on:
November 05, 2025, 02:24:41 PM »
Here is a photo of the cam position sensor in place.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
John A
No way to slow down...
Reply #12 on:
November 06, 2025, 01:00:35 AM »
A search on this site should get you some tips on setting the clearance between the sensor and cam wheel. I used the JB weld quick setting method that worked well. Otherwise you have to access the cam wheel and use a feeler gauge
jrt
Reply #13 on:
November 06, 2025, 09:45:11 PM »
I made a simple tool to measure the distance between the seat and the gear teeth. It's just a rod, friction fit in a delrin housing. Insert the delrin into the hole, push down the rod. Pull it out and use a set of calipers to measure it. If anyone wants to use it, I'll send it out.
L-720
1973 Eldorado
2020 R1250RS
Kaladin
Gosling
Reply #14 on:
November 12, 2025, 12:54:23 PM »
I can see now how the cam sensor distance is determined, but how the heck do you set it? There were no shims under the old one, and no shims supplied with the new one.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
jrt
Reply #15 on:
November 15, 2025, 03:36:06 PM »
You might have to make your own. In my case, the old and new were the same dimensions, so I did not need to do any adjusting.
L-720
1973 Eldorado
2020 R1250RS
Kiwi_Roy
Reply #16 on:
November 15, 2025, 07:55:59 PM »
If the sensor fails chances are the coil will be dead that's why its nice to have an LED monitoring the relay Voltage as shown on the sketch.
The sensor consists of a small magnet with a coil wound over it, as the timing gear teeth pass by the tip of the magnet it creates ripples in the magnetic field that induces a waveform in the coil which is monitored by the ECU
No ripple in the field = no waveform for the ECU so it releases the coil feeding the relay so no fuel pump and no ignition.
Without fuel and ignition the engine is a dead weight!
I suspect the sensor fails opening a microscopic crack between the coil and the connecting wires.
This sensor is about the only thing you can't fix by the roadside, it would be a good idea to carry a spare c/w the required shims to set the gap.
http://www.dpguzzi.com/efiman.pdf
Page 13
The resistance may have changed over the years but the idea is the same.
Last Edit: November 15, 2025, 08:08:10 PM by Kiwi_Roy
Kaladin
Gosling
Reply #17 on:
November 19, 2025, 04:22:18 PM »
Yes, you have to remove the gas tank and the air box in order to get to the camshaft sensor cable connector. Here it is:
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Haioku_Mantan
Hatchling
Reply #18 on:
July 30, 2026, 01:46:24 AM »
Quote from: Kaladin on November 05, 2025, 02:24:41 PM
Many thanks for the pic. I had the same issue with the warning and CPS fault leading to the bike occasionally not wanting to start so I went down the rabbit hole of replacement parts and got a Facet 9.0032.
FYI here is a list of equivalent parts:
Guzzi Part #GU01721600
Magnetti Marelli SEN813
Alfa Romero 60810103
Fiat 7733001
Meat & Doria: 87074
FAE: 79015
Sidat: 83.125
Era: 550092
Facet 9.0032
AK24 was the cheapest including shipping to Singapore so went with them. Removed the two bolts at the rear of the lower fairing to get a little better access and removed the header pipe as well. Seems like the previous owner had RTV'ed or cemented the sensor in place with some rubber sealant and that was flaking off which may have been causing some intermittent sensor readings.
The sensor Ohm readings were well within spec (checked before ordering and removing the old one) but even cleaning the contacts didn't fix the issue so I went and bought some peace of mind for $20 and 20mins of my time. The old sensor had 3 shims on it and an o-ring. Reused the shims. Had to clean a bunch of the sealant off from the shims and the motor itself as well.
It is a very tight fit but doable like others have mentioned with some extensions and universal joints. Just make sure you do the O-ring trick to the U-joint so its not all floppy and holds the position you want securely.
Works just fine and starts right up afterwards. Was so worried that it would turn into a 2 hour nightmare but pleasantly surprised at how easy it was.
Current:
'07 Norge
Previous:
'07 Honda Deauville
'12 KTM SuperMoto
'94 ZZR 400
'92 ZZR 1290
'92 Bandit 250
