Author Topic: V7ii Main Seal DIY  (Read 5659 times)
Offline Error
V7ii Main Seal DIY
« on: October 12, 2025, 06:30:45 PM »
So my 2016 V7ii (North American) Stone looks like the main seal has decided it’s no longer interested in doing its Job.
It’s been showing the same oil leak all this season, whipe it off it comes back. I’m assuming it’s the main seal as it Dosent smell like trans fluid, even after pulling the starter and sniffing around. But I guess I’ll only know for sure once I have it apart.
I’m debating on doing this job myself (my preference) but it would be nice to find someone who has already done this with pictures so I can look at steps and the best way to do it. A step by step clutch job would be the same thing as well.
Anyone have done this deal or a clutch job on a V7i/ii/iii that want to share steps and pics?
Online Vagrant
Re: V7ii Main Seal DIY
« Reply #1 on: October 12, 2025, 07:07:04 PM »
When you pulled the starter was everything soaked with oil. I wouldn't touch it until the clutch starts slipping. Most Guzzis show that same outside oil; mist.
Offline Error
« Reply #3 on: October 12, 2025, 09:22:55 PM »
Soaked no, but certainly a light a coating that I’m not super happy with in a dry clutch setup. The bike has 36k or so KMs on it. I’d like to sort it.
https://www.thisoldtractor.com/moto_guzzi_technical_training_videos_eng_v750.html
 These videos are fantastic, I’ve used them before. I was more looking for something to walk me through getting the bike torn down to the point I could address the seal.. It doesn't look all that complicated, but it would be nice to have a walk through to that point.
I suspect best practice is to just start removing parts from the rear wheel forward until I hit clutch lol.
Offline jrt
« Reply #4 on: October 12, 2025, 10:14:40 PM »
That's about right.  I don't know if you need any special tools for the small block clutch (you do for the big block).  i just haven't looked into it.
But- to get to the clutch is not as much hard as it is time consuming.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #5 on: October 13, 2025, 08:02:32 AM »
I’ve been in a V7 II engine a couple times—once to replace the clutch (unnecessarily in hindsight) and also during my engine rebuild when I spun a big end bearing. You can either separate the frame completely from the motor like so (performed on the Lario last year to haul it into my basement):
…or crabbing the frame, making sure to separate all connections between motor and frame, like so, when I thought my clutch may be slipping, but turned out to be—ahem—a dirty fuel filter…<clears throat>:
If you remove the frame completely, you can more easily work on it in your dining room/kitchen like I did when I replaced my V7 II’s top end:
The custom bike-building bloke helping me out with the job in the middle photos had no experience with a Guzzi motor, but because he was once an auto mechanic—and these motors are very much like a car engine—we were able to do the job with no special tools; just a few of the mechanic tricks he had learned (spanner on a bolt to keep the flywheel from rotating when torque’ing down the clutch, using a long bolt to connect the clutch assembly first before resorting back to the standard flywheel bolts, understanding how to properly center things, etc. I also used the training videos and got a little help from a couple folks here.
« Last Edit: October 13, 2025, 08:09:18 AM by Dirk_S »
Offline Error
« Reply #6 on: October 13, 2025, 10:42:24 AM »
More or less what I expected. Would still love to see a tear down of the bike to this point in video, but I don't think there are any around.
I also ran into this picture, I believe it was on the Guzzi Tech site. This seems like its possible to leave the rear end in one piece, unbolt just the trans side and drop it out. This would be my preferred method I think.
Has anyone does it this way before?
« Last Edit: October 13, 2025, 10:45:28 AM by Error »
« Reply #7 on: October 13, 2025, 11:45:43 AM »
Your last picture of the trans and rear wheel together is IIRR how Guzzi installs the drive line at the factory. I think I have seen this in the manual??
I have done the seal/clutch crabbing like a Tonti by pulling the whell and then the rear dive/swing arm assy.. Clutch disc centering can be done without the factory tool. You "snug" up the clutch assy. while still being able to move the disc just a bit and then use a drill bit of descending sizes to feel around the clutch plate. Once the drill bit fits perfectly all the way around, the plate is centered.
Offline Dirk_S
« Reply #8 on: October 13, 2025, 12:15:50 PM »
Highly recommend using a heat gun to soften the 2-in-1 intake snorkel to pry off the throttle body or manifolds.
Offline Error
« Reply #9 on: October 13, 2025, 01:32:35 PM »
Good idea. I muscled them off when doing a head gasket, as well as when removing the charcoal box. It was the hardest part of both jobs lol.
Offline Dirk_S
« Reply #10 on: October 13, 2025, 03:43:41 PM »
Your last picture of the trans and rear wheel together is IIRR how Guzzi installs the drive line at the factory. I think I have seen this in the manual??…
That lower picture looks like the frame isn’t even crabbed. BUT—With the lower frame rails removed from the engine, that motor is not connected in any way EXCEPT by the intakes. It’s indeed another option, and it alleviates the need for all the disconnections, but I would want to make sure that motor isn’t going to fall over. At least when crabbing the frame, the motor remains connected to the lower frame rails, which are still connected to the front of the frame by one bolt on each side.
If you go about that method, keep in mind the pesky neutral switch located underneath the battery bay. It can easily be damaged. Lower the gearbox slightly, then disconnect the neutral switch before proceeding.
« Last Edit: October 13, 2025, 05:31:16 PM by Dirk_S »
Offline Error
« Reply #11 on: October 13, 2025, 04:05:41 PM »
This is the kind of thing a video/walk through would be fantastic for!
Thanks for heads up.
My first hurdle will actually be seeing if I can get the seal where I  am. Local Guzzi dealer has had a clamp on order for 4 months for me. I’m not willing to start this project until seal is in hand.
« Reply #12 on: October 13, 2025, 05:09:23 PM »
MG Cycle and Harpers come to mind for parts. Just make a decent order of any bits you may need since there is Int'l shipping.
Offline Error
« Reply #13 on: October 13, 2025, 06:18:19 PM »
I've already noted a few places overseas Ill try if i cant get it here. I'm up here in Canada, so we are not seeing the tariffs our friends down south are, but Id still rather pick up local so there are no surprise charges if I can.
