Author Topic: Norge gas tank too long  (Read 26791 times)
Offline Kaladin
« on: October 15, 2025, 12:45:49 PM »
So evidently the gas tank has swollen because when I try to get it back on the screw holes won't line up.   Any clever ideas on how to re-install it?
I also need to slide it back at the DMV so they can read the VIN number. . .
And then re-install it in the parking lot.
thanks
mark
First you look where it should be, then you look where it might be, then you look where it won't be, then you look where it mustn't be.  And when you find it you discover "that's where it should have been."
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Re: Norge gas tank too long
« Reply #1 on: October 15, 2025, 12:54:47 PM »
Mine hasn’t been able to bolt in place for years and I tried cutting down the rubber grommets but it didn’t help, maybe I need to do it again. I’ve been told that draining the tank and letting it sit for a few months will shrink the tank and you’d have to use non ethanol gas to keep it from expanding again; it’s easy to get non ethanol where I live but that isn’t always the case, especially on a road trip.
In the meantime I just use a large zip tie to keep it in place in case of an accident.
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: October 15, 2025, 01:06:14 PM »
Drain the tank and place it in a freezer overnight?
Offline PJPR01
« Reply #3 on: October 15, 2025, 01:07:37 PM »
Get a medium size Philips screwdriver with a long handle, insert it into the tank hole and thru the threaded frame and firmly push forward, while sitting on the bike with your knees pressed on the tank pushing it forward a bit.
Remove the screwdriver while keeping the pressure on the tank with your knees and thread in the screw.
Presumably you are fully aligned on the rubber grommets at the front of the tank?
« Last Edit: October 15, 2025, 01:09:07 PM by PJPR01 »
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Kaladin
« Reply #4 on: October 15, 2025, 01:46:30 PM »
I tried that, the tank is too long.
I think leaving it off the bike for a week was the wrong thing to do.
Maybe the zip tie will work at least to get it registered. . .
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Offline SemperVee
  • USMC Retired
« Reply #5 on: October 15, 2025, 02:32:07 PM »
learned this on my first Norge, why she only gets expensive Mermaid tears (Ethanol free) for go juice.  I agree that probably shaving the front doughnuts might be the way "forward" in this case. YMMV.. :rolleyes:
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline Stretch
« Reply #6 on: October 15, 2025, 03:19:50 PM »
An excellent idea, Dirk!
If Kaladin ain't married, it might just work!  :shocked:  :laugh:
                                     -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline Kaladin
« Reply #7 on: October 15, 2025, 03:33:00 PM »
I am married, but I have a temperature chamber at work.  Should I bake out the water in the nylon or freeze it?
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
« Reply #8 on: October 15, 2025, 04:27:18 PM »
I used to have 2 pieces of 1 by(3/4") in my box at work. Put together, 1 on fuel tank & 1 on the ledge on fender would make a small tent shape. If you push down on the peak yuo move it right up in place, super easy. You could also cut the rubber pucks down. I found they go back to the enlarged size as soon you put in fuel unless coating and it still a waste of time.
Offline Mike Craven
« Reply #9 on: October 15, 2025, 05:43:52 PM »
Someone needs to (!) come up with a fabricated offset stud or clamp for mature tanks.
-Mike-
Mike  L-715, Atlanta GA
1983 Cali II
Offline PJPR01
« Reply #10 on: October 15, 2025, 07:16:57 PM »
I've had the tank off for a week or more in the past and just used this simple method with no issues.
By any chance did you take out the airbox or anything else that might be blocking the tank from fitting forward...100% sure the tank is set onto the rubber grommets and is not jammed somehow?
Paul R
2008 Silver Norge
2002 V11 Scura
Online Wayne Orwig
« Reply #11 on: October 16, 2025, 08:17:13 AM »
Drain it, plug the holes, apply a light vacuum. That may pull the moisture out plus shrink it.
Online Gliderjohn
« Reply #12 on: October 16, 2025, 09:01:03 AM »
thanks
mark
Can't speak for the first gen Norge but with a 2011 Norge two people can read the VIN on the frame neck by having one person look up from below using a small flash light while the other holds back wiring. That will get some of the numbers, the do the same looking down from above for the rest of the numbers. At first I was going to also loosen and move the tank back but the DMV office manager said I could not do that due to "altering the bike" which was not allowed. They have the private for profit tag offices available here. Went to one of them and did as described above because the worker knew how.
GliderJohn.
Back in central KS
Offline nwguy
    • Jim Gallant's home page
« Reply #13 on: October 16, 2025, 09:28:40 AM »
This is one of the two reasons I sold my first gen Ducati Multistrada. It had a plastic tank about 4 feet long (see pic below). There was a recall and I did get a new tank out of it. Then I found out that many owners had 2 tanks and left one to dry out in the garage until they needed to remove the other tank from the bike. Then they'd swap. Ridiculous.
The other reason I sold it was the frequent and expensive valve adjustments (bucket and shim) vs. doing my own on my old Norge or current Bassa. My old Norge tank did swell too.
Offline Kaladin
« Reply #14 on: October 16, 2025, 02:15:43 PM »
I also have a vacuum oven, but it won't fit.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Offline Motormike
« Reply #15 on: October 16, 2025, 04:17:19 PM »
Yep, I feel your pain.  Still have a Ducati Multistrada fuel tank in my attic.  Can't bring myself to toss it, even though the bike is long gone.  I gave up on the whole plastic tank/ethanol fiasco a few years back and sold most all (two Ducati's, one V11 Guzzi) the motorcycles in my modest collection that had PA6 nylon fuel tanks all made by Acerbus. Still have a Griso with a nylon tank, but am religious about only running non-ethanol gas in it.  The whole stupid E10 business has given me a real obsession about using non-ethanol gas in my bikes.
« Last Edit: October 16, 2025, 04:18:00 PM by Motormike »
Offline PJPR01
« Reply #16 on: October 16, 2025, 05:21:28 PM »
Non Ethanol is the main reason I go to Bucee's to fill up with 91 Non Ethanol...makes the bike run better and obviously seems to be helping with any tank expansion issues too.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline MGrego
« Reply #17 on: October 17, 2025, 01:51:27 PM »
I used a scissor jack between the tank and the frame, I think I had to use a small block of wood on the tank side.  Turn the screw till the holes line up, easy.  :thumb:
« Last Edit: October 17, 2025, 01:51:48 PM by MGrego »
Offline brider
« Reply #18 on: October 18, 2025, 10:47:56 AM »
I've had to remove my tank a half dozen times and the long screwdriver probably method has always worked. The holes never completely line up, but with enough angle of the bolt and a good socket I can get it started (probably cross-threaded) and then work the bolt to vertical as it screws in farther. HOWEVER, I may try that ingenious zip tie method next time if I can't get it, there are some zip-ties that are major beefy, would serve the purpose well.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Online SIR REAL ED
  • uh.... it's personal....
« Reply #19 on: October 18, 2025, 11:08:29 AM »
After you guys have managed to successfully shrink an expanded gas tank, have any of you sealed the gas tank to prevent future expansion?
IIRC, Caswell's Dragon's Blood gas tank sealant is recommended for "plastic" gas tanks.
« Last Edit: October 18, 2025, 11:11:09 AM by SIR REAL ED »
2019 Beta EVO 250
Online Dirk_S
« Reply #20 on: October 18, 2025, 12:08:05 PM »
For clarification, I think you’re referring to Caswell’s two-part epoxy tank sealer; Dragon’s Blood is one of the colors.
https://caswellplating.com/caswell-epoxy-gas-tank-sealer-car-tanks-up-to-20-gal-1-quart.html?srsltid=AfmBOopUSmpc8GsXoW-57vpfj5eBaeKP3Ak0UQ0hfWMBqc1YlbBUuSmW
« Last Edit: October 18, 2025, 12:13:44 PM by Dirk_S »
Offline Kaladin
« Reply #21 on: October 19, 2025, 04:58:18 PM »
Success, I found a small bottle jack that not only fit and was red like my bike.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Offline Kaladin
« Reply #22 on: October 19, 2025, 05:03:18 PM »
Sorry, for some reason the web page rotated  the image.  This one might be more understandable.
The hydraulic jack needs to be rotated so the oil can reach the actuating  piston.
« Last Edit: October 19, 2025, 05:04:46 PM by Kaladin »
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Offline Motormike
« Reply #23 on: October 20, 2025, 10:02:32 AM »
Having to use a hydraulic jack to put fuel tanks back on? I mean, seriously folks!? :rolleyes: I guess it beats an unusable bike.  It's a good thing those nylon fuel tanks have some flex to them.
Offline Kaladin
« Reply #24 on: October 20, 2025, 10:54:05 AM »
They must have some flex to them, since they fit nicely before taking out the bolt.  There also might be some extra compression of the front mounting posts.
2007 Norge Silver
2007 Norge Red
2000 BMW R1150GS
2003 Jaguar XKR
Online Moparnut72
« Reply #25 on: October 20, 2025, 11:44:23 AM »
I have never been in a situation like this but to me I would probably figure out a way to modify the mounting rather than stressing the tank.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online DoubleGuzzi
« Reply #26 on: October 20, 2025, 12:43:54 PM »
Same thing happened with my Triumph 955 Sprint ST; car jack and a block of wood to the rescue. There is a risk of rupturing the tank though.   :shocked:
Nearly natural progression..
Offline Abbienormal
« Reply #27 on: October 21, 2025, 04:12:56 PM »
I've had this problem more on the 2012 I had than both my 2007's one of which I currently am riding.  If it is not a lot then I use 2 round rods, punches, screwdrivers or whatever.  Put them on either side of where the bolt goes, slip them into the frame and push the tank forward.  On my 2012 it swelled too much for this to work so I took a either a file or dremel, I forget, and ground the hole so it was enlongated and I could put the tank on.  There was enough just plastic and not tank to do that in front of the hole.
2007 Moto Guzzi Norge
1972 Suzuki TS 90
Offline Motormike
« Reply #28 on: October 22, 2025, 05:51:34 PM »
I know from looking at the Norge, there is very little clearance from the front of the tank to the top triple clamp at full lock.  I've seen several where contact is already being made, if only just enough to chip the paint.  Something to watch out for if you are having to force the tank forward to get the rear bolt to line up.
Online SIR REAL ED
« Reply #29 on: October 22, 2025, 06:50:38 PM »
That is awesome!
Do you think a 2 ton bottle jack is up to the job?
2019 Beta EVO 250
